3211
Highlighted
Enthusiast
unable to match dial-peer with FXO Ports
I am trying to call 90096650xxxxxxx. I am using h323 gateway connected with CUCM. I have FXO lines
Dial-Peer detail
dial-peer voice 10 pots
trunkgroup LOCAL
description International
destination-pattern 900.T
prefix 00
Voice-Port detail
voice-port 0/3/3
trunk-group LOCAL
input gain -3
output attenuation -1
echo-cancel coverage 64
no comfort-noise
cptone SA
timing hookflash-out 50
connection plar 9918
description *** LOCAL LINE ***
music-threshold -45
bearer-cap Speech
Debug voip dial-peer inout detail
JUB-HUB-RTR#
*Jul 16 05:41:18.969: //-1/0028C7E90A00/DPM/dpAssociateIncomingPeerCore:
   Calling Number=7030, Called Number=900966502747576, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
   Result=NO_MATCH(-1) After All Match Rules Attempt
*Jul 16 05:41:18.969: //-1/0028C7E90A00/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
*Jul 16 05:41:18.969: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=900966502747576, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=900966502747576
   Result=Success(0) after DP_MATCH_DEST
*Jul 16 05:41:18.973: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=900966502747576, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
*Jul 16 05:41:18.973: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=10
*Jul 16 05:41:18.973: //-1/0028C7E90A00/DPM/dpMatchPeersCore:
*Jul 16 05:41:18.973: //-1/0028C7E90A00/DPM/dpMatchSafModulePlugin:
*Jul 16 05:41:18.973: //-1/0028C7E90A00/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
*Jul 16 05:41:18.973: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=900966502747576, Called Number=900966502747576, Peer Info Type=DIALPEER_INFO_SPEECH
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
*Jul 16 05:41:18.973: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=900966502747576, Called Number=, Voice-Interface=0x0,
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
   dialstring=900966502747576, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
*Jul 16 05:41:23.373: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=7030, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=7030
   No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
*Jul 16 05:41:23.373: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
*Jul 16 05:41:23.373: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=NO_MATCH(-1)
   Calling Number=, Called Number=00966502747576, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=00966502747576
   Result=NO_MATCH(-1)
*Jul 16 05:41:23.725: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
*Jul 16 05:41:23.725: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
*Jul 16 05:41:23.725: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=NO_MATCH(-1)
   Result=NO_MATCH(-1)
11 REPLIES 11
Highlighted
Enthusiast
Update failed. The list of Partition names (Clause) in a Calling Search Space is  too long as a result of this operation (more than 1024 characters). Shorten the  Partition names or use fewer Partitions in the Calling Search Space
I did notice while rechecking setting of Route Partition and CSS that i am getting above mentioned error.
Highlighted
I guess you are trying to match incoming dial-peer. If so please refer the following document,
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a008010fed1.shtml
You might have to configure 'incoming called-number' or 'port x/y/z'.
Since you are using H323 Gateway and dialable extension is off-box, you should use 'connection plar opx 9918'
voice-port 0/3/3
If you want to route calls to Call Manager, configure a voip dial-peer.
Hope this helps.
Vinay
Highlighted
My voip dial-peer to route calls to CUCM. I am trying to call outgoing.
dial-peer voice 100 voip
description ***testing***
preference 1
destination-pattern 991[89]
session target ipv4:10.50.2.3
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
Highlighted
Add an incoming voip dial-peer and see if it helps,
dial-peer voice xx voip
incoming called-number .T
codec g711ulaw
If not, please attach
debug voice ccapi inout
debug h225 asn1
debug vpm signal
debug voice dialpeer inout
Vinay
Highlighted
Result of debug h225 asn1
value H323_UserInformation ::=
      h323-uu-pdu
        h323-message-body progress :
          protocolIdentifier { 0 0 8 2250 0 4 }
          destinationInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
            gateway
              protocol
                voice :
                  supportedPrefixes
            mc FALSE
            undefinedNode FALSE
          h245Address ipAddress :
            ip '0A053FFE'H
            port 36841
          callIdentifier
            guid '00F7CA19CF4011E21200BE010A011266'H
          multipleCalls FALSE
          maintainConnection FALSE
        h245Tunneling FALSE
        nonStandardControl
            nonStandardIdentifier h221NonStandard :
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
            data '60011000011E041E028188'H
*Jul 16 07:44:28.421: H225.0 OUTGOING ENCODE BUFFER::= 280032C0060008914A00042800B500001240013C050100000A053FFE8FE90000F7CA19CF4011E21200BE010A01126605800100010010A00100120140B50000120B60011000011E041E028188
*Jul 16 07:44:28.421: H225.0 OUTGOING PDU ::=
      h323-uu-pdu
        h323-message-body notify :
          callIdentifier
        h245Tunneling FALSE
*Jul 16 07:44:28.421: H225.0 OUTGOING ENCODE BUFFER::= 28501900060008914A00040000F7CA19CF4011E21200BE010A01126610800100
*Jul 16 07:44:28.769: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
*Jul 16 07:44:28.769: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
*Jul 16 07:44:28.769: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=NO_MATCH(-1)
   Result=NO_MATCH(-1)
*Jul 16 07:44:28.769: H225 NONSTD OUTGOING PDU ::=
value H323_UU_NonStdInfo ::=
      version 0
      progIndParam progIndIEinfo :
        progIndIE '00000002'H
*Jul 16 07:44:28.769: H225 NONSTD OUTGOING ENCODE BUFFER::= C0010018800006000400000002
*Jul 16 07:44:28.769: H225.0 OUTGOING PDU ::=
      h323-uu-pdu
        h323-message-body connect :
            ip '0A053FFE'H
            port 36841
          destinationInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
            gateway
              protocol
                voice :
                  supportedPrefixes
            mc FALSE
            undefinedNode FALSE
          conferenceID '00F7CA19CF4011E21200BE010A011266'H
          callIdentifier
          multipleCalls FALSE
        h245Tunneling FALSE
        nonStandardControl
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
            data 'C0010018800006000400000002'H
*Jul 16 07:44:28.773: H225.0 OUTGOING ENCODE BUFFER::= 22C0060008914A0004000A053FFE8FE92800B500001240013C0501000000F7CA19CF4011E21200BE010A0112661D0C00110000F7CA19CF4011E21200BE010A0112660100010010A00100140140B50000120DC0010018800006000400000002
*Jul 16 07:44:28.773: H225.0 OUTGOING PDU ::=
      h323-uu-pdu
          callIdentifier
        h245Tunneling FALSE
*Jul 16 07:44:28.773: H225.0 OUTGOING ENCODE BUFFER::= 28501900060008914A00040000F7CA19CF4011E21200BE010A01126610800100
Highlighted
Result of debug vpm signal
          destinationInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
            gateway
              protocol
                voice :
                  supportedPrefixes
            mc FALSE
            undefinedNode FALSE
            ip '0A053FFE'H
            port 45788
          callIdentifier
            guid '008B0091974111E21300C9010A011266'H
          multipleCalls FALSE
        h245Tunneling FALSE
        nonStandardControl
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
*Jul 16 07:47:45.233: H225.0 OUTGOING ENCODE BUFFER::= 280032C0060008914A00042800B500001240013C050100000A053FFEB2DC00008B0091974111E21300C9010A01126605800100010010A00100120140B50000120B60011000011E041E028188
*Jul 16 07:47:45.237: H225.0 OUTGOING PDU ::=
      h323-uu-pdu
          callIdentifier
        h245Tunneling FALSE
*Jul 16 07:47:45.237: H225.0 OUTGOING ENCODE BUFFER::= 28501900060008914A000400008B0091974111E21300C9010A01126610800100
*Jul 16 07:47:45.581: htsp_process_event: [0/1/0, FXOLS_WAIT_CUT_THRU, E_HTSP_EVENT_TIMER]fxols_handle_cut_thru
*Jul 16 07:47:45.581: htsp_timer_stop
*Jul 16 07:47:45.581: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
*Jul 16 07:47:45.581: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
*Jul 16 07:47:45.581: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=NO_MATCH(-1)
   Result=NO_MATCH(-1)
*Jul 16 07:47:45.581: H225 NONSTD OUTGOING PDU ::=
      version 0
*Jul 16 07:47:45.581: H225 NONSTD OUTGOING ENCODE BUFFER::= C0010018800006000400000002
*Jul 16 07:47:45.581: H225.0 OUTGOING PDU ::=
      h323-uu-pdu
            ip '0A053FFE'H
            port 45788
          destinationInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
            gateway
              protocol
                voice :
                  supportedPrefixes
            mc FALSE
            undefinedNode FALSE
          conferenceID '008B0091974111E21300C9010A011266'H
          callIdentifier
          multipleCalls FALSE
        h245Tunneling FALSE
        nonStandardControl
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
*Jul 16 07:47:45.585: H225.0 OUTGOING ENCODE BUFFER::= 22C0060008914A0004000A053FFEB2DC2800B500001240013C05010000008B0091974111E21300C9010A0112661D0C001100008B0091974111E21300C9010A0112660100010010A00100140140B50000120DC0010018800006000400000002
*Jul 16 07:47:45.585: H225.0 OUTGOING PDU ::=
      h323-uu-pdu
          callIdentifier
        h245Tunneling FALSE
*Jul 16 07:47:45.585: H225.0 OUTGOING ENCODE BUFFER::= 28501900060008914A000400008B0091974111E21300C9010A01126610800100
*Jul 16 07:47:46.965: htsp_process_event: [0/1/0, FXOLS_OFFHOOK, E_HTSP_VOICE_CUT_THROUGH]fxols_proc_voice
Highlighted
Looking at the called number and your dial-peer config, they do not match. Your called number begins with 009, wher as dial-peer is configured to match numbers begining with 900.
trunkgroup LOCAL
prefix 00
Highlighted
whats the solution???
Highlighted
Change the dial-peer config to match actual called number,
trunkgroup LOCAL
destination-pattern 00.T
prefix 00
I assume you have modified the configuration, because i see different called number and proper dial-peer match in your first thread.
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
Highlighted
means that i cant call by dialing 9
Highlighted
Yes. If you would like to use 9 dialing, make sure you configure your Route Pattern accordingly and do not strip this digit at Callmanager.
Vinay
