195
Highlighted
Beginner
UCM GUI is sluggish after upgrade to 10.5(2)SU2a (10.5.2.12901-1)
I recently upgraded from a 10.5.2 release to 10.5(2)SU2a, and it all works fine. But the GUI is sluggish compared to earlier versions. Adding and updating phones takes perhaps twice as long to add or save. If an add or change took 2-3 seconds I'm going to say it now takes 5-7. Very noticably slower. Has anyone else seen this behavior?
4 REPLIES 4
Highlighted
can you please status of
can you please status of "Show status command from CLI and also did you tried to restart CM and see any change ?
Nadeem Ahmed
PS: Please rate all useful post
Br, Nadeem Please rate all useful post.
Highlighted
Beginner
Oops. I was going to restart
Oops. I was going to restart Tomcat on the pub and see if it helped. That did it. Weird, I've never had it run slow like that. Must not have started right after the upgrade. Thanks for the response.
Highlighted
Beginner
Hope that you do not have Vm
Hope that you do not have Vm snapshots on Esxi, because that cause also cause issues when it comes to these issues.
Ronak Agarwal
Highlighted
Beginner
No we're not using that.
No we're not using that. Thanks
