01-08-2015 07:59 AM - edited 03-17-2019 01:31 AM
Hii,
I have 2 UCS with 1 PUB and 1 SUB and I want to put a second LAN connection to the physical server in order to have redundancy If the first LAN port is down. Any ideas about how to finis this setup or some information/how to about the config.
Pls see attachment
Thanks for support
Solved! Go to Solution.
02-25-2015 02:03 AM
CIMC is there for C-series UCS for iLO/remote console access and management:
Ref: http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/e/1-0/gs/guide/b_Getting_Started_Guide/b_Getting_Started_Guide_chapter_0101.html#topic_CD641EB5E8F4416A9C8AB250941F5338
The Cisco Integrated Management Controller (CIMC) is the management service for the E-Series Servers. CIMC runs within the server. You can use a web-based GUI or the SSH-based CLI to access, configure, administer, and monitor the server.
You can use CIMC to perform the following server management tasks:
01-08-2015 08:20 AM
Go to your vSwitch, click properties and add the vNIC you want.
This is really ESXi config, you probably want to look into their documentation.
EDIT: You probably want to have them both at the same speed, you have one at 1 GB and another at 100 mbps.
02-25-2015 01:33 AM
Hey Jaime,
Any tool from Cisco to manage the UCS C200 server settings ( management config ).
02-25-2015 02:03 AM
02-25-2015 03:20 AM
See below the document explaining the UCS C series setup etc. I realised by mistake referenced link for UCS E series but CIMC functionality is same.
http://www.cisco.com/c/en/us/support/docs/servers-unified-computing/ucs-c200-m1-high-density-rack-mount-server/111455-setup-cimc-c-series.html
https://www.youtube.com/watch?v=Tqq2xSIGJNY
-Terry
02-25-2015 04:10 AM
Not sure what you mean, besides the actual server config that you handle via CIMC, the rest is handled via ESXi.
