04-07-2014 07:05 AM - edited 03-16-2019 10:23 PM
Does anyone know if (and when) UCS series (C220M3 in my case) will support VMWare Esxi 5.5 ? Currently our two server are running ESXi 5.0, but there's some limitations that would be removed with 5.5.
Thanks for your help
Fabian
Solved! Go to Solution.
04-07-2014 08:13 AM
Hi Fabian,
This will depend on the Applications you are running on the C220M3. The details are in the link below :)
http://docwiki.cisco.com/wiki/Unified_Communications_VMware_Requirements
Cheers!
Rob
04-07-2014 08:13 AM
Hi Fabian,
Cheers!
Rob
04-07-2014 08:22 AM
Thanks Rob, it helps !
Fabian
