Unable to install Unity Connection 8.6 on UCS VM
cristian.munoz
Enthusiast
Enthusiast
Hi Guys
I have a problem when I try to install the Unity Connection on UCS VM using OVA CUC_8.6.2_vmv7_v1.5.ova
  , the console show me the follow message:
Operating System not found
I´ve trying to setup BIOS (changing the boot order), to use a CUCM OVA for 2500 users, etc., but the problem still continue.
Any idea?
Cristian
Jaime Valencia
if you've already loaded the ISO (anyway you want it), just hit enter and it will start the install
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
