Unable to login Call Manager Web interface
I have a production CUCM cluster. 1 Publisher and 6 subscribers. I have created a new user ID and provided all the rules and group. I am able to login Publisher but with the same credentials unable to login Subscribers web interface. DB replication is fine between clusters.
It shows invalid user id/ password while logging into subscriber.
CUCM version - 10.5.2
Navaneeth
16 Replies 16
Jitender Bhandari
when you login to SUB what do you get blank page \ error. are you not able to login to all SUB or a specific.
JB
Hi Jitender,
CUCM page is getting loaded and able to provide User ID and Password but after providing that i am getting the below error. Its happening for all subscriber.
"Log On Failed - Invalid User ID or Password"
Navaneeth
Hi Navaneeth,
This User ID you have created is it Application user or end user.
JB
Jitender,
I have created in End user.
Navaneeth
Go to the CLI for PUB and one SUB run the below SQL command and past the output here
run sql select * from enduser where userid = 'REPLACE-WITH-USER-ID'
JB
Hi Jitender,
Please find the attached image of publisher and subscriber query.
Navaneeth
Navaneeth,
enduser table has not returned anything are you sure you created end user.
JB
Hi Jitender,
It was an ldap sync actually. Please find the image attached.
Hi Jitender,
Please find the updated query. I have typed in lower case before might be that is the reason its not pulled out in query.
Navaneeth,
as it is LDAP sync the authentication is happening against AD, so you need to try and log again and collect
  1. Tomcat security
  2. PCAP from PUB
For both PUB and SUB login and spot the difference.
JB
Hi Jitender,
I have configured the Enduser Manually and able to login all subscribers successfully. Might be I am unable to login previously due to issue with LDAP.
Thank you so much for your thoughts.
Navaneeth
Hi Navaneeth,
Happy to help, but i would still recommend stick to application user as it sounds more logical.
If you dont have further question dont forget to rate.
JB
Hi Navaneeth,
it should still show in that SQL command, if this is production or you dont have a lot of enduser run below
and see if you are able to spot the user.
JB
Jitender,
While executed the query "run sql select * from enduser" able to see the User id MXX6147 in both publisher and subscriber.
regards,
Navaneeth
