Uniform dialing pattern
Sanoop N V
Beginner
Beginner
Hi All,
I would like to know whether it is possible to deploy uniform dialing across all regions in following manner:
All Call Types (Local,LD or Int) ==> 9 + County Code + Number
My concern here is, let's say I am in Russia
I dial Japan (International call) using 9+ 81 + xxxxxxxxx
I dial St.Petersonburg(LD) using 9 + 812 + xxxxxxxx
How do you distinguish LD & Int and route to service provider. I have almost 20 offices spread across regions. this is one e.g. . Similarly I belive there are lot of such instances of dial plan overlapping.
Can you please advice how to implement the same
Thanks!
Sanoop
Dennis Mink
Advisor
Advisor
Deploy E164 mate! that way there should not be any overlapping,  It also greatly simplifies your dialplan in conjunction with using Local Route Groups
check my post out on this topic:
http://ciscoshizzle.blogspot.com.au/2012_05_01_archive.html
Please remember to rate useful posts, by clicking on the stars below.
Chris Deren
Hall of Fame Master Hall of Fame Master
Hall of Fame Master
Include the country access code, i.e. 00 or 011 depending what country you are dialing from.
HTH,
Chris
Dennis Mink
Advisor
Advisor
Thank you Dennis!
This is very helpfull...
Thanks!
Sanoop
Recognize Your Peers
