Unable to ping vlan gateway from VM
Rajan R
Running a Unity Connection 12.5. I am unable to ping the local vlan gateway from the cli. Hence it is not reaching the internet and unable to sync licenses. I am able to ping CUCM since it is in the same VM Server. Nothing goes out otherwise. Restarted it several times. Any clues ?
M02@rt37
Hello @Rajan R
Do you check IP config of that Unity Connection server? default Gateway ?
Best regards
Hi @Rajan R ,
Are you able to ping the default GW from the CUCM?
Please post the output of show network eth0 detail and a utils network arp list
Thaks a lot
Carlo
Please rate all helpful posts "The more you help the more you learn"
First, make sure you have configured the correct subnet mask. Check the VM network settings. Can your CUCM reach the gateway? If not, then it’s a common issue for all the VMs that you need to check from the VMware level
Response Signature
