11-04-2011 05:40 AM - edited 03-16-2019 07:52 AM
Dear all
we have setup a high availability CUPS .
We are wondering if the primary server goes down , and the users trying to login via CUPC then what happen ?
If they use the ip for publisher then if the publisher is down what they have to type for login?the ip of the subscriber?
is any other option that the users can know only one domain or only one ip for the login via CUPC?
Solved! Go to Solution.
11-04-2011 06:33 AM
You shouldn't have to change IP address for logon. As explained, CUPC will handle it automatically.
11-04-2011 06:06 AM
When CUPC logs in the first time, it downloads a list of servers. This list will be stored locally on the client PC and updated on every logon.
When the first server on the list is unavailable, CUPC will try the next server.
Hope this answers your question.
Michael
11-04-2011 06:24 AM
Hi Michael
I have logged in the CUPC succesfully the first time using the ip of the publisher.Then i rebooted the publisher and i tried to logging with the ip of the subscriber unfortunatelly with out success. IF the publisher is down then the clients for CUPC can use the ip for publisher?
Do you have any idea?
i am using load balancing for the users assignment and when i rebooted the publisher all the users then associated with the subscriber
Also what is the needs for the srv if you know? i have to configure it for HA or is not neccessary
regards
11-04-2011 06:33 AM
11-04-2011 06:34 AM
Thank you Michael
