unable to make outbound call from cucm 7.1.3 to itsp via sip through cisco router 2821
my conf in attatchment files
and this is debug ccsip calls results
*Sep 24 12:54:01.339: //3636/3806C30E8EF1/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x47BAFFB4
State of The Call        : STATE_DEAD
TCP Sockets Used         : NO
Calling Number           : 0146239789
Called Number            : 0530184647
Source IP Address (Sig  ): 172.29.37.10
Destn SIP Req Addr:Port  : 10.208.9.69:5060
Destn SIP Resp Addr:Port : 10.208.9.69:5060
Destination Name         : 10.208.9.69
Disconnect Cause (CC)    : 28
Disconnect Cause (SIP)   : 484
*Sep 24 12:54:01.347: //3635/3806C30E8EF1/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x472E5E90
Called Number            : 00530184647
Source IP Address (Sig  ): 172.30.151.8
Destn SIP Req Addr:Port  : 172.30.151.6:5060
Destn SIP Resp Addr:Port : 172.30.151.6:5060
Destination Name         : 172.30.151.6
*Sep 24 12:54:01.347: //3635/3806C30E8EF1/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream             : 1
Negotiated Codec         : No Codec
Negotiated Codec Bytes   : 0
Nego. Codec payload      : 255 (tx), 255 (rx)
Negotiated Dtmf-relay    : 0
Dtmf-relay Payload       : 0 (tx), 0 (rx)
Source IP Address (Media): 172.30.151.8
Source IP Port    (Media): 17688
Destn  IP Address (Media): 0.0.0.0
Destn  IP Port    (Media): 0
Orig Destn IP Address:Port (Media): 0.0.0.0:0
2 Accepted Solutions
Hi Othman,
debug shows that ITSP is releasing your call.
Please confirm with Telco regarding their requirment in calling number & called number? I mean how many digits they want
in calling & called number?
Also, please share your running-config.
Nishant Savalia
Regards, Nishant Savalia
Hi Othman!
For your second problem (DTMF).
I don´t see in sip messages SDP messages the your SIP Provider with instructions DTMF.
In normal Setup, ISP forwards SDP messages to client with DTMF instruction, example below:
v=0
o=HuaweiSoftX3000 12459576 12459576 IN IP4 10.57.0.117
s=Sip Call
c=IN IP4 10.57.0.117
t=0 0
m=audio 19696 RTP/AVP 18 8 4 2 98 99 102 97 (instructions SDP)
a=rtpmap:18 G729/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:4 G723/8000
a=rtpmap:2 G726-32/8000
a=rtpmap:98 G726-40/8000
a=rtpmap:99 G726-32/8000
a=rtpmap:102 G726-24/8000
a=rtpmap:97 telephone-event/8000 (DTMF Instruction)
a=fmtp:97 0-15
a=fmtp:18 annexb=no
You can ask your ISP about it, or force the answer by sending your information on your invite.
For enable Early Offer is possible global or in dial-peer:
in voice service voip:
sip
   early-offer forced
In dial-peer voip:
dial-peer voice 3 voip
voice-class sip early-offer forced
I recomend too change your dtmf instruction in dial-peer call leg and outbound.
dtmf-relay rtp-nte sip-kpml sip-notify
Regards!
J Rosa.
22 Replies 22
Nishant Savalia
Level 4
Level 4
Hi othman,
Can you please share debug ccsip messages?
Nishant Savalia
Hi Nishant
this is debug ccsip messages
QCT-VG-02#debug ccsip mess
QCT-VG-02#debug ccsip messages
SIP Call messages tracing is enabled
QCT-VG-02#term mon
% Console already monitors
QCT-VG-02#
*Sep 25 05:39:27.534: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:172.29.37.10:5060 SIP/2.0
Via: SIP/2.0/UDP 10.208.9.69:5060;branch=z9hG4bKmcyo3ttgpypsmgme33ik13y1oT10844
Call-ID: isbchtpyeigss1githiotgctsmi1g1hffs1y@SoftX3000
To: <172.29.37.10>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Sent:
SIP/2.0 200 OK
To: <172.29.37.10>;tag=7DEB744-14A6
Date: Wed, 25 Sep 2013 05:39:27 GMT
Server: Cisco-SIPGateway/IOS-12.x
CSeq: 1 OPTIONS
Supported: 100rel,resource-priority,replaces
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Allow-Events: telephone-event
Accept: application/sdp
Content-Type: application/sdp
Content-Length: 167
v=0
o=CiscoSystemsSIP-GW-UserAgent 5730 6955 IN IP4 172.29.37.10
s=SIP Call
c=IN IP4 172.29.37.10
t=0 0
m=audio 0 RTP/AVP 18 0 8 4 2 15 3
*Sep 25 05:39:47.626: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.208.9.69:5060;branch=z9hG4bKkspss35eohsg5mf3mohifiogiT23848
Call-ID: isbc1gfofcttmiccekoky1ohcyokfst3c11e@SoftX3000
To: <172.29.37.10>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Sent:
SIP/2.0 200 OK
To: <172.29.37.10>;tag=7DF05C0-2175
Date: Wed, 25 Sep 2013 05:39:47 GMT
CSeq: 1 OPTIONS
Content-Length: 167
v=0
o=CiscoSystemsSIP-GW-UserAgent 2913 5735 IN IP4 172.29.37.10
s=SIP Call
t=0 0
*Sep 25 05:40:07.726: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.208.9.69:5060;branch=z9hG4bKk5isemyskp1pseitmtogmg1tcT41547
Call-ID: isbcsifppptscge3e3ytts5mi3cmoekygh3h@SoftX3000
To: <172.29.37.10>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
*Sep 25 05:40:07.730: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <172.29.37.10>;tag=7DF5444-969
Date: Wed, 25 Sep 2013 05:40:07 GMT
CSeq: 1 OPTIONS
Content-Length: 167
v=0
o=CiscoSystemsSIP-GW-UserAgent 7457 1270 IN IP4 172.29.37.10
s=SIP Call
t=0 0
*Sep 25 05:40:27.826: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.208.9.69:5060;branch=z9hG4bKp5es31eyyysiy3mgomcygkcy1T19701
Call-ID: isbc1gep5m3kmiopm1tgseg5iot3g5ciepmt@SoftX3000
To: <172.29.37.10>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
*Sep 25 05:40:27.830: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <172.29.37.10>;tag=7DFA2C8-7A1
Date: Wed, 25 Sep 2013 05:40:27 GMT
CSeq: 1 OPTIONS
Content-Length: 167
v=0
o=CiscoSystemsSIP-GW-UserAgent 7282 1454 IN IP4 172.29.37.10
s=SIP Call
t=0 0
*Sep 25 05:40:47.930: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.208.9.69:5060;branch=z9hG4bKime51kimge1hmmicmioyepsk3T11076
Call-ID: isbc3kyessgeegcgmg11tiit1sfic3eyy1mk@SoftX3000
To: <172.29.37.10>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
*Sep 25 05:40:47.934: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <172.29.37.10>;tag=7DFF150-22C6
Date: Wed, 25 Sep 2013 05:40:47 GMT
CSeq: 1 OPTIONS
Content-Length: 167
v=0
o=CiscoSystemsSIP-GW-UserAgent 1227 5323 IN IP4 172.29.37.10
s=SIP Call
t=0 0
This does not seems to be a outgoing call debug.
Please check and share it again.
Nishant Savalia
Hi Nishant
this is debug ccsip messages for
outgoing call
*Sep 26 09:10:52.539: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:0530184647@172.30.151.8:5060 SIP/2.0
Date: Thu, 26 Sep 2013 08:42:55 GMT
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
From: <0146239789>;tag=c0b59f9c-9377-4dfa-8a7d-3dd8712ea826-34283601
Allow-Events: presence
P-Asserted-Identity: <0146239789>
Supported: timer,resource-priority,replaces
Supported: Geolocation
Min-SE:  1800
Remote-Party-ID: <0146239789>;party=calling;screen=yes;privacy=off
Content-Length: 0
User-Agent: Cisco-CUCM7.1
To: <0530184647>
Contact: <0146239789>
Expires: 180
Call-ID: a1e0d700-2431f38f-18-6971eac@172.30.151.6
Via: SIP/2.0/UDP 172.30.151.6:5060;branch=z9hG4bK177db77ee1
CSeq: 101 INVITE
Session-Expires:  1800
Max-Forwards: 70
*Sep 26 09:10:52.551: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: <0530184647>
Date: Thu, 26 Sep 2013 09:10:52 GMT
CSeq: 101 INVITE
Content-Length: 0
Sent:
INVITE sip:0530184647@10.208.9.69:5060 SIP/2.0
Via: SIP/2.0/UDP 172.29.37.10:5060;branch=z9hG4bK1D15C0
To: <0530184647>
Call-ID: 60947F0A-25C211E3-80DFA7B3-7B90AC6A@172.29.37.10
Supported: 100rel,timer,resource-priority,replaces
Min-SE:  1800
Cisco-Guid: 1620304610-633475555-2161813427-2073078890
User-Agent: Cisco-SIPGateway/IOS-12.x
CSeq: 101 INVITE
Timestamp: 1380186652
Expires: 180
Allow-Events: kpml, telephone-event
Max-Forwards: 69
Content-Length: 0
*Sep 26 09:10:52.595: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <0530184647>
CSeq: 101 INVITE
Content-Length: 0
*Sep 26 09:10:52.671: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 484 Address Incomplete
Record-Route: <10.208.9.69:5060>
To: <0530184647>;tag=sbc0804moo5gecs
CSeq: 101 INVITE
Reason: Q.850;cause=28;text="address incomplete"
Warning: 399 - "SoftX3000 R601-CCU Rel POS:[3103] Release from CR"
Content-Length: 0
*Sep 26 09:10:52.675: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:0530184647@10.208.9.69:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Sent:
To: <0530184647>;tag=70214C-1FFC
CSeq: 101 INVITE
Content-Length: 0
Received:
ACK sip:0530184647@172.30.151.8:5060 SIP/2.0
Content-Length: 0
CSeq: 101 ACK
Max-Forwards: 70
Hi Othman,
Nishant Savalia
Hi Nishant
this is my running conf
for itsp i will ask them for calling and called number
version 12.4
hostname QCT-VG-02
boot-start-marker
boot-end-marker
! card type command needed for slot/vwic-slot 0/0
logging buffered 51200 warnings
no aaa new-model
no network-clock-participate slot 1
dot11 syslog
ip cef
ip domain name yourdomain.com
voice-card 0
dspfarm
dsp services dspfarm
voice-card 1
no dspfarm
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip refer
redirect ip2ip
h323
  emptycapability
  h225 signal overlap
  h225 connect-passthru
  call start interwork
  h245 passthru tcsnonstd-passthru
sip
  no update-callerid
voice class codec 2
codec preference 1 g729r8
voice class codec 3
codec preference 1 g729br8
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
voice class h323 1
h225 timeout tcp establish 3
archive
log config
  hidekeys
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address 172.30.151.8 255.255.255.128
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 172.29.37.10 255.255.255.252
duplex auto
speed auto
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 172.29.37.9
ip route 172.30.0.0 255.255.0.0 172.30.151.1
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
control-plane
sccp local GigabitEthernet0/0
sccp ccm 172.30.151.6 identifier 2
sccp ccm 172.30.151.5 identifier 1
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 1 register CFB0015633b74d8
associate profile 2 register MTP0015633b74d8
dspfarm profile 3 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
associate application SCCP
shutdown
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 2
shutdown
dspfarm profile 2 mtp
codec g711ulaw
maximum sessions software 20
shutdown
dial-peer voice 1 voip
description To/from CUCM
destination-pattern 0146239...
voice-class codec 1
session protocol sipv2
session target ipv4:172.30.151.5
incoming called-number 0146239...
dtmf-relay rtp-nte
no vad
dial-peer voice 2 voip
preference 1
voice-class codec 1
session target ipv4:172.30.151.6
dtmf-relay rtp-nte
no vad
description Outbound to IPTSP
destination-pattern 0T
voice-class codec 1
session target ipv4:10.208.9.69
dtmf-relay rtp-nte
no vad
gateway
timer receive-rtp 1200
sip-ua
registrar ipv4:10.208.9.69 expires 3600
line con 0
login local
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input telnet ssh
line vty 5 15
access-class 23 in
privilege level 15
login local
scheduler allocate 20000 1000
end
Ok..share when you get the information from ITSP regarding the calling and called party requirement.
What type of number you are trying to call i.e Local, National, International?
Nishant Savalia
Hi Othman,
Include in SIP config in "voice service voip" bind comand an EO forced.
sip
  bind control source-interface GigabitEthernet0/1
  bind media source-interface GigabitEthernet0/1
  early-offer forced
I recomend too, create a dial-peer voip call leg and remove the "incoming called-number" in dial-peer 1 and 2.
Ex: call leg dial-peer:
dial-peer voice XX voip
description # Call Leg VOIP #
incoming called-number .
voice-class codec 1
dtmf-relay rtp-nte
Regards.
JRosa.
Hi Nishant
hi  jfernandorosa
our outbound calls now working but i still have problems
first it worked after i put this command in sip conf  and removed area code from calling party (014)
sip
  rel1xx disable
second our problems is
1- cant make calls to mobile numbers of aspecific company ( STC HERE IN KSA )
2- Cant interact with outging auto-attendant  calls , for example when make call to 909 ( customer service for stc ) and after automatic  greeting message it ask me to press 1 for arabic and 2 for english  , when i press 1 or 2  nothing happen and call terminated.
Hi othman,
Good part that one issue is resolved.
Please share debugs for both the failure cases and also topology i.e. what kind of connectivity is between all nodes
Nishant Savalia
Hi Nishant
for connectivity we have   2 cucm ---sip trunk ---- cube router 2821 cisco ------ sip trunk --- ITSP (STC)
these for first problem  debug ccsip messages for  (
1- cant make calls to mobile numbers of aspecific company ( STC HERE IN KSA ) )
*Oct  1 12:07:32.314: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 183 Session Progress
Via: SIP/2.0/UDP 172.29.37.10:5060;branch=z9hG4bKAE1CAB
Call-ID: E25C47BC-29C811E3-8570E499-2C4180EE@172.29.37.10
To: <0530184647>;tag=sbc0804tmctsh3g-CC-23-TRC-5940
CSeq: 101 INVITE
Contact: <0530184647>
Allow: INVITE,ACK,OPTIONS,BYE,CANCEL,REGISTER,INFO,PRACK,SUBSCRIBE,NOTIFY,UPDATE        ,MESSAGE,REFER
Content-Length: 324
v=0
o=- 100623 100623 IN IP4 10.208.9.69
s=SBC call
c=IN IP4 10.208.9.69
t=0 0
m=audio 40752 RTP/AVP 8 0 102 102 18 116
a=rtpmap:0 PCMU/8000
a=rtpmap:102 AMR/8000
a=rtpmap:116 telephone-event/8000
a=ptime:5
a=fmtp:116 0-15
a=fmtp:18 annexb=yes
*Oct  1 12:07:32.314: %SIP-3-UNSUPPORTED: Unsupported ptime value
*Oct  1 12:07:32.318: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 172.30.151.6:5060;branch=z9hG4bK3f577c8bcaa
From: "othman" <6239789>;tag=c0b59f9c-9377-4dfa-8a7d-3dd8712ea8        26-34286980
To: <0530184647>;tag=16564F8-22E4
Date: Tue, 01 Oct 2013 12:07:31 GMT
Call-ID: af360100-24a1b3b3-215-6971eac@172.30.151.6
CSeq: 101 INVITE
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIF        Y, INFO, REGISTER
Remote-Party-ID: <0530184647>;party=called;screen=no;privacy=of        f
Content-Disposition: session;handling=required
Content-Length: 271
v=0
o=CiscoSystemsSIP-GW-UserAgent 2552 1205 IN IP4 172.30.151.7
s=SIP Call
c=IN IP4 172.30.151.7
t=0 0
m=audio 16586 RTP/AVP 8 101 19
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=rtpmap:19 CN/8000
a=ptime:20
*Oct  1 12:07:32.414: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 500 Server Internal Error
CSeq: 101 INVITE
Reason: Q.850;cause=127;text="interworking unspecified"
Content-Length: 0
Sent:
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
*Oct  1 12:07:32.418: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 503 Service Unavailable
CSeq: 101 INVITE
Reason: Q.850;cause=41
Content-Length: 0
Received:
ACK sip:0530184647@172.30.151.7:5060 SIP/2.0
Date: Tue, 01 Oct 2013 11:36:19 GMT
Allow-Events: presence, kpml
Content-Length: 0
CSeq: 101 ACK
Max-Forwards: 70
second one :
*Oct  1 12:19:32.310: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:909@172.30.151.7:5060 SIP/2.0
Date: Tue, 01 Oct 2013 11:48:19 GMT
From: "othman" <6239789>;tag=c0b59f9c-9377-4dfa-8a7d-3dd8712ea826-34286998
Content-Length: 214
To: <909>;tag=17060C8-1646
Call-ID: 5c5d4900-24a1b683-216-6971eac@172.30.151.6
Via: SIP/2.0/UDP 172.30.151.6:5060;branch=z9hG4bK3f7e7f24
CSeq: 101 ACK
Max-Forwards: 70
v=0
o=CiscoSystemsCCM-SIP 2000 1 IN IP4 172.30.151.6
s=SIP Call
c=IN IP4 172.30.151.152
t=0 0
m=audio 26094 RTP/AVP 8 101
a=ptime:20
a=fmtp:101 0-15
*Oct  1 12:19:32.314: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:909@10.208.9.69:5060;user=phone SIP/2.0
Via: SIP/2.0/UDP 172.29.37.10:5060;branch=z9hG4bKB020F6
To: <909>;tag=sbc0807fphthmti-CC-27-TRC-7127
Date: Tue, 01 Oct 2013 12:19:31 GMT
Call-ID: 8F339A2C-29CA11E3-859AE499-2C4180EE@172.29.37.10
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 179
v=0
o=CiscoSystemsSIP-GW-UserAgent 6381 9777 IN IP4 172.29.37.10
s=SIP Call
t=0 0
m=audio 18884 RTP/AVP 8
*Oct  1 12:19:32.378: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:6239789@172.29.37.10:5060 SIP/2.0
Via: SIP/2.0/UDP 10.208.9.69:5060;branch=z9hG4bKhohfppyykktomyc53ecok1cogT27880
To: "othman"<6239789>;tag=1705DD8-18B
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
*Oct  1 12:19:32.382: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: "othman" <6239789>;tag=1705DD8-18B
Date: Tue, 01 Oct 2013 12:19:32 GMT
CSeq: 1 OPTIONS
Supported: resource-priority,replaces
Content-Length: 179
v=0
s=SIP Call
t=0 0
*Oct  1 12:19:34.974: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.208.9.69:5060;branch=z9hG4bKyeygicopit3oif35c5gimmfiiT09136
Call-ID: isbccc5gehio1yph3ksocigp1tokpothmpmc@SoftX3000
To: <172.29.37.10>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Sent:
SIP/2.0 200 OK
To: <172.29.37.10>;tag=1706BD8-68F
Date: Tue, 01 Oct 2013 12:19:34 GMT
CSeq: 1 OPTIONS
Content-Length: 167
v=0
o=CiscoSystemsSIP-GW-UserAgent 2613 8478 IN IP4 172.29.37.10
s=SIP Call
t=0 0
*Oct  1 12:19:55.054: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.208.9.69:5060;branch=z9hG4bKehkhmeih155fpcfookseymok3T09215
Call-ID: isbcksc3sc53phfsmseoktkpftehshfgepme@SoftX3000
To: <172.29.37.10>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Sent:
SIP/2.0 200 OK
To: <172.29.37.10>;tag=170BA48-1BC8
Date: Tue, 01 Oct 2013 12:19:55 GMT
CSeq: 1 OPTIONS
Content-Length: 167
v=0
o=CiscoSystemsSIP-GW-UserAgent 8558 9468 IN IP4 172.29.37.10
s=SIP Call
t=0 0
*Oct  1 12:20:02.414: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:909@172.30.151.7:5060 SIP/2.0
P-Asserted-Identity: "othman" <6239789>
Content-Length: 0
Via: SIP/2.0/UDP 172.30.151.6:5060;branch=z9hG4bK3f8534587ae
CSeq: 102 BYE
Max-Forwards: 70
*Oct  1 12:20:02.418: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Tue, 01 Oct 2013 12:20:02 GMT
CSeq: 102 BYE
Reason: Q.850;cause=16
Content-Length: 0
Sent:
BYE sip:909@10.208.9.69:5060;user=phone SIP/2.0
Via: SIP/2.0/UDP 172.29.37.10:5060;branch=z9hG4bKB115B3
Max-Forwards: 70
Timestamp: 1380630002
CSeq: 102 BYE
Content-Length: 0
*Oct  1 12:20:02.506: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 BYE
Content-Length: 0
Hi Othman!
v=0
s=Sip Call
t=0 0
a=fmtp:97 0-15
a=fmtp:18 annexb=no
sip
   early-offer forced
In dial-peer voip:
Regards!
J Rosa.
Hi j rosa
for "early-offer forced"  command  i cant enter it becuase our cube doesnt let me to enter it , i think i have to upgrade the
software of it .  do you know what exact or right image for cisco router 2821 or 2851  to act as cube or ip-to-ip GW ?
tomorrow i will post what version i have on router .
