UCOS_6.1.5.13900-4 Download Broken?
cmcclinton
Level 4
Level 4
Is anyone else having problems downloading the 6.1(5)SU3 update (UCSInstall_UCOS_6.1.5.13900-4.sgn.iso) ?
I have a tried a few times and the direct download link only downloads a file of a few hundred k, which isn't right.
The Java download never seems to work reliably for me and in this case only ever gets as far as 10%
C
malombar
Hi Colin,
There are two methods to download via the software download, Java and non Java assisted. If you haven't already tried, please try use the non-Java assisted. I've just tried downloading and already upto 18% of download (527MB of 2.8GB) which has another 2:20 to finish.
Cheers
Mario
you manage to get the iso? at this point I need the upgrade UCSInstall_UCOS_6.1.5.13900-4.sgn.iso
thaks
6.x images are no longer available to download from cisco.com, you'll need to reach out to your SE/AM for this.
java
if this helps, please rate
