Unable to make more than two outbound/inbound calls
sharathpk0912
The call  flow  is  CUCM >> sip gateway  >> PRI.
I am unable to make more than two inbound/ outbound calls.
How to increase the number of inbound/ outbound calls in our voice network.
Rajan
what is the pri config ?  how many channels are configured to use ?
I'm still new to VOIP network.
Configuration file of voice gateway is attached.
When you try to make a 3rd call then what happens on phone..is it give busy signal or some announcement ?
Can you please attach "debug isdn q931" and "debug voip ccapi inout" traces for a failed call along with calling number and called numbers.
Suresh
