12-03-2015 10:04 PM - edited 03-17-2019 05:07 AM
Hi Guys
I have been trying to install CUCM10.5.2 on vmware workstation 11 on pc for lab. I have been getting the same error.(image attached)
I have tried using the ova template from cisco, but still failed.
Anything I am missing ?
Solved! Go to Solution.
12-03-2015 10:54 PM
Hi Krishna,
Have you verified MD5 checksum of the ISO file ?
Rajan
12-04-2015 10:46 AM
Krishna,
Try using the link below for help:
http://vonclawson.blogspot.in/2015/04/cucm-1052-install-on-vmware-workstation.html
Ronak Agarwal
12-03-2015 10:54 PM
Hi Krishna,
Rajan
12-03-2015 11:11 PM
Hi Rajan
Thank your for the response.
The iso I downloaded from cisco was not Bootable. I converted the iso to Bootable I think that might change the hash value.
I should compare hash before converting to Bootable?
12-03-2015 11:37 PM
the checksum value was for the downloaded file. So yes, pls check it before converting to bootable image.
12-04-2015 12:25 AM
Hi Rajan
I just verified the hash. It is correct.
12-11-2015 09:55 PM
The iso was on a remote drive . Copied it to a local drive and tried worked fine.
Thanks guys!
12-04-2015 10:46 AM
Krishna,
Ronak Agarwal
