03-31-2020 03:05 AM
Hi Everyone,
When I connect my IP phone 8841 directly to cable modem (Motorola), the Phone get registered in CUCM. but when I connect the IP Phone with WRT54G2 in between, the Cisco IP phone does not get registered in CUCM.
It says "verify your service domain and internet connectivity".
I already did a lot of changes in the Linksys router but the same issue, can some one can help me with this issue ?
Thanks in advance,
Orellana
03-31-2020 06:55 AM
Review a PRT from the device and logs from EXP-E, but that most usually means either ports are blocked or maybe something like SIP ALG is causing some issue.
04-01-2020 09:09 AM
Sip Alg is enable in the firewall that is in the front of the exp-e.
but why the phone gets registered when I plug it in the home modem?
and then when I connect the CiscoLinksys WRT54G2 to the modem and connect the phone to the CiscoLinksys WRT54G2 the registration doesn't get completed ?
That CiscoLinksys does not have to many options to play with, talking about option to grant full open port for testing purpose.
Thanks for responding,
Orellanas
