701
Highlighted
Beginner
Unbrick 7975G
I got a 7975G that was interupted during a firmware upgrade.  Therefore, the screen is disabled and I cannot see to get it to come back on or upgrade.  It will get an ip address from the TFTP but it does not appear to try to download anything from the TFTP.  And even though it has an ip address I cannot get to the phone's web page.  Can anyone help me figure out how to get the screen back on and get this phone back up and working?
Everyone's tags (1)
11 REPLIES 11
Highlighted
Unbrick 7975G
Hi.
Did you try to perform factory reset procedure?
After that you can try to upload the firmware through a tftp in a windows or linux machine.
Let me know
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
Highlighted
Beginner
Unbrick 7975G
Yes, I have tried the factory reset procedure several times.  Since I can't see anything on the screen I can't see if there are any prompts for me to do.  Yes I have tried a TFTP server on my windows pc and pointed the option 150 to that ip address.  According to the logs in the tftp the phone is not trying to download anything.
Highlighted
Re: Unbrick 7975G
Can you see, at least, if phone is getting ipaddress?
Cheers
Carlo
Highlighted
Beginner
Unbrick 7975G
If you look at what I said in the first post, yes I can tell from the dhcp server that it is getting an ip address and I can ping the ip address from my pc.  I can't get to the web page of the phone though.  And there is no activity on the TFTP server.
Highlighted
Beginner
Unbrick 7975G
Can anyone else help me with this.  Specifically it would help if there is a way to enable the screen again.
Highlighted
Enthusiast
Unbrick 7975G
Are you sure the phone is actually getting the TFTP server settings?  What are you using for handing out DHCP to the phone?  If you're using something like Tftpd64/32 for DHCP, the option 150 doesn't work right in there and you have to use Option 66.
Highlighted
Beginner
Unbrick 7975G
No, I'm not sure if it is getting the TFTP because I can't see the screen or the web page of the phone.  I'm using a 871 router for the DHCP and then using TFTPd64 for the TFTP on my pc.  I plug the pc into the same 871 and it gets an ip address and can ping the phone.
Highlighted
Enthusiast
Unbrick 7975G
So the TFTPd64 is most likely the issue here.  How did you define the TFTP server option in TFTPd64?  As option 150 or 66?  Check out http://reboot.pro/topic/2048-tftpd32-with-cisco-phones-option-150/
Highlighted
Beginner
Unbrick 7975G
Thanks for helping Brian,
Again, I am not using the DHCP on the TFTPD64 but I'm using the Cisco 871 router for the DHCP.  It is currently defined as option 150 ip x.x.x.x.  I am using the TFTPd64 only as the TFTP server to try to get this phone up.  I have the firmware files downloaded and set as the base folder for the TFTP.  Do you think I need to set option 66 on the DHCP on the 871?  Any other suggestions?
Highlighted
Enthusiast
Unbrick 7975G
Ah okay.  So if you connect a PC to the 871, can you download files from your PC running TFTPd64 using a TFTP client?  Does a packet capture show any traffic at all from the phone to your PC running TFTP?
Highlighted
Beginner
Unbrick 7975G
Yes, I can download files using the TFTP client to the 871.  I havent' tried to take a packet capture yet. I'll try to do that.  Any other suggestions?
Content for Community-Ad
Future of Work Virtual Summit Day 5
Cisco COVID-19 Survey
