UCS servers and UC Applications
mrmhar1408
Level 4
Level 4
Hi all,
I have question in Design for the UCS servers with the Unified Applications, How I can distrbuite the Applications in the UCS.
Is there any calculator like the DSP calculator shows how many HDD, RAM and CPU if i will choose all the applications i want to install
Or if I have
UCS-C210M2-VCD2 How do I know how many applcation I can install on it ?
ronpatel
Level 8
Level 8
You  will have to use the OVA supplied by Cisco for that aplicaiton and its release. When you import OVA template it will create Virtunal machine which will be best for that Cisco application and for that release.
Ronak Patel
Rate helpful posts by clicking stars below the answer.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
I download the sizing tool but it's not working, it is opening excel sheet then close it immediately. How I can use it ?
If you are Cisco certified partner, you can open case at cisco.com/go/pdihelpdesk. Or else try to use online version of sizing tool.
regards
Ronak Patel
