07-14-2014 01:31 PM - edited 03-16-2019 11:24 PM
Hi team;
I have installed on the UCS cluster unity connection Version 8.6
The problem is when I save a recording for the greeter, not let me upload the file and then display a window for me to accept the SSL certificate, and have accepted the certificate but still not allowed to upload the file; This is the message of unity:
Unable to save recording due to SSL certificate error in CUCM 8.6
I found two possible solutions that did not work and they are these:
1 Error: Unable to save recording due to SSL certificate errors
problem
When you save a recording with Cisco Unity Connection 8.5, This Appears error message:
Unable to save recording due to SSL certificate errors.
Would you like to accept the SSL certificate for thissession and
attempt to save recording again
Solution
In order to resolve this issue, click Trust the certificate Appears When the certificate warning.
Then I found this solution but neither worked:
2. Https://tools.cisco.com/bugsearch/bug/CSCto92753
Someone who can help me or knows what the problem is?
Thanks for the space.
Solved! Go to Solution.
07-14-2014 03:27 PM
It is a bug with the last release of CUC 8.6, can you confirm your SU please? you can upload the prompt installing the following tool,
- Audio Text Manager.
http://ciscounitytools.com/Applications/CxN/ATM/ATM.html
http://ciscounitytools.com/Applications/CxN/ATM/Help/ConnectionAudiotextManager.htm
If it was useful please rate.
Regards.
07-14-2014 03:27 PM
Regards.
07-15-2014 07:08 AM
Hi Emmanuel;
Thanks for you help, today i go to install the audiotext manager and see how it works.
Excuseme but i not understand when me questions which is my SU?
As i find in unity?
Thanks and regards.
07-15-2014 08:24 AM
Hi Paolo,
The SU is your actual version, you can check it by cli with "show status" or opening the CUC administration page, the last SU for CUC 8.6 had an issue when you want to upload a prompt, I could upload the prompt only with the Audio Text Manager.
If you need anything else please let me know.
Regards.
07-30-2014 10:34 AM
Hi Emmanuel;
I could fix the fault with the method you mentioned.
Sorry to answer now but I was on medical leave.
Thanks again and good day.
07-30-2014 11:00 AM
Hi Paolo,
You´re welcome.
Regards.
05-31-2016 11:11 AM
07-30-2014 11:59 AM
It may be due to https://tools.cisco.com/bugsearch/bug/CSCuo66204 depending on your version.
