UCS 200 network configuration
gabiulici
Hii,
I have 2 UCS with 1 PUB and 1 SUB and I want to put a second LAN connection to the physical server in order to have redundancy If the first LAN port is down. Any ideas about how to finis this setup or some information/how to about the config.
Pls see attachment
Thanks for support
CIMC is there for C-series UCS for iLO/remote console access and  management:
Ref: http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/e/1-0/gs/guide/b_Getting_Started_Guide/b_Getting_Started_Guide_chapter_0101.html#topic_CD641EB5E8F4416A9C8AB250941F5338
CIMC Overview
The Cisco Integrated Management Controller (CIMC) is the management service for the E-Series Servers. CIMC runs within the server. You can use a web-based GUI or the SSH-based CLI to access, configure, administer, and monitor the server.
You can use CIMC to perform the following server management tasks:
  • Power on, power off, power cycle, reset and shut down the server
  • Configure the server boot order
  • Manage RAID levels
  • View server properties and sensors
  • Manage remote presence
  • Create and manage local user accounts, and enable remote user authentication through the Active Directory
  • Configure network-related settings, including NIC properties, IPv4, VLANs, and network security
  • Configure communication services, including HTTP, SSH, IPMI Over LAN, and SNMP
  • Manage certificates
  • Configure platform event filters
  • Update CIMC firmware
  • Update BIOS firmware
  • Install the host image from an internal repository
  • Monitor faults, alarms, and server status
  • Collect technical support data in the event of server failure
5 Replies 5
Jaime Valencia
Go to your vSwitch, click properties and add the vNIC you want.
This is really ESXi config, you probably want to look into their documentation.
EDIT: You probably want to have them both at the same speed, you have one at 1 GB and another at 100 mbps.
java
if this helps, please rate
Hey Jaime,
Any tool from Cisco to manage the UCS C200 server settings ( management config ).
CIMC Overview
See below the document explaining the UCS C series setup etc. I realised by mistake referenced link for UCS E series but CIMC functionality is same.
http://www.cisco.com/c/en/us/support/docs/servers-unified-computing/ucs-c200-m1-high-density-rack-mount-server/111455-setup-cimc-c-series.html
https://www.youtube.com/watch?v=Tqq2xSIGJNY
-Terry
Not sure what you mean, besides the actual server config that you handle via CIMC, the rest is handled via ESXi.
java
