12-14-2010 03:24 PM - edited 03-16-2019 02:26 AM
Hi ,
We are using CUCM 7.1.5 ,with one H.323 gateway. I am able to make or receive external calls,but can not park or transfer the call to another extension.
Trying to transfer the call in the same partition. When the external call is connected, I see transfer button ,but when I press the button nothing happens. I can not dial the extension.
Any idea why this is happening ?. I can transfer or park if I get a call from internal numbers...
Thanks in advance,
12-14-2010 05:25 PM
I hope you are doing great,
Can you post an screenshoot of your problem.
Or just to doublecheck do you have the MTP required checked on the CUCM.
I also would like to confirm if you have an MRGL associated with the H.323 gateway.
Also if possible can you post the traces from the faulty call.
Luis Sandi.
12-16-2010 04:16 PM
We unchecked MTP required but this caused all the ougoing calls through Gateway failed. We had MRGL associated with Gateway. We dont have any Transcoder setup as we are using G711 codec throughout. and have only SCCP phones.
awaiting maintenace window to debug further.
12-15-2010 12:14 AM
it sounds that you have no media resources to transfer or park the call.
You need to add media resources to the device pool.
1. You must activate the "Cisco IP Media Streaming App" under Cisco Unified Serviceablity.
2. Under Cisco Unified CM Administration go to "Media Resources" >> Media Resource Group >> Add New.
You can look in the screenshot 1 and add the software media resources to the group
3. Then you must create a "Media Resource Group List" ("Media Resources" >> Media Resource Group List >> Add New)
Give the list a name and put the media resources inside that you created in step 2 and save the list (Screenshot 2).
4. Go to "System" >> Device Pools and add the Media Resource Group that you created in step 3 (Screenshot 3).
5. (optional) You can add the Media Resource List to the H.323 / SIP / MGCP Gateway under "Media Resource Group List" (Screenshot 4).
Kind regards,
Marcel Ammann
Please rate helpful posts!
12-15-2010 02:02 AM
I also have same problem in customer side but now he can trasfer but without MoH?
regards
Mohammed
12-15-2010 02:12 AM
Hello Mohammed,
do you use Multicast-MOH?
If you you use multicast you must enable multicast routing and use pim sparse-dense mode.
Also you must define a rendezvous point.
Here is some documentation for multicast routing:
http://www.cisco.com/en/US/tech/tk828/technologies_tech_note09186a0080094821.shtml
Kind regards,
Marcel Ammann
12-16-2010 02:51 PM
Hello Mohammed,
is the issue resolved?
Marcel
