Unified Communications Manager 8.5, Directory not showing up (Wrong Directory URL)
I try to go to my directory, but I'm getting a "host not found"
I’m checking the network configuration of the phone.
Under the Phone network config
The Directorys URL is pointing to the wrong address
Right now it is pointing to https://10.200.0.17:8080/ccmcip/xmldirectory.jsp
And it should be pointing to 10.11.0.7:8080/ccmcip/xmldirectory.jsp
Where do I change this setting?
Thanks!
-M
acampbell
Advocate
Advocate
M.
Look under CUCM ADmin --> System --> Enterprise Parameters..
You should find the directory URL there
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
acampbell
Advocate
Advocate
M.
Alex.
Recognize Your Peers
