Beginner
Unable to view Cisco 8811 phone in CUCM cluster domain
I've two CUCM (CUCM1 and CUCM2) with System version: 9.1.2.12901-3 and about 500 phones (79xx) connected to a CUCM and I've no problem with them.
I'v just configured 20 x 8811 phones and register them in two CUCMs.
The latest cop files were installed and a clusterwide reboot but still not resolved my issue!
While the CUCM1 manage correctly the phones, the second CUCM2 get the following error message:
"Unmapped Exception /usr/local/cm/db/xml/xml/Phone_8811_SIP_display_instance.xml (No such file or directory)".
I've attached the show software packages from all CUCM.
Any ideas to resolve issue?
Michele
2 ACCEPTED SOLUTIONS
Michele, have you installed
Michele, have you installed the latest Device Pack on both the CM servers in order to add support for 8811 phones. If not, then that is something you should be doing first of all since just adding the FW will not help:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/compat/matrix/CMDP_BK_CCBDA741_00_cucm-device-package-compatibility-matrix/CMDP_BK_CCBDA741_00_cucm-device-package-compatibility-matrix_chapter_00.html#CMDP_RF_C8E075E1_00
Deepak
Hall of Fame Cisco Employee
A DevPack has to be installed
A DevPack has to be installed in ALL of the servers in the cluster, and a cluster reboot is MANDATORY if you're installing the DevPack to add support for new endpoints.
java
if this helps, please rate
8 REPLIES 8
Deepak
Highlighted
Beginner
I Deepak,
I Deepak,
I don't installed the Device Pack on both CUCMs. I'll do it, but how is it possible that CUCM1 works find with 8811 phones.
can you paste the output of "show version active" from both cluster as the file attached is not very clear.
JB
Beginner
Thank you guys,
Thank you guys,
I veirified that the device pack is installed in CUCM1 and it is not true what I said before.
I hope that the problem will be resolved by installing the Device Pack in the second CUCM.
I'm forced to restart all the CUCMs or just one where I will install the Device pack ?
thanks a lot
Michele.
you can keep the below link for reference
Link Summery:
Table 5 Cisco Unified IP Phone 8800 Series
Device Type
Device Release
Unified CM 11.0(1)
Unified CM 10.5(2)
Unified CM Device 9.1(2)
Unified CM Device 8.6(2)
8845
Caveat Resolution
cmterm-devicepack11.0.1
Oct. 2, 2015
cmterm-devicepack10.5.2
Oct. 2, 2015
cmterm-devicepack9.1.2
Oct. 2, 2015
Not Applicable
8845 and 8865
11.0(1)
Jan 7, 2016
Jan 7, 2016
Jan 7, 2016
Not Applicable
10.3(2)
July 30, 2015
Aug 4 , 2015
July 30 , 2015
cmterm-devicepack8.6.2
Aug 4 , 2015
8811, 8841, 8851, 8851NR, and 8861
11.0(1)
Jan 7, 2016
Jan 7, 2016
Jan 7, 2016
Not Applicable
10.3(1)
Native in UCM
May 29, 2015
May 29, 2015
May 29, 2015
Also device pack needs to be installed on all nodes and a cluster reboot is mandate.
JB
java
Beginner
I've installed in the CUCM2
I've installed in the CUCM2 the same device pack just loaded in the CUCM1 and a restart the CUCM2.
Now CUCM1 work find and it recognize the 8811 phones.
Best Regards.
Michele
normally the error would show if there was an issue with device pack installation on CUCM.
from both Clusters and every node can you provide
"file view install system-history.log"
JB
Content for Community-Ad
August's Community Spotlight Awards
