Beginner
Unable to Call Numbers in the UK that have 01 after the area code
Hi, I have a customer that uses Route Filters and the GB dial plan. BT have introduced numbers that have a 01 after the area code, for example, 01274 01XXXX. The end user has CUCM version 9.1.2.
I am hoping that the latest GB numbering Dial Plan will include this but I don't want to advise the customer unless this is the case. How do I check?
10 REPLIES 10
VIP Collaborator
Re: Unable to Call Numbers in the UK that have 01 after the area code
@Ayodeji Okanlawon
You were on that major thread about the GB numbering plan a few years back. Can you answer this question?
If you have a UCM in your lab, that would be a quick way to install the NP and test. If this is something that BT has introduced recently than not sure if that would be included on the NP as of yet. If that is the case, you would need to get a PER going through your Accounts team.
Nipun Singh Raghav
"We cannot solve our problems with the same thinking we used when we created them"
Beginner
Hi Nipun,
thanks for your reply. Offcom implemented the change from 1st October 2014. I think I will follow your suggestion and lab it up.
Thanks, John.
VIP Mentor
Hi, you can just look at the flat file of the IDP on cisco.com to see the patterns that are there.
The latest one is dp-ffr.3-1-35.GB. I have looked at the flat file and there is no 01274. There is 01276 in it.I have attached the flat file for you,s o you can have a look through it.
Please rate all useful posts
Highlighted
Beginner
Hi Ayodeji,
many thanks, I did look at the flat file but could not see the addition so perhaps I will lab for ver 9, add the DP and test out to a gateway.
Thanks, John.
VIP Mentor
Yes in that case your best option is just to add a manual pattern and send it out your gateway. Its that simple.
Beginner
Hi Ayodeji,
I did add a manual pattern but there are other towns in the UK that have had the area prefix changed so best to use the Dial Plan.
Many thanks for your responses and help.
Cheers, John.
VIP Mentor
@johnsnave1 wrote:
Hi Ayodeji,
Cheers, John.
There is no point "labbing" this up. The IDP doesn't contain the pattern. What you have in the flat file is what you have in the cop file. There is no other way to route calls for these new numbers without manually defining the pattern. You should just use 0127XXXXXXXX. Are you suggesting that there are multiple of these you need to add?
Beginner
thanks. Yes, there a 4 other patterns to add. Not a problem though as I will add all 5 explicit route patterns and hope that Cisco catch up with the UK Dial Plan one day soon.
Thanks, John.
Beginner
Hi Ayodeji,
would this (from the latest IDP) not do it?
# 0+1[2-9][02-9]X+XXXXXX
P: 0 NATIONAL-ACCESS
P: 1[2-9][02-9]X AREA-CODE
P: XXXXXX SUBSCRIBER
T: N
C: LONGDISTANCE
E: +,[COUNTRY-CODE],AREA-CODE,SUBSCRIBER
F: NATIONAL-ACCESS,AREA-CODE,SUBSCRIBER
S: Y
0 1 2 7 4 01XXXX
Content for Community-Ad
August's Community Spotlight Awards
