unable to call inside and outside
techguy
Level 4
Level 4
I have following stuff on my router and i am unable to dial in side and outside.
voice-port 0/0/0
trunk-group FXO
input gain -3
output attenuation -1
echo-cancel coverage 64
no comfort-noise
connection plar 2222
music-threshold -45
bearer-cap Speech
dial-peer voice 4 pots
description Mobile
destination-pattern 955......
fax rate disable
port 0/0/0
prefix 55
dial-peer voice 6000 voip
preference 1
destination-pattern 2...
voice-class codec 1
voice-class h323 1
session target ipv4:10.X.X.X
dtmf-relay h245-alphanumeric
req-qos guaranteed-delay audio
acc-qos guaranteed-delay audio
fax-relay ecm disable
fax rate 14400
fax nsf 000000
fax protocol pass-through g711ulaw
no vad
5 Replies 5
techguy
Level 4
Level 4
2811#debug voip dialpeer inout
.Aug 28 11:19:09.325: //-1/00B7899F0800/DPM/dpAssociateIncomingPeerCore:
   Calling Number=2222, Called Number=933192426, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=6000
2811#debug voip ccapi
voip ccapi default debugging is on
.Aug 28 11:21:32.648: //-1/80C8C5F40900/DPM/dpAssociateIncomingPeerCore:
   Calling Number=2222, Called Number=933192425, Voice-Interface=0x0,
.Aug 28 11:21:32.652: //-1/80C8C5F40900/DPM/dpAssociateIncomingPeerCore:
.Aug 28 11:21:32.652: //-1/80C8C5F40900/CCAPI/cc_api_create_cc_entry_common:
   Interface=0x490A7A48, Call Id=116,
   Call Info=2222(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=933192425(TON=Unknown, NPI=Unknown),
   FinalDestinationFlag=TRUE, Incoming Dial-peer=6000
.Aug 28 11:21:32.652: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
.Aug 28 11:21:32.652: :cc_get_feature_vsa malloc success
.Aug 28 11:21:32.652:  cc_get_feature_vsa count is 1
.Aug 28 11:21:32.652: :FEATURE_VSA attributes are: feature_name:0,feature_time:1245094968,feature_id:110
.Aug 28 11:21:32.660: //116/80C8C5F40900/CCAPI/cc_api_delete_cc_entry:
   Interface=0x490A7A48, Disposition=0x0, Tag=0x0, Call Id=116
.Aug 28 11:21:32.660: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
.Aug 28 11:21:32.660: :cc_free_feature_vsa freeing 4A36A430
.Aug 28 11:21:32.660:  vsacount in free is 0
Marwan ALshawi
in the FXO can you change the connection plar with the bellow command and try incoming call
connection plar-opx 2222
i am assuming there us an extension 2222 configured in the other end of the voip dial-peer
Nothing happened.
For inbound call, its ringing but i dont where call is going.
For outbound call, immediately it gives me busy tone.
Adrian Saavedra
Level 7
Level 7
If you see the output of the debug, you have ANI (calling number) = 2222 and DNIS (called number) = 933192426. Also, you're matching incoming dial-peer 6000. Dialpeer 6000 is VoIP, then I it seems that you're dialing from your IP phone to the PSTN. You have an outbound POTS dialpeer with destination pattern 955...... and isn't matching with your DNIS. Could you please reconfigure the destination pattern of dialpeer 4 to something like 933...... and see what happens?
Hope it helps, please rate if it does.
Kind regards,
- Adrian.
if i call 955123456 nmuber...something wud happen. Bcoz i have many dial-peer including 933......
I have doubt that Disposition=0x0 is creating problem ?
