Unable to Dial Long Distance numbers fromCIPC(SCCP) Deskphone(SIP)work
chaitusite
Unable to dial some numbers from CIPC (SCCP) phone, but Desk Phone(SIP) calls are working with Same CSS and Device pool.
CUCM Version:11.5.1.13901-3,
call flow:
CIPC(SCCP)--->CUCM--->Gateway(H.323)--->PSTN(PRI)--->Notworking
Desk Phone(SIP)--->CUCM--->Gateway(H.323)--->PSTN(PRI)--->Working
Krishna
24 Replies 24
Hi Nithin,
Please find the configuration for dial-peers below.
dial-peer voice 22 voip
description to CUCMPub
preference 2
destination-pattern 4...
session target ipv4:10.60.1.35
voice-class codec 1
dtmf-relay h245-alphanumeric h245-signal cisco-rtp
no vad
dial-peer voice 23 voip
description to CUCMSub
preference 1
session target ipv4:10.60.1.36
voice-class codec 1
no vad
dial-peer voice 10 pots
description OUTGOING
preference 9
destination-pattern [0-9]T
port 0/1/0:1
forward-digits all
Taking your dial-peer config, it covers the findings about your the call logs.
Since your called number begins with 4, it will use the CUCM dial-peers as outgoing dial-peers first.
Maybe you should re-configure your dial-plan, something like this:
Assuming, that you send all called numbers from CUCM to the GW starting with 9.
dial-peer voice 20 voip
description ### from CUCM ###
incoming called-number 9
voice-class codec 1
no vad
huntstop
description ### to CUCMPub ###
preference 2
voice-class codec 1
no vad
huntstop
description ### to CUCMSub ###
preference 1
voice-class codec 1
no vad
description ### From PSTN ###
incoming called-number 4 --> Put here your number range
direct-inward-dial
huntstop
description ### To PSTN ###
destination-pattern 9
port 0/1/0:1
huntstop
Absolutely sound advice, but I would suggest the following alterations to your configuration suggestion.
 description ### Incoming from CUCM ###
 incoming called-number .
 voice-class codec 1
 no vad
 description ### Outgoing to CUCMPub ###
 preference 2
 destination-pattern 4...$
 voice-class codec 1
 no vad
 huntstop
 description ### Outgoing to CUCMSub ###
 preference 1
 voice-class codec 1
 no vad
dial-peer voice 1 pots
 description ### Incoming from PSTN ###
 tone ringback alert-no-PI
 direct-inward-dial
 description ### Outgoing to PSTN ###
 destination-pattern 9T
 progress_ind setup enable 3
 progress_ind alert enable 8
 progress_ind progress enable 8
 progress_ind connect enable 8
 progress_ind disconnect enable 8
 port 0/1/0:1
 huntstop
@chaitusite Based on the shared configuration and debugs it looks like you have a loop in your call setup and this is caused by that you have overlaps between the match on your dial peers. This is not a good state to have. As advised by @b.winter suggest that you alter the way you send calls from CM to your VGW and how your match the calls outbound to PSTN. If you use a break out code, for example 9, the easist is to keep that in the called number as the call is passed from CM to the gateway. Then in the gateway you use this to match the call going to PSTN and consume that on it's way out to the service provider. There are many ways to achieve this, the simplest is to let the default function of POTS dial peers to consume any explicitly matched digits to be stripped. If you don't want that or have other needs for how to modify the called number you can do this with voice translation rules. Let us know you preference and we can lend you a hand with that part as well.
Response Signature
Please find the GW configuration.
version 15.5
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone year
service timestamps log datetime msec localtime show-timezone year
service password-encryption
service sequence-numbers
no platform punt-keepalive disable-kernel-core
hostname RTR
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
card type e1 0 1
logging count
logging buffered 500000
no logging console
aaa session-id common
clock timezone CST -6 0
clock summer-time CDT recurring
no ip domain lookup
XXXX.com
subscriber templating
isdn switch-type primary-net5
voice call send-alert
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
codec preference 4 g729br8
voice class h323 1
h225 timeout tcp establish 3
call start slow
voice translation-rule 200
rule 1 reject /87879/
voice translation-profile REJECT-CALLS
translate calling 200
voice-card 0/1
no watchdog
voice-card 0/2
no watchdog
license udi pid ISR4351/K9
license boot level appxk9 disable
license boot level uck9
license boot level securityk9 disable
username
redundancy
mode none
controller E1 0/1/0
framing no-crc4
clock source line primary
ds0-group 1 timeslots 1-15,17-31 type r2-digital r2-compelled ani
cas-custom 1
country telmex
category 2
answer-signal group-b 1
caller-digits 4
groupa-callerid-end
vlan internal allocation policy ascending
interface GigabitEthernet0/0/0
ip address 10.X.X.XX 255.255.X.X
negotiation auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.X.X.X
interface GigabitEthernet0/0/1
no ip address
negotiation auto
interface GigabitEthernet0/0/2
no ip address
negotiation auto
interface Service-Engine0/1/0
interface Service-Engine0/2/0
vrf forwarding Mgmt-intf
no ip address
negotiation auto
interface Vlan1
no ip address
shutdown
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.X.X.X
ip ssh version 2
logging trap debugging
control-plane
voice-port 0/1/0:1
voice-port 0/2/0
timing hookflash-out 500
timing guard-out 1000
voice-port 0/2/1
pre-dial-delay 2
voice-port 0/2/2
voice-port 0/2/3
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp bind control source-interface GigabitEthernet0/0/0
mgcp bind media source-interface GigabitEthernet0/0/0
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
sccp local GigabitEthernet0/0/0
sccp ccm 10.6.X.X identifier 38 priority 2 version 4.1
sccp ccm 10.6.X.X identifier 37 priority 1 version 4.1
sccp
no ccm-manager fax protocol cisco
call-block translation-profile incoming REJECT-CALLS
direct-inward-dial
preference 9
port 0/1/0:1
forward-digits all
preference 2
destination-pattern 3...
session target ipv4:10.6.X.X
voice-class codec 1
no vad
dial-peer voice 21 voip
preference 1
voice-class codec 1
no vad
preference 2
voice-class codec 1
no vad
preference 1
voice-class codec 1
no vad
dial-peer voice 24 voip
preference 2
destination-pattern 6...
voice-class codec 1
no vad
dial-peer voice 25 voip
preference 1
voice-class codec 1
no vad
dial-peer voice 11 voip
incoming called-number 9T
voice-class codec 1
no vad
dial-peer voice 12 pots
destination-pattern 350
port 0/2/3
dial-peer voice 9 pots
description OUTGOING Emergency
destination-pattern 9911$
port 0/1/0:1
forward-digits 3
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
transport input ssh
network-clock input-source 1 controller E1 0/1/0
end
AFAIKT none of the suggested changes has been implemented. What is you intent with posting your configuration?
Response Signature
Hi Sir,
Sorry i have not checked your post, i missed to post the complete  configuration before.
Based on your complete shared configuration I would suggest that you make these changes.
voice service voip
 no allow-connections h323 to h323
 no allow-connections h323 to sip
 no allow-connections sip to h323
 no allow-connections sip to sip
voice translation-rule 1
 rule 1 /^9\(.*\)/ /\1/
voice translation-profile PSTN-OUT
 translate called 1
voice-port 0/1/0:1
 translation-profile outgoing PSTN-OUT
 direct-inward-dial
 port 0/1/0:1
 huntstop
 forward-digits all
 preference 2
 destination-pattern [346]...$
 voice-class codec 1
 huntstop
 no vad
 preference 1
 voice-class codec 1
 no vad
voice-class codec 1
no vad
! no dial-peer voice 22 voip no dial-peer voice 23 voip no dial-peer voice 24 voip no dial-peer voice 25 voip
Response Signature
Hi Sir,
If we give
voice service voip
i think  Gateway will not be able to Communicate with CUCM for sending the calls back.
No, those are for if the gateway should act as a Session Border Controller (SBC), or CUBE as Cisco calls it. What these commands do is to enable the gateway to handle VoIP to VoIP call legs, aka two voip dial peers in the call flow. Meaning that you have one voip dial peer match inbound and another, or the same depending on configuration, matched in the outbound direction.
What you have is a traditional TDM (Time Division Multiplex) gateway, meaning that it handles POTS to VoIP, and the reverse, call legs. This is what you have as you have one pots or voip dial peer match inbound, depending if the call comes from PSTN or CM, and then a voip or pots dial peer matched outbound, depending if the call is destined to CM or PSTN. For this none of these commands are needed.
Response Signature
As @Roger Kallberg mentioned, use $ at the end of the destination pattern. Instead of 6 dial peer you can achieve the same with two dial-peer.
use [346]...$
Response Signature
