Unable to configure Algo 8081G to Cisco CME 10.5
Hi Gents,
Currently im having issues to register  Algo 8081G SIP Audio Alerter to Cisco CME 10.5
Seems like at Algo GUI, both extension (810) & (811) already successfully registered in the CME. However when I tried to do the test call from other ext to both Algo number, it just replied with dead tones.
I've share the snippet of the config as follow and debug log 
voice register global
mode cme
source-address 10.203.30.248 port 2000
timeouts interdigit 4
max-dn 100
max-pool 100
load 3911 SIP3951.8-0-2-9
authenticate register
timezone 42
time-format 24
date-format D/M/Y
call-forward system redirecting-expanded
tftp-path flash:
create profile sync 0281468568161315
voice register dn 2
number 811
name Algo8081G
preference 1
label 811
voice register dn 3
number 810
name Algo-Pager
preference 1
label 810
voice register pool 2
voice register pool 5
id device-id-name 811
number 1 dn 2
dtmf-relay sip-notify
username 811 password cisco
voice register pool 7
id device-id-name 810
number 1 dn 3
username 810 password cisco
*voice Register all result*
ADOLUCM01#sho voice register all
VOICE REGISTER GLOBAL
CONFIG [Version=10.5]
Version 10.5
Mode is cme
Max-pool is 100
Max-dn is 100
Outbound-proxy is enabled and will use global configured value
Security Policy: DEVICE-DEFAULT
Forced Authorization Code Refer is enabled
Source-address is 10.203.30.248 port 2000
Load 3911 is SIP3951.8-0-2-9
Authenticate register
Time-format is 24
Date-format is D/M/Y
Time-zone is 42
Hold-alert is disabled
Mwi stutter is disabled
Mwi registration for full E.164 is disabled
Forwarding local is enabled
Video is disabled
Camera is disabled
Privacy is enabled
Privacy-on-hold is disabled
Conference hardware is disabled
Dst auto adjust is enabled
start at Apr week 1 day Sun time 02:00
stop at Oct week 8 day Sun time 02:00
Call List BLF is enabled
Max redirect number is 5
IP QoS DSCP:
ef (the MS 6 bits, 46, in ToS, 0xB8) for media
cs3 (the MS 6 bits, 24, in ToS, 0x60) for signal
af41 (the MS 6 bits, 34, in ToS, 0x88) for video
default (the MS 6 bits, 0, in ToS, 0x0) for service
Telnet Level: 0
Tftp path is flash:/its
Generate text file is disabled
Tftp files are created, current syncinfo 0281468568161315
OS79XX.TXT is not created
timeout interdigit 4
network-locale[0] US (This is the default network locale for this box)
network-locale[1] US
network-locale[2] US
network-locale[3] US
network-locale[4] US
user-locale[0] US (This is the default user locale for this box)
user-locale[1] US
user-locale[2] US
user-locale[3] US
user-locale[4] US
MWI unsolicited notify is disabled
Active registrations : 3
Total SIP phones registered: 3
Total Registration Statistics
Registration requests : 208
Registration success : 16
Registration failed : 192
unRegister requests : 11
unRegister success : 11
unRegister failed : 0
Attempts to register
after last unregister : 0
Last register request time : *10:29:52.556 UTC Fri Dec 25 2020
Last unregister request time : *10:37:13.504 UTC Fri Dec 25 2020
Register success time : *10:29:52.556 UTC Fri Dec 25 2020
Unregister success time : *10:37:13.504 UTC Fri Dec 25 2020
VOICE REGISTER DN
Dn Tag 2
Config:
Number is 811
Preference is 1
Huntstop is disabled
Name Algo8081G
Auto answer is disabled
Label is 811
Pool 5 has this DN configured for line 1
Dn Tag 3
Config:
Number is 810
Preference is 1
Name Algo-Pager
Label is 810
Pool 7 has this DN configured for line 1
VOICE REGISTER TEMPLATE
VOICE REGISTER DIALPLAN
VOICE REGISTER POOL
Pool Tag 2
Nothing configured yet
Pool Tag 5
Config:
Device ID Name is 811
Number list 1 : DN 2
Proxy Ip address is 0.0.0.0
Current Phone load version is Algo-8180G2/1.7.6
DTMF Relay is enabled, sip-notify
Call Waiting is enabled
DnD is disabled
Video is disabled
Camera is disabled
Busy trigger per button value is 0
keep-conference is enabled
registration expires timer max is 600 and min is 60
Lpcor Type is none
Transport type is udp
service-control mechanism is not supported
registration Call ID is 7a5e7aca333a95f6
Registration method: per line
Privacy feature is not configured.
Privacy button is disabled
active primary line is: 811
contact IP address: 10.203.30.83 port 5060
conference admin: no
conference add mode: all
conference drop mode: never
paging-dn: config 0 [multicas
