UCMC server listing change..
jmachiggins
Hello, I'd like to change the way my publisher is listed on the server configuration page of a CallManager cluster.  I will not be actually changing the name or IP address of the server.  I just want it listed by IP instead of name, so I can avoide DNS issues.  Everything I can find out there refers to actually changing the name or IP of the server not just changing how it's listed on the Server Config page.  So my question is...Can i just change it and adjust the service URLs or do I need to go through the whole process as if it was an actual change to the name and/or IP of the server?
J
Chris Deren
Yes, you can safely change it.
HTH,
Chris
Thanks Chris.  What I really need to know is the process.  Do I just change it, adjust the URLs, and it's good to go?  Or are there additional steps I need to take?
J
Yes, adjust the URLs under enterprise parameters. It is also a good practice to reference CUCM servers by IPs as oppose to hostnames under System --> Server
HTH,
Chris
