Unity 4 Auto Attendant Configuration
Surendra Singh
i never configured an Auto Attendant in Unity 4.0(4)SR1 to be exact.
Does anyone have a guide i can follow?
Surendra
Jaime Valencia
There are no guides for AA, the theory has always been the same in CUC and Unity across all versions, it's just call handlers and caller input.
java
if this helps, please rate
great thanks much. appreciate it.
i am familiar with the configuration for the later versions.
thanks again.
One issue I am coming accross is that for the Caller Input in one of my Call handlers, I need to send the call to a Hunt Group, but there  is no option for that.
i suspect there is a workaround for this. Can you assist?
