Unity 11.5.1 time incorrect
carlos15
Unity 11.5.1 time off by 14 minutes. CLI on the server confirms the incorrect time, but the Timezone is set correctly. Please advise.
Chris Deren
What does "utils ntp status" show?
Aha, I think that might be the issue:
admin:utils ntp status
ntpd (pid 9459) is running...
remote refid st t when poll reach delay offset jitter
10.14.0.240 .INIT. 16 u - 1024 0 0.000 0.000 0.000
unsynchronised
polling server every 8 s
Current time in UTC is : Thu Jan 2 22:11:37 UTC 2020
Current time in America/Chicago is : Thu Jan 2 16:11:37 CST 2020
Thank you!
This ntp address is incorrect. Please let me know where I would be able to change this setting
Thanks again!
Please disregard the portion of my last post asking where to change the ntp setting. I found it.
Thank you very much for your help.
use "utils ntp server ?" will give you options to add, delete, list. You may have to issue "utils ntp restart" afterwards.
HTH, please rate all useful posts!
Chris
