UK PSTN International Ringback
DaveX4285_2
(SCCP) --> CUCM 8.5 <---(SIP TRUNK)---> 3825 <---(PSTN)PRI
Just brought up a new cluster in the UK and for all international calls I am receiving the same ring back no matter which country is dialed. All ringback is the UK ringback. If Germany is dialed we get UK ringback, Japan = UK ringback. User and Network locale are set to UK and the UK locale is loaded. Under the PRI interface cptone GB is configured. When this site was running CME we recieved the proper ringback depending on the country, but now moving to CUCM that has disappeared. Any help is appreciated.
20 Replies 20
ADAM CRISP
Level 4
Level 4
hello.
I thing there is a disable early media 180 ringing command under sip-ua , which stops the ringback unless no media is present...
Adam
I noticed this can be disabled on the SIP Profile on CUCM as well. Would this have the same effect?
Aa
I don't thing so. It's the router that terminates the isdn stack, so it is here the sip dialogue starts. I would imagine the setting on the cucm, is for inbound calls.
Thanks. Unfortunately adding this had no effect on the ringback. The relevant part of the configuration is below
dial-peer voice 5 pots
trunkgroup 1
description [ Outgoing ]
preference 2
destination-pattern .T
progress_ind alert enable 8
progress_ind connect enable 8
forward-digits all
voice-port 0/0/0:15
translation-profile incoming AA-DDI
no vad
cptone GB
timeouts interdigit 4
music-threshold -70
bearer-cap Speech
voice service voip
clid substitute name
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
redirect ip2ip
signaling forward unconditional
fax protocol pass-through g711ulaw
modem passthrough nse codec g711ulaw
sip
  bind control source-interface GigabitEthernet0/0
  bind media source-interface GigabitEthernet0/0
  transport switch udp tcp
  midcall-signaling passthru
Ok. That's interesting. I wonder what's present on the PRI ?
It might be worth gathering the output of debig ccsip messages and isdn q931 to see whether and when you receive alerting from isdn for UK calls / international and when you send the SIP ringing with sdp message
example:
Oct 18 09:23:56.252: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8  callref = 0x367E
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA9839D
                Exclusive, Channel 29
        Calling Party Number i = 0x2180, '1245'
                Plan:ISDN, Type:National
        Called Party Number i = 0x91, '44845123456'
                Plan:ISDN, Type:International
Oct 18 09:23:56.404: ISDN Se0/1/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0xB67E
few moments later
Oct 18 09:23:58.356: ISDN Se0/1/0:15 Q931: RX <- ALERTING pd = 8  callref = 0xB67E
        Progress Ind i = 0x8181 - Call not end-to-end ISDN, may have in-band info
I would expect the gw to send ONLY at this point the 180 with SDP. If this is sent before the progress indicator then it's the Cisco, after then it's possible the telco is sending you UK tones.
In an effort to be helpful, here's the config of our of our UK ISDN to SIP gateways. It's quite a bit simpler than yours.
We get GB ringback for UK and International via early media everywhere else
voice service voip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711alaw
voice-port 0/0/0:15
cptone GB
bearer-cap Speech
dial-peer voice 10 pots
description POTS talking dial peer for E1 #0
translation-profile outgoing voip-to-pstn
preference 3
destination-pattern .+
incoming called-number .+
direct-inward-dial
port 0/0/0:15
dial-peer voice 997 voip
description incoming voip
rtp payload-type cisco-codec-fax-ind 124
voice-class codec 1
session protocol sipv2
dtmf-relay cisco-rtp rtp-nte
fax-relay ecm disable
fax nsf 000000
fax protocol t38 ls-redundancy 5 hs-redundancy 2 fallback pass-through g711alaw
no vad
sip-ua
disable-early-media 180
set sip-status 480 pstn-cause 42
set sip-status 500 pstn-cause 42
set sip-status 503 pstn-cause 27
set pstn-cause 3 sip-status 503
set pstn-cause 17 sip-status 500
set pstn-cause 21 sip-status 603
max-forwards 20
sip-server dns:from-pstn.internal.voip.co.uk
Adam
Thanks again. Do you have any translations changing the plan and type of the calls by chance. Below is a q931  debug and Im sending ISDN and Unknown where as you are sending ISDN and International.
007131: Oct 18 22:59:41.115 bst: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0395
        Standard = CCITT
    Channel ID i = 0xA98381
        Exclusive, Channel 1
    Display i = 'Test'
    Calling Party Number i = 0x0181, '1007'
        Plan:ISDN, Type:Unknown
    Called Party Number i = 0x81, '0012489794774'
007132: Oct 18 22:59:41.403 bst: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x8395
007133: Oct 18 22:59:45.099 bst: ISDN Se0/0/0:15 Q931: RX <- PROGRESS pd = 8  callref = 0x8395
    Progress Ind i = 0x8381 - Call not end-to-end ISDN, may have in-band info
    Progress Ind i = 0x8482 - Destination address is non-ISDN
007134: Oct 18 22:59:47.883 bst: ISDN Se0/0/0:15 Q931: RX <- ALERTING pd = 8  callref = 0x8395
007135: Oct 18 22:59:50.135 bst: ISDN Se0/0/0:15 Q931: RX <- CONNECT pd = 8  callref = 0x8395
007136: Oct 18 22:59:50.139 bst: ISDN Se0/0/0:15 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x0395
UKMCH2VGW001#
UKMCH2VGW001#
Yes we do.
When you get a chance would you mind sending the translations?
Greatly appreciated.
Hi.
Not Got live access until tomorrow
But it's a normal voice translation rule followed by something like type any international plan any isdn
No problem. Thats what I created, and it changes the type to international but no difference in ringback.
ADAM CRISP
Level 4
Level 4
ok can you debug ccsip messages and isdn q931 at the same time?
Back tmrrw. Adam
Debug is attached.
Hi Dave.
You initial invite is offerless meaning that early media isn't going to work.
The 183 Session progress contains all the codecs the GW is configured with configures, but for sure the GW doesn't know where to send the media, or indeed what codec is
You need to get CM to send in invite with SDP. I *think* you can make this happen by making the SIP trunk use an MTP.
If the GW is part of your network I'd be inclined to try the following
1. On CM tick the box to use an MTP that is available in the SIP trunk's region.
re-test
2. If this fails or if you want to perfect your media flow, configure your GW router to be an MTP resource for CM and then make this MTP available for this SIP trunk only.
Interesting one!
Adam
Thanks Adam, I will look at making these changes after hours.
Regarding your 2nd remark. This is currently a single site Pilot deployment, would there be any benefits in configuring the MTP local on the gateway if its all at the same site. Obviously this would be preferred but at this point the gateway has limited DSP resources and I had been utilizing the CUCM's resources. I will make the change after hours and let you know the result.
