11-30-2011 11:04 PM - edited 03-16-2019 08:19 AM
I have about 9524 unassigned directory numbers on my cluster. So I just wanted to know, is that taking up the space on the disk. It should be deleted or not ? Please advise.
11-30-2011 11:22 PM
what is your CUCM version?
I'd check if any of those are being used for call forward (for example when employee leaves company) and delete the rest just for house keeping.
11-30-2011 11:48 PM
Its CUCM 6.1.3.x version.
I see none of this DN's are associated with any end devices/device profiles. So how can the call forward work even if it is setup for any of this DN's.
Any idea, if this 9524 unassigned DN's takes up huge space on the disk even though we are not using it.
12-01-2011 12:08 AM
It does not matter if DN is assigned or unassigned.
CCM 5 and later has "Active" flag to include unassigned DNs into routing table and it is checked by default.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/5_0_1/ccmsys/a03dn.html#wp1057487
DNs do not take any considerable disk space but they definitely consume system resources like CPU and RAM.
12-01-2011 12:14 AM
So wat do you suggest ? Is it good to clean up unassigned DNs or leave it as it is.
12-01-2011 12:20 AM
12-01-2011 12:27 AM
There are about 9000+ unassigned DNs on the cluster. Is there an easy way to cross check this DNs if this are call forwarded as it would be difficult to check one by one. Please advise.
12-01-2011 12:32 AM
Use BAT to export DNs to csv file and analyse call forward fields.
Or you could use SQL queries "run sql" via SSH session, but I can't help you with those.
12-01-2011 12:35 AM
Ok, thanks for all your help.
