Unable to receive incoming calls via the PSTN in SRST mode
martin.franklyn
I am able to successfully dial out to the PSTN in SRST mode but unable to receive calls. The phones are registered using SIP. The following is the output after I entered the show run command.
Building configuration...
Current configuration : 4447 bytes
! Last configuration change at 22:32:27 UTC Sat Mar 21 2015 by admin
! NVRAM config last updated at 22:32:28 UTC Sat Mar 21 2015 by admin
version 12.4
hostname LabRouter
boot-start-marker
boot-end-marker
! card type command needed for slot/vwic-slot 0/3
logging message-counter syslog
no aaa new-model
clock timezone UTC -4
dot11 syslog
 --More--         ip source-route
ip cef
no ip domain lookup
ip name-server 172.16.2.140
ip name-server 172.16.0.1
no ipv6 cef
voice service voip
 allow-connections sip to h323
 allow-connections sip to sip
 fax protocol cisco
 sip
  registrar server expires max 600 min 60
voice register global
 max-dn 5
 max-pool 5
voice register pool  5
 id network 172.16.2.0 mask 255.255.255.128
 dtmf-relay rtp-nte cisco-rtp sip-notify
 codec g711ulaw
 no vad
voice-card 0
 --More--         !
application
 global
  service alternate Default
username admin password 0 cisco
archive
 log config
  hidekeys
interface GigabitEthernet0/0
 ip address 172.16.0.2 255.255.255.0
 duplex auto
 speed auto
interface GigabitEthernet0/1
 no ip address
 duplex auto
 speed auto
interface GigabitEthernet0/1.10
 encapsulation dot1Q 10
 ip address 172.16.1.1 255.255.255.0
 ip helper-address 172.16.2.140
interface GigabitEthernet0/1.20
 encapsulation dot1Q 20
 ip address 172.16.2.1 255.255.255.128
interface GigabitEthernet0/1.30
 encapsulation dot1Q 30
 ip address 172.16.2.129 255.255.255.128
interface GigabitEthernet0/1.40
 encapsulation dot1Q 40
 ip address 172.16.3.1 255.255.255.248
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 172.16.0.1
no ip http server
 --More--         no ip http secure-server
control-plane
voice-port 0/0/0
 timing hookflash-out 50
 timing guard-out 1000
 connection plar 1001
voice-port 0/0/1
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 172.16.2.10
ccm-manager config
mgcp
mgcp call-agent 172.16.2.10 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
 --More--         no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp profile default
dial-peer voice 999000 pots
 service mgcpapp
 port 0/0/0
dial-peer voice 999001 pots
 service mgcpapp
 port 0/0/1
dial-peer voice 1 pots
 description PSTN-emergency dial 9 first fxo 0
 destination-pattern 999.
 port 0/0/0
 forward-digits 3
dial-peer voice 2 pots
 description PSTN-emergency dial 9 first fxo 1
 port 0/0/1
dial-peer voice 3 pots
 description PSTN-emergency fxo 0
 destination-pattern 99.
 port 0/0/0
 forward-digits all
dial-peer voice 4 pots
 description PSTN-emergency fxo 1
 port 0/0/1
 forward-digits all
dial-peer voice 5 pots
 description Local PSTN
 destination-pattern 9[2-9]......
 port 0/0/0
 forward-digits 7
dial-peer voice 6 pots
 description Local PSTN FXO 1
 port 0/0/1
 forward-digits 7
dial-peer voice 7 pots
 description NANP FXO 0
 destination-pattern 91[2-9].........
 --More--          port 0/0/0
 forward-digits 11
dial-peer voice 8 pots
 description NANP FXO 1
 port 0/0/1
 forward-digits 11
dial-peer voice 868 pots
 service mgcpapp
 incoming called-number .
 direct-inward-dial
 port 0/0/0
dial-peer voice 869 pots
 service mgcpapp
 direct-inward-dial
 port 0/0/1
sip-ua
 registrar ipv4:172.16.2.1 expires 600
call-manager-fallback
 max-conferences 8 gain -6
 transfer-system full-consult
 ip source-address 172.16.2.1 port 2000
 max-ephones 6
 max-dn 12
 keepalive 20
line con 0
 exec-timeout 0 0
 password cisco
 logging synchronous
 login
line aux 0
line vty 0 4
 password cisco
 login local
 transport input telnet ssh
scheduler allocate 20000 1000
ntp master
end
Thanks in advance,
Martin.
5 Replies 5
Jaime Valencia
Debug your GW, do you see the calls hitting your GW???
java
if this helps, please rate
Hi Jaime,
Thanks for the reply. I don't know if I ran the correct debug command (debug voice dialpeer detail). The following is the logs on the router during an incoming call.
Mar 22 07:42:07.891: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=, Called Number=, Voice-Interface=0x492D4A04,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_PORT;
   Result=Success(0) after DP_MATCH_PORT; Incoming Dial-peer=999000
Mar 22 07:42:07.891: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerSPI:exit@6170
Thanks again for your assistance.
Run ccapi inout, but that debug does not show calling or called numbers, that would be a telco issue
java
I ran the ccapi inout  debug command and noticed that the dial-peer mgcp created (999000 and 999001) are being match as the incoming dial-peer.
June 7 15:14:12.037: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 0
June 7 15:14:12.037: //2254/EDF9F1C19458/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 2254 with tag 999000 to app "MGCPAPP"
When I shutdown this dial-peer I am able to receive calls with the following output from the debug command.
Result=Success(0); Incoming Dial-peer=40006 Is Matched
Result=Success(0); Outgoing Dial-peer=40006 Is Matched
40005  voip  up   up             1001               0  syst ipv4:172.16.2.46:506
40006  voip  up   up             0                  0  syst ipv4:172.16.2.46:506
40003  voip  up   up             1000               0  syst ipv4:172.16.2.48:506
40004  voip  up   up             1002               0  syst ipv4:172.16.2.45:506
40001  voip  up   up             0                  0  syst ipv4:172.16.2.48:506
40002  voip  up   up             0                  0  syst ipv4:172.16.2.45:506
However, if I leave this port shutdown and callmanager comes online this port is now seen as unregistered.
Is there a way for another dial-peer to be match as the incoming dial-peer so that the incoming calls will be successful?
Hi Martin,
Should the incoming dial peers be voip and not pots??
 service mgcpapp
 direct-inward-dial
 port 0/0/0
 service mgcpapp
 direct-inward-dial
 port 0/0/1
Thanks.
