09-24-2016 04:41 PM - edited 03-17-2019 08:10 AM
I want to upgrade UCM 10.5.1 to 10.5.2 & lots of phones are in branches over the WAN. I have 79XX (7942) & 8945 phones, how do i minimize the WAN utilization , waht is the best practice for this kind of situation?
Suchi
Solved! Go to Solution.
09-24-2016 08:26 PM
Hello Suchi,
I had a similar situation where the customer did not want to do firmware upgrade with the CUCM upgrade.
Before Upgrade
Do the upgrade for the Pub
After upgrade
change the phones' DP to their original ones before upgrade.
Now all your phones still with the old firmware. and your cluster got upgraded.
if you want to upgrade them, but not all at once to save your WAN bandwidth :
Regards.
Mohamed Helmy
09-24-2016 08:26 PM
Hello Suchi,
Before Upgrade
After upgrade
Regards.
Mohamed Helmy
09-24-2016 08:43 PM
If/when you want to upgrade, you can also consider peer firmware sharing, or setting a local TFTP server for the FW files.
09-24-2016 09:08 PM
The best would be to first upgrade the phones on the new firmware as per 10.5.2 by setting up a local TFTP server. I have tested it using TFTPD32 in lab and it works.
While upgrading you need to make sure that you distribute the Phones to the servers using appropriate call manager group.
Aseem
