Unable to make a SIP trunk work.
                   I just set up a two 7940 SIP phones. Ive been trying for days to receive/send calls with no luck.I am using a CISCO 1760 router and I have installed a 4.3 CME version. I configured the phones according to many of the postings and I came to the conclusion that my problem is the way I configured the  phones on the router. I know by fact that the phones have access to URL services, and they can send and receive call whithsin my local network. . Please, can anybody point me on the right direction?. Thanks.
Building configuration...
Current configuration : 4825 bytes
! Last configuration change at 14:51:12 CA1_DST Tue Jul 24 2012
! NVRAM config last updated at 14:44:54 CA1_DST Tue Jul 24 2012
version 12.4
hostname VOICE
boot-start-marker
boot-end-marker
no aaa new-model
clock timezone EST -5
clock summer-time CA1_DST recurring
crypto pki trustpoint TP-self-signed-990320880
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-990320880
revocation-check none
rsakeypair TP-self-signed-990320880
crypto pki certificate chain TP-self-signed-990320880
certificate self-signed 01
  9F53E051 E687F356 AFC69E0A 34521D8D 29046BC6 47CE3C3E 54E698F1
6E0B7166
  DBA9FB31 B2AC424F 572A4081 0248862E 689A3611 E853C8B6 AAA74852
AFFA514A
  431EF188 75EEFA87 2C394197 AB99B453 D31E4349 803D1383 6B2B84F1 2002A8
        quit
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.18.1 192.168.18.200
ip dhcp pool VOICE_SCOPE
   network 192.168.18.0 255.255.255.0
   default-router 192.168.18.200
   option 150 ip 192.168.18.200
   dns-server 4.2.2.2
ip name-server 192.168.13.2
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
sip
  registrar server expires max 600 min 60
voice register global
mode cme
source-address 192.168.18.200 port 5060
max-dn 144
max-pool 24
load 7960-7940 P0S3-08-6-00
timezone 13
url service http://phone-xml.berbee.com/cgi-bin/weather.pl
file text
create profile sync 000124025500339A
ntp-server 134.214.100.6 mode unicast
voice register dn  1
number 7001
name Ubuntu
label Core7
voice register dn  2
number 7005
name ccna
label IPccna
voice register dialplan  1
type 7940-7960-others
pattern 1 7
voice register pool  1
id mac 0013.1A6C.XXXX
type 7940
number 1 dn 1
dtmf-relay rtp-nte sip-notify
codec g711ulaw
voice register pool  2
id mac 000B.5F80.XXXX
type 7940
number 1 dn 2
username 561623XXXX
username username privilege 15 secret 5 $1$W2PC$WHkf.nvnA6SLMAaZsxwSl0
archive
log config
  hidekeys
interface Loopback0
ip address 192.168.254.254 255.255.255.255
interface FastEthernet0/0
ip address 192.168.18.200 255.255.255.0
speed auto
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.18.1
ip http server
ip http authentication local
ip http secure-server
ip http path flash:/gui
tftp-server flash:/phone/7940-7960/P0S3-08-6-00.loads alias
P0S3-08-6-00.loads
tftp-server flash:/phone/7940-7960/P0S3-08-6-00.sb2 alias
P0S3-08-6-00.sb2
tftp-server flash:/phone/7940-7960/P003-08-6-00.bin alias
P003-08-6-00.bin
tftp-server flash:/phone/7940-7960/P003-08-6-00.sbn alias
P003-08-6-00.sbn
control-plane
dial-peer voice 13 voip
preference 1
session protocol sipv2
session target sip-server
incoming called-number 561623XXXX
dtmf-relay rtp-nte
codec g711ulaw
line con 0
password password
login
line aux 0
line vty 0 4
password cisco
login
line vty 5 15
password cisco
login
ntp clock-period 17179988
ntp server 134.214.100.6
end
15 Replies 15
Chris Deren
So, where is your sip-ua configuration since you are pointing your dial-peer to sip-server?
Who is your SIP provider?
What is not working? Inbound calls, outbound, both?
Can you post "debug ccsip messages" for one of the calls?
Chris
I havent configured the sip-ua part yet. My SIP provider is IPComms. No inbound/outbound calls at all. The ccsip messagges didnt show anything at all. Thanks
You need to configure the sip-ua.
And the dial-peers ofr inbound and outbound calls!
Verify some key points with the ITSP:
• Verify the supported codecs
• Verify the digits format that you need to send and receive
• This SIP Trunk need authentications?
• IP address of the SIP Servers
• DTMF mode Supported
• Support early or dealyed offer?
Follow a config example:
voice service voip
sip
  bind control source-interface
  bind media source-interface
  error-passthru
  no update-callerid
  early-offer forced
  midcall-signaling passthru
sip-ua
retry invite 2
retry register 10
timers connect 100
sip-server ipv4::5060
dial-peer voice 16 voip
description -------------[DDI]
translation-profile outgoing PSTNAccess
destination-pattern 000.T
modem passthrough nse codec g711alaw
session target ipv4:
voice-class codec 1
dtmf-relay rtp-nte
fax-relay ecm disable
fax rate disable
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711alaw
icpif 50
no vad
Note that this example i dont use authentication and early-offer, and confirm the informations with the ITSP. Other thing i have an SIP Trunk with this gateway this why i only have allow connections sip to sip. If you are using H.233 gateway you need the allow connection sip to h323, h323 to sip.
Leonardo Santana
Leonardo Santana
*** Rate All Helpful Responses***
I am going to check the settings and make the proper changes. Thanks
Use this documentation too, is very good!
Cisco CallManager Express (CME) SIP Trunking Configuration Example
http://www.cisco.com/en/US/products/sw/voicesw/ps462/products_configuration_example09186a00808f9666.shtml#codecs
Leonardo Santana
Leonardo Santana
Thanks everyone for your replies. I configured theSIP  AU and the incoming/outgoing Dial peer.
I am not still receiving calls and now I cannot able to receive calls inside my network. Far below, I added part of a deabug portion when trying to generate calls. Since I am missing the translation rules, could this be part of the problem ? ThanksPlease let me know.
By the way, the link you provided is down. I used this one instead: http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_configuration_example09186a00808f9666.shtml
VOICE#show run
Current configuration : 5966 bytes
! Last configuration change at 19:58:47 CA1_DST Tue Jul 24 2012
! NVRAM config last updated at 19:10:41 CA1_DST Tue Jul 24 2012
version 12.4
hostname VOICE
boot-start-marker
boot-end-marker
no aaa new-model
  3082023B 308201A4 A0030201 02020101 300D0609 2A864886 F70D0101         quit
ip cef
   dns-server 4.2.2.2
voice service voip
sip
voice class codec 1
codec preference 1 g711ulaw
mode cme
max-dn 144
max-pool 24
timezone 13
file text
create profile sync 0001240255003394
voice register dn  1
number 5616236333
name Ubuntu
label Core7
voice register dn  2
number 7005
name ccna
label IPccna
pattern 1 7
id mac 0013.1A6C.3693
type 7940
number 1 dn 1
codec g711ulaw
id mac 000B.5F80.0479
type 7940
number 1 dn 2
username 5616236333
archive
log config
  hidekeys
interface Loopback0
speed auto
ip http server
tftp-server flash:/phone/7940-7960/P0S3-08-6-00.loads alias P0S3-08-6-00.loads
tftp-server flash:/phone/7940-7960/P0S3-08-6-00.sb2 alias P0S3-08-6-00.sb2
tftp-server flash:/phone/7940-7960/P003-08-6-00.bin alias P003-08-6-00.bin
tftp-server flash:/phone/7940-7960/P003-08-6-00.sbn alias P003-08-6-00.sbn
control-plane
description **Incoming Call from SIP Trunk**
translation-profile incoming CUE_Voicemail/Autoattendant
preference 1
modem passthrough nse codec g711ulaw
voice-class codec 1
incoming called-number .%
dtmf-relay rtp-nte
fax rate disable
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
icpif 50
no vad
dial-peer voice 2 voip
description **Outgoing Call to SIP Trunk**
translation-profile outgoing PSTN_Outgoing
destination-pattern 9........
voice-class codec 1
voice-class sip dtmf-relay force rtp-nte
dtmf-relay rtp-nte
no vad
sip-ua
authentication username 5616236333 password 7 025F510C525158701E1D5E
no remote-party-id
retry invite 2
retry register 10
timers connect 100
registrar ipv4:64.154.41.150 expires 3600
sip-server dns:sipconnect.ipcomms.net
  host-registrar
telephony-service
max-ephones 24
max-dn 48
ip source-address 192.168.18.200 port 2000
system message URL
url services http://phone-xml.berbee.com/cgi-bin/weather.pl
dialplan-pattern 1 56162363.. extension-length 3 extension-pattern 2.. no-reg
voicemail 600
max-conferences 4 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
web admin system name voice secret 5 $1$g0TF$UKhdG0xKxqdw7CDpqzCiI/
dn-webedit
transfer-system full-consult
ephone-dn  1
number 333 secondary 5616236333 no-reg both
description ***Good Life***
name Latitude
ephone  1
mac-address 000B.5F80.0479
ephone  2
mac-address 0013.1A6C.3693
line con 0
password password
login
line aux 0
line vty 0 4
password cisco
login
line vty 5 15
password cisco
login
ntp clock-period 17180019
end
  88888888888888888888888888888888888888888888888888888888888888888888888888888888
VOICE#debug ccsip all
This may severely impact system performance. Continue? [confirm]yAll SIP
Call tr
acing is enabled
VOICE#
Jul 24 23:49:26.594: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAddContextToTable:
Added c
ontext(0x852C7DA0) with key=[29] to table
//-1/000000000000/SIP/Info/sipSPIGetOutboundHostAndDestHost
: CCSIP: target_host : 64.154.41.150 target_port : 5060
//-1/000000000000/SIP/Info/sipSPIValidateAndCopyOutboundHos
t: CCSIP: copy target_host to outbound_host
Jul 24 23:49:26.594: //-1/000000000000/SIP/State/sipSPIChangeState:
0x852C7DA0 :
State change from (STATE_NONE, SUBSTATE_NONE)  to (STATE_IDLE,
SUBSTATE_NONE)
//-1/000000000000/SIP/Info/ccsip_spi_registrar_add_expires_
header: Inside ccsip_spi_registrar_add_expires_header for Expires
Jul 24 23:49:26.598: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued
event f
rom SIP SPI : SIPSPI_EV_OUTBOUND_REGISTER
//-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event
: ccsip_spi_get_msg_type returned: 3 for event 40
//-1/000000000000/SIP/Info/act_idle_outgoing_register: In a
//23/000000000000/SIP/Info/act_idle_outgoing_register:  Sen
d REGISTER to 64.154.41.150:5060
Jul 24 23:49:26.598: //23/000000000000/SIP/Info/sipSPIUaddCcbToUACTable:
****Add
ing to UAC table.
Jul 24 23:49:26.598: //23/000000000000/SIP/Info/sipSPIUaddCcbToTable:
Added to t
able. ccb=0x852C7DA0 key=C629EB93-D51F11E1-8014DE03-81F92794
Jul 24 23:49:26.598: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader:
Converting
TimeZone CA1_DST to SIP default timezone = GMT
Jul 24 23:49:26.602: //23/000000000000/SIP/Info/sipSPISendRegister:
Associated c
ontainer=0x85A93914 to Register
Jul 24 23:49:26.602: //23/000000000000/SIP/Transport/sipSPISendRegister:
Sending
REGISTER to the transport layer
//23/000000000000/SIP/Transport/sipSPIGetSwitchTransportFla
g: Return the Dial peer configuration, Switch Transport is FALSE
Jul 24 23:49:26.606:
//23/000000000000/SIP/Transport/sipSPITransportSendMessage:
msg=0x850B5EF4, addr=64.154.41.150, port=5060, sentBy_port=0, is_req=1,
transpo
rt=1, switch=0, callBack=0x80E02208
Proceedable for sending msg immediately
//23/000000000000/SIP/Transport/sipTransportLogicSendMsg: s
witch transport is 0
//23/000000000000/SIP/Transport/sipTransportLogicSendMsg: S
et to send the msg=0x850B5EF4
//-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage
: Posting send for msg=0x850B5EF4, addr=64.154.41.150, port=5060,
connId=2 for U
DP
Jul 24 23:49:26.606: //23/000000000000/SIP/State/sipSPIChangeState:
0x852C7DA0 :
State change from (STATE_IDLE, SUBSTATE_NONE)  to
(SIP_STATE_OUTGOING_REGISTER,
SUBSTATE_NONE)
0x852C7DA0 :
State change from (SIP_STATE_OUTGOING_REGISTER, SUBSTATE_NONE)  to
(SIP_STATE_O
Jul 24 23:49:26.610: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
REGISTER sip:64.154.41.150:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.18.200:5060;branch=z9hG4bK1C1193
To: <7005>
Date: Tue, 24 Jul 2012 23:49:26 GMT
Call-ID: C629EB93-D51F11E1-8014DE03-81F92794
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 70
Timestamp: 1343173766
CSeq: 8 REGISTER
Contact: <7005>
Expires:  3600
Content-Length: 0
Jul 24 23:49:26.778: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads:
Msg enqueu
ed for SPI with IP addr: 64.154.41.150:5060
: ccsip_spi_get_msg_type returned: 2 for event 1
//-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewCon
nMsg: context=0x850B1084
//-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcess
NewConnMsg: gConnTab=0x850B1084, addr=64.154.41.150, port=5060,
connid=2, transp
ort=UDP
//-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Chec
king Invite Dialog
Jul 24 23:49:26.782: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP
192.168.18.200:5060;branch=z9hG4bK1C1193;received=108.132.102.1
84
To: <7005>
CSeq: 8 REGISTER
Server: Asterisk PBX 1.6.2.13
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO
Supported: replaces, timer
Content-Length: 0
Jul 24 23:49:26.838: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads:
Msg enqueu
connid=2, transp
ort=UDP
Jul 24 23:49:26.842:
king Invite Dialog
Jul 24 23:49:26.842: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 401 Unauthorized
Via: SIP/2.0/UDP
84
To: <7005>;tag=as122e8ac5
CSeq: 8 REGISTER
WWW-Authenticate: Digest algorithm=MD5, realm="asterisk",
nonce="512fa694"
Content-Length: 0
Jul 24 23:49:26.846:
//23/000000000000/SIP/Info/sipSPIGenerateAuthorizationRespo
nse: HA1 is: 7f8699de54ca1c3ae55fc85c23cf048b
Jul 24 23:49:26.846: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader:
Converting
Jul 24 23:49:26.850: //23/000000000000/SIP/Transport/sipSPISendRegister:
Sending
msg=0x853734F4, addr=64.154.41.150, port=5060, sentBy_port=0, is_req=1,
transpo
et to send the msg=0x853734F4
Jul 24 23:49:26.854:
: Posting send for msg=0x853734F4, addr=64.154.41.150, port=5060,
connId=2 for U
DP
Jul 24 23:49:26.854: //23/000000000000/SIP/State/sipSPIChangeState:
0x852C7DA0 :
(SIP_STATE_O
Jul 24 23:49:26.854: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.168.18.200:5060;branch=z9hG4bK1D2140
To: <7005>
Max-Forwards: 70
CSeq: 9 REGISTER
Contact: <7005>
Expires: 3600
Authorization: Digest
username="5616236333",realm="asterisk",uri="sip:64.154.41.
150:5060",response="0f077c9394532140da55c1074c4e4560",nonce="512fa694",a
lgorithm
=MD5
Content-Length: 0
Jul 24 23:49:27.042: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads:
Msg enqueu
connid=2, transp
ort=UDP
king Invite Dialog
Jul 24 23:49:27.046: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP
192.168.18.200:5060;branch=z9hG4bK1D2140;received=108.132.102.1
84
To: <7005>
CSeq: 9 REGISTER
Content-Length: 0
Jul 24 23:49:27.098: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads:
Msg enqueu
Jul 24 23:49:27.102:
connid=2, transp
ort=UDP
king Invite Dialog
Jul 24 23:49:27.106: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 403 Forbidden (Bad auth)
Via: SIP/2.0/UDP
84
CSeq: 9 REGISTER
Content-Length: 0
//23/000000000000/SIP/Error/ccsip_api_register_result_ind:
Message Code Class 4xx Method Code 100 received for REGISTER
//-1/xxxxxxxxxxxx/SIP/Info/ccsip_register_reset_dns_cache:
CCSIP_REGISTER:: Primary registrar DNS resolved addr reset
//-1/xxxxxxxxxxxx/SIP/Info/ccsipRegisterStartExpiresTimer:
Starting timer for pattern 7005 for 180 seconds
Jul 24 23:49:27.110:
//-1/xxxxxxxxxxxx/SIP/Info/sipSPIDeleteContextFromTable: Co
ntext for key=[29] removed.
//23/000000000000/SIP/Info/sipSPIUdeleteCcbFromUACTable: **
**Deleting from UAC table.
//23/000000000000/SIP/Info/sipSPIUdeleteCcbFromTable: Delet
ing from table. ccb=0x852C7DA0 key=C629EB93-D51F11E1-8014DE03-81F92794
//23/000000000000/SIP/Info/sipSPIFlushEventBufferQueue: The
re are 0 events on the internal queue that are going to be free'd
From your trace...
++++You are trying to register/authenticate to 64.154.41.150++++
(SIP_STATE_O
Sent:
To: <7005>
Max-Forwards: 70
CSeq: 8 REGISTER
Contact: <7005>
Expires:  3600
Content-Length: 0
+++Your provider is sending Unauthrorized and bad authentication++++++
Received:
Via: SIP/2.0/UDP
84
CSeq: 8 REGISTER
nonce="512fa694"
Content-Length: 0
Received:
Via: SIP/2.0/UDP
84
CSeq: 9 REGISTER
Content-Length: 0
In your registration request, I cannot see you passing any authentication credentials to your sip provider. I can see that you have configured username and password under sip-ua, but this is not been sent in your registration request, so your provider does not know who you are, hence rejecting your registration requests
Please rate all useful posts
Tony Cilli Jr
You wont ever see any incoming calls until you configure the ip address trusted list under your voice service voip.. Here's an example from my config. You have to configure the router to allow calls to come in from your SIP provider.. (replace 10.255.255.255 with the ip address your SIP provider gives you. The other stuff below isn't as important as the ip address trusted list.. That's 100% crucial when doing SIP Trunking from a provider.
voice service voip
  ipv4 10.255.255.255
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
sip
  bind control source-interface GigabitEthernet0/0
  bind media source-interface GigabitEthernet0/0
  early-offer forced
HTH,
Tony
If you find my post helpful, please rate!
Humberto,
Have you tried enabling 'debug ccsip messages' and attempting to dial inward and see if you get any notifications? If not, I still believe you need to configure the ip address trusted list. Even the iOS on my router tells me it needs to be configured when you first start.
Furthermore, to add onto aokanlawon's respone, check with your provider to see how they want you to authenticate. If you can authenticate by using caller ID or perhaps a diverson header (these are the only two methods my provider will take). I find Diversion header's to be the simplest because then you can manipulate your calling number for outbound calls.
Example:
voice class sip-profiles 100
request INVITE sip-header Diversion add "Diversion: "
Replace the X's with the 10-digit BTN they give you for diversion header authentication and the Y's with the IP Address of your router passing through the calls. Then you assign "voiec-class sip profiles 100" to your outbound dial-peer.
HTH,
Tony
I am going to redo the whole SIP thing. I have done so many changes to the configuration that I am completely lost. I will come back as soon as I see something different. To answer to your question, the CCSIP messages never showed after calling in to my number from my cell phone. So, Im going to troubleshoot the authentication part first to verify that my router has been seen and not rejected by the ITSP server.
Im back. I started from scratch. As of right now, I am able to receive incoming calls, and make iternal inbound/outgoing calls with my two IP phones.However, I am not able to make phone calls to the outside world.After dialing 561xxxxxxx, the display shows proceeding in 100, then reorder, and finally a fast busy signal. I attached the actual config and the csip messages. I am pretty sure that may translation rules and my dial-peers are not configured correctly. Also, I have not configured anytyhing related to NAT, which could be part of the problem too. Please take a look and let me if you guys can help me.
You SIP provider rejects the calls, probably because you are sending 333 instead of a valid calling number
Configure so that you send a valid calling number as assigned by SIP provider.
Jul 31 19:03:51.864: //-1/xxxxxxxxxxxx/SIP/sg/ccsipDisplayMsg:
Sent:
INVITE sip:5618537305@sipconnect.ipcomms.net:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.13.200:5060;branch=z9hG4bK3EB130B
From: "333" <>333@sipconnect.ipcomms.net>;tag=13A6B78-21B1
To: <>5618537305@sipconnect.ipcomms.net>
Date: Tue, 31 Jul 2012 19:03:51 GMT
Call-ID: 47C614D5-DA7911E1-82C2AA27-49453C96@192.168.13.200
Supported: 100rel,timer,resource-priority,replaces
Min-SE:  1800
Cisco-Guid: 1203803861-3665367521-2193467943-1229274262
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIF
Y, INFO, REGISTER
CSeq: 102 INVITE
Timestamp: 1343761431
Contact: <333>
Expires: 180
Allow-Events: telephone-event
Authorization: Digest username="5616236333",realm="asterisk",uri="sip:5618537305
@sipconnect.ipcomms.net:5060",response="a74b62c8ee2fe21f3539ba3167c0d02a",nonce=
"790ee99f",algorithm=MD5
Max-Forwards: 69
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 265
v=0
o=CiscoSystemsSIP-GW-UserAgent 6958 2124 IN IP4 192.168.13.200
s=SIP Call
c=IN IP4 192.168.13.200
t=0 0
m=audio 19406 RTP/AVP 0 8 101
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
Jul 31 19:03:51.928: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 192.168.13.200:5060;branch=z9hG4bK3EB130B;received=184.32.211.5
8
CSeq: 102 INVITE
Require: timer
Session-Expires: 1800;refresher=uas
Contact: <5618537305>
Content-Length: 0
Jul 31 19:03:55.376: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 603 Declined
8
To: <>5618537305@sipconnect.ipcomms.net>;tag=as76b59e9c
CSeq: 102 INVITE
Content-Length: 0
Just like Paolo has mentioned, ensure the CLI you are sending macthes with the DDI range from your provider. You can use xlation rules or sip profiles to modify the CLI
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
I found on this lilnk, http://wiki.kolmisoft.com/index.php/SIP/2.0_603_Declined what to look for when SIP/2.0 603 Declined appears. I changed on my phone the username and password, from "333" "333" to username xxxxx password yyyy, the ones provided by mis SIP server.
Thanks to all of you for your inputs. I am still working on more issues, but getting the sip trunk up and running was big.
