unable to match dial-peer with FXO Ports
techguy
Level 4
Level 4
I am trying to call 90096650xxxxxxx. I am using h323 gateway connected with CUCM. I have FXO lines
Dial-Peer detail
dial-peer voice 10 pots
trunkgroup LOCAL
description International
destination-pattern 900.T
prefix 00
Voice-Port detail
voice-port 0/3/3
trunk-group LOCAL
input gain -3
output attenuation -1
echo-cancel coverage 64
no comfort-noise
cptone SA
timing hookflash-out 50
connection plar 9918
description *** LOCAL LINE ***
music-threshold -45
bearer-cap Speech
Debug voip dial-peer inout detail
JUB-HUB-RTR#
*Jul 16 05:41:18.969: //-1/0028C7E90A00/DPM/dpAssociateIncomingPeerCore:
   Calling Number=7030, Called Number=900966502747576, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
   Result=NO_MATCH(-1) After All Match Rules Attempt
*Jul 16 05:41:18.969: //-1/0028C7E90A00/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
*Jul 16 05:41:18.969: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=900966502747576, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=900966502747576
   Result=Success(0) after DP_MATCH_DEST
*Jul 16 05:41:18.973: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=900966502747576, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
*Jul 16 05:41:18.973: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=10
*Jul 16 05:41:18.973: //-1/0028C7E90A00/DPM/dpMatchPeersCore:
*Jul 16 05:41:18.973: //-1/0028C7E90A00/DPM/dpMatchSafModulePlugin:
*Jul 16 05:41:18.973: //-1/0028C7E90A00/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
*Jul 16 05:41:18.973: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=900966502747576, Called Number=900966502747576, Peer Info Type=DIALPEER_INFO_SPEECH
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
*Jul 16 05:41:18.973: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=900966502747576, Called Number=, Voice-Interface=0x0,
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
   dialstring=900966502747576, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
*Jul 16 05:41:23.373: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=7030, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=7030
   No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
*Jul 16 05:41:23.373: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
*Jul 16 05:41:23.373: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=NO_MATCH(-1)
   Calling Number=, Called Number=00966502747576, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=00966502747576
   Result=NO_MATCH(-1)
*Jul 16 05:41:23.725: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
*Jul 16 05:41:23.725: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
*Jul 16 05:41:23.725: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=NO_MATCH(-1)
   Result=NO_MATCH(-1)
11 Replies 11
techguy
Level 4
Level 4
Update failed. The list of Partition names (Clause) in a Calling Search Space is  too long as a result of this operation (more than 1024 characters). Shorten the  Partition names or use fewer Partitions in the Calling Search Space
I did notice while rechecking setting of Route Partition and CSS that i am getting above mentioned error.
I guess you are trying to match incoming dial-peer. If so please refer the following document,
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a008010fed1.shtml
You might have to configure 'incoming called-number' or 'port x/y/z'.
Since you are using H323 Gateway and dialable extension is off-box, you should use 'connection plar opx 9918'
voice-port 0/3/3
If you want to route calls to Call Manager, configure a voip dial-peer.
Hope this helps.
Vinay
My voip dial-peer to route calls to CUCM. I am trying to call outgoing.
dial-peer voice 100 voip
description ***testing***
preference 1
destination-pattern 991[89]
session target ipv4:10.50.2.3
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
Add an incoming voip dial-peer and see if it helps,
dial-peer voice xx voip
incoming called-number .T
codec g711ulaw
If not, please attach
debug voice ccapi inout
debug h225 asn1
debug vpm signal
debug voice dialpeer inout
Vinay
Result of debug h225 asn1
value H323_UserInformation ::=
      h323-uu-pdu
        h323-message-body progress :
          protocolIdentifier { 0 0 8 2250 0 4 }
          destinationInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
            gateway
              protocol
                voice :
                  supportedPrefixes
            mc FALSE
            undefinedNode FALSE
          h245Address ipAddress :
            ip '0A053FFE'H
            port 36841
          callIdentifier
            guid '00F7CA19CF4011E21200BE010A011266'H
          multipleCalls FALSE
          maintainConnection FALSE
        h245Tunneling FALSE
        nonStandardControl
            nonStandardIdentifier h221NonStandard :
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
            data '60011000011E041E028188'H
*Jul 16 07:44:28.421: H225.0 OUTGOING ENCODE BUFFER::= 280032C0060008914A00042800B500001240013C050100000A053FFE8FE90000F7CA19CF4011E21200BE010A01126605800100010010A00100120140B50000120B60011000011E041E028188
*Jul 16 07:44:28.421: H225.0 OUTGOING PDU ::=
      h323-uu-pdu
        h323-message-body notify :
          callIdentifier
        h245Tunneling FALSE
*Jul 16 07:44:28.421: H225.0 OUTGOING ENCODE BUFFER::= 28501900060008914A00040000F7CA19CF4011E21200BE010A01126610800100
*Jul 16 07:44:28.769: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
*Jul 16 07:44:28.769: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
*Jul 16 07:44:28.769: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=NO_MATCH(-1)
   Result=NO_MATCH(-1)
*Jul 16 07:44:28.769: H225 NONSTD OUTGOING PDU ::=
value H323_UU_NonStdInfo ::=
      version 0
      progIndParam progIndIEinfo :
        progIndIE '00000002'H
*Jul 16 07:44:28.769: H225 NONSTD OUTGOING ENCODE BUFFER::= C0010018800006000400000002
*Jul 16 07:44:28.769: H225.0 OUTGOING PDU ::=
      h323-uu-pdu
        h323-message-body connect :
            ip '0A053FFE'H
            port 36841
          destinationInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
            gateway
              protocol
                voice :
                  supportedPrefixes
            mc FALSE
            undefinedNode FALSE
          conferenceID '00F7CA19CF4011E21200BE010A011266'H
          callIdentifier
          multipleCalls FALSE
        h245Tunneling FALSE
        nonStandardControl
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
            data 'C0010018800006000400000002'H
*Jul 16 07:44:28.773: H225.0 OUTGOING ENCODE BUFFER::= 22C0060008914A0004000A053FFE8FE92800B500001240013C0501000000F7CA19CF4011E21200BE010A0112661D0C00110000F7CA19CF4011E21200BE010A0112660100010010A00100140140B50000120DC0010018800006000400000002
*Jul 16 07:44:28.773: H225.0 OUTGOING PDU ::=
      h323-uu-pdu
          callIdentifier
        h245Tunneling FALSE
*Jul 16 07:44:28.773: H225.0 OUTGOING ENCODE BUFFER::= 28501900060008914A00040000F7CA19CF4011E21200BE010A01126610800100
Result of debug vpm signal
          destinationInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
            gateway
              protocol
                voice :
                  supportedPrefixes
            mc FALSE
            undefinedNode FALSE
            ip '0A053FFE'H
            port 45788
          callIdentifier
            guid '008B0091974111E21300C9010A011266'H
          multipleCalls FALSE
        h245Tunneling FALSE
        nonStandardControl
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
*Jul 16 07:47:45.233: H225.0 OUTGOING ENCODE BUFFER::= 280032C0060008914A00042800B500001240013C050100000A053FFEB2DC00008B0091974111E21300C9010A01126605800100010010A00100120140B50000120B60011000011E041E028188
*Jul 16 07:47:45.237: H225.0 OUTGOING PDU ::=
      h323-uu-pdu
          callIdentifier
        h245Tunneling FALSE
*Jul 16 07:47:45.237: H225.0 OUTGOING ENCODE BUFFER::= 28501900060008914A000400008B0091974111E21300C9010A01126610800100
*Jul 16 07:47:45.581: htsp_process_event: [0/1/0, FXOLS_WAIT_CUT_THRU, E_HTSP_EVENT_TIMER]fxols_handle_cut_thru
*Jul 16 07:47:45.581: htsp_timer_stop
*Jul 16 07:47:45.581: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
*Jul 16 07:47:45.581: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
*Jul 16 07:47:45.581: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=NO_MATCH(-1)
   Result=NO_MATCH(-1)
*Jul 16 07:47:45.581: H225 NONSTD OUTGOING PDU ::=
      version 0
*Jul 16 07:47:45.581: H225 NONSTD OUTGOING ENCODE BUFFER::= C0010018800006000400000002
*Jul 16 07:47:45.581: H225.0 OUTGOING PDU ::=
      h323-uu-pdu
            ip '0A053FFE'H
            port 45788
          destinationInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
            gateway
              protocol
                voice :
                  supportedPrefixes
            mc FALSE
            undefinedNode FALSE
          conferenceID '008B0091974111E21300C9010A011266'H
          callIdentifier
          multipleCalls FALSE
        h245Tunneling FALSE
        nonStandardControl
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
*Jul 16 07:47:45.585: H225.0 OUTGOING ENCODE BUFFER::= 22C0060008914A0004000A053FFEB2DC2800B500001240013C05010000008B0091974111E21300C9010A0112661D0C001100008B0091974111E21300C9010A0112660100010010A00100140140B50000120DC0010018800006000400000002
*Jul 16 07:47:45.585: H225.0 OUTGOING PDU ::=
      h323-uu-pdu
          callIdentifier
        h245Tunneling FALSE
*Jul 16 07:47:45.585: H225.0 OUTGOING ENCODE BUFFER::= 28501900060008914A000400008B0091974111E21300C9010A01126610800100
*Jul 16 07:47:46.965: htsp_process_event: [0/1/0, FXOLS_OFFHOOK, E_HTSP_VOICE_CUT_THROUGH]fxols_proc_voice
Looking at the called number and your dial-peer config, they do not match. Your called number begins with 009, wher as dial-peer is configured to match numbers begining with 900.
trunkgroup LOCAL
prefix 00
whats the solution???
Change the dial-peer config to match actual called number,
trunkgroup LOCAL
destination-pattern 00.T
prefix 00
I assume you have modified the configuration, because i see different called number and proper dial-peer match in your first thread.
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
means that i cant call by dialing 9
Yes. If you would like to use 9 dialing, make sure you configure your Route Pattern accordingly and do not strip this digit at Callmanager.
Vinay
