208
valery cottencin
Beginner
Ucmuser can't acces to 78XX .pdf documentation by ucmuser interface
I have this message when i want to download the user guide for 7821 or 7861 ,on the ucmuser interface  :
HTTP Status 404 - /PhoneGuides/locales/en_us/PhoneOnlineGuide/7821_41_61_45/7821.pdf
type: Status report
message: /PhoneGuides/locales/en_us/PhoneOnlineGuide/7821_41_61_45/7821.pdf
description: The requested resource is not available.
My CUCM is in :  Version 9.1.2.10000-28
and the file a
Installed Software Options
cmterm-devicepack9.1.2.12031-1.cop Active
cmterm-devicepack9.1.2.12024-1.cop Active
po-locale-fr_FR-10.2.2.1000-1.cop Active
cmterm-devicepack9.1.2.11012-1.cop Active
cmterm-78xx.10-2-1-12SR1-4.cop Active
cm-locale-fr_FR-9.1.2.1000-1.cop Active
cmterm-78xx.10-2-1-12.cop Active
Does any one have a solution ?
2 ACCEPTED SOLUTIONS
Hi Valery,
Check defect https://tools.cisco.com/bugsearch/bug/CSCuq92971
HTH,
Mohammed Noor
Hi Valery,
Here is another defect for 10.5
CSCun17694 - Phone Manual/User guide is unavailable for 78xx phones in Self-Care
https://tools.cisco.com/bugsearch/bug/CSCun17694
HTH,
Mohammed Noor
5 REPLIES 5
Manish Gogna
Seems to be related to the following
https://tools.cisco.com/bugsearch/bug/CSCun57378/?reffering_site=dumpcr
Although Polish language is not listed in this, you may need to contact TAC for a confirmation.
Manish
Hi Valery,
HTH,
Mohammed Noor
Thanks for your answer.
It's ok for cucm V9.1.2
But I have another customer with a V10.5 and he has the same problème.I think the 78XX are ok in CUCM V10.5 ?
Hi Valery,
HTH,
Mohammed Noor
Perfect,
Thanks for your quickly answer.
Best regards
Content for Community-Ad
