Unable to Make Outgoing Calls on Cisco IP Communicator 8.6
mohammednoor
Beginner
Beginner
I have configured Cisco Unified CM rel. 7.1 and installed Cisco IP Communicator 8.6. Incoming calls work fine but I am having problems making outgoing calls. Would very much appreciate any advise. Thanks.
Mohammed Noor
Jaime Valencia
Hall of Fame Cisco Employee Hall of Fame Cisco Employee
What do you hear on IPC?
What does the debugs on the GW say about the reason code for the disconnect?
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Recognize Your Peers
