Unable to Create Backup device on CUCM 8.6 DRS
shabeer mohamed
Download filezilla or another SFTP client, and verify you can connect to the SFTP server from your PC.
If you can't, you'll need to look at the logs on the SFTP server to see what the problem is.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
7 Replies 7
Aman Soi
Seems to be a connectivity issue with SFTP server. Check the credentials and sftp service is running .
which sftp u are using?
regds,
aman
Solar Winds STFP
Can u try using freeftpd sftp and check if problem is related to sftp or network path?
Aaron
Problem Solved... Its SFTP Connectivity Problem.
thanks for update.
regds,
aman
Thanks for updating.
Please remember to rate useful replies, and mark the question 'answered' when  appropriate.
Aaron
