Unable to use Phone Designer
jason9045
I'm running a brand-new installation of UCMBE 8 and I want to roll out Phone Designer for some of my users so they can customize their backgrounds. Trouble is, I can't get wallpaper to push out to the phone. I keep getting the message 'Personalization is disabled on the selected device' anytime I try.
I've set Phone Personalization to Enabled on the individual phones, in the Common Phone Profile, and even in the Enterprise Parameters, performing a reset each time. Still, I get that message. Is there something I'm missing in enabling personalization?
Jason
17 Replies 17
Pointing to a subscriber fixed our problem with Phone Designer message "personalization disabled" All our 7962 and 7942 Cisco IP phones on our CUCM 8.5 cluster are now able to use Phone Designer.
Thanks George!
good one George - THE CORRECT answer
Our Designer has always been pointed to the Subscriber.  As scheived  noted at that time, downgrading the phone firmware did fix our issue, so whichever works...roll with it.
