UCS C240 M3S RAM upgrade in VM's
Bhavani Sankar
Hi All,
We are planning to upgrade CUCM from (10.5.2.12901-1 to 11.x). But memory configured is 6 GB which is not sufficient for 7500 users. Can we increase the RAM to 8GB by shutting down the VM's. Is it recommended to upgrade RAM manually?
Sankar.
2 Accepted Solutions
Manish Gogna
Hi Sankar,
It is supported, this information is also provided in the OVA read me files like below
http://www.cisco.com/web/software/283088407/51125/cucm_8.6_vmv7_v1.5.ova.README.txt
Upgrades from previous releases:
1) Stop the VM
2) Edit the VM
3) Modify the RAM, CPU, reservations, and OS based on the changes listed above.
4) Save the changes
5) Power back on the VM
Manish
Jaime Valencia
I'm guessing you have not reviewed the upgrade guide??? which covers all of what you're asking
Change Virtual Machine Configuration Specifications
Before an upgrade, you NEED to review:
A) Release Notes
B) Upgrade Guide
To get all of the necessary information, and requirement.
java
if this helps, please rate
Manish Gogna
Hi Sankar,
1) Stop the VM
2) Edit the VM
4) Save the changes
Manish
Hi Manish,
Thanks a ton for clearing my confusion. We have done the same.
Sankar.
Jaime Valencia
A) Release Notes
B) Upgrade Guide
java
