08-06-2012 01:22 PM - edited 03-16-2019 12:34 PM
Hi All,
I have a question if UCM 9.0 license calculation is different than for 8.6 .
If I have following license calculation for 8.6, then would it change somehow if I propose the same for UCM 9?
CUCM-USR-LIC | 1 | Top Level Sku For User License | 1 |
MIG-CUCM-USR | 400 | Upgrade ala carte CM to ENH USR, 1 User | 400 |
UCSS-UCM-3-1 | 400 | UCSS for UCM User for three Year - 1 users | 400 |
UCM-7825-80 | 2 | CUCM 8.0 7825 | 2 |
CUCM-PAK | 1 | Include PAK Auto-expanding PAK for CUCM | 1 |
CUCM-USR | 800 | Include PAK Auto-expanding User for CUCM | 800 |
LIC-CUCM-USR-A | 400 | Unified Communications Manager Enhanced Single User-Under 1K | 400 |
UCM-7825-80-UKIT | 1 | CUCM 8.0 Upgrade Media Kit | 1 |
UCSS-UCM-PAK | 1 | Include PAK Auto-expanding UCSS PAK for CUCM | 1 |
CON-ESW-CUCMUSR | 1 | CSSP ESS SW Top Level Sku For User License | 1 |
CON-ESW-EUSRA1 | 1200 | CSSP ESS SW Unified Comm Mgr Enh Sngle User Under 1K | 1200 |
Solved! Go to Solution.
08-07-2012 08:11 AM
The licensing programs have not changed since 7.1(5) / 8.0(2). This is to say that there are User Connect Licensing or Unified Workspace Licensing. The table above shows UCL licenses. What the user is entitled to use remains the same. The only difference is that CUCM and CXN 9.0 begin properly enforcing these licenses. In 8.6 and earlier the software was still tracking licenses by the legacy DLU model. The disconnect between provisioned DLUs and purchased UCL/UWL licenses allowed the customer to deviate from what they actually purchased. That will no longer be the case in 9.0.
I know that there is no direct upgrade option available but I am wondering if I can purchase above listed and then just install clean system using above quoted SKUs.
Sure. If you install a new CUCM 9.0 cluster and activate the licenses shown above in ELM you can use them.
Please remember to rate helpful responses and identify helpful or correct answers.
08-06-2012 02:02 PM
I would also like to know if there is any way to purchase above listed upgrade SKUs and perform upgrade from 5.x to 8.x
08-07-2012 08:11 AM
