Unity 7 Call Handler Extension Dialing
balitewiczp
Level 2
Level 2
Call Handler is set to allow callers to dial extensions during the greeting. However, unity sends directly to the persons greeting , rather than transferring to phone. Is this changeable? thanks
Jaime Valencia
Yes, go to the subscriber(s) and under transfer settings configure "Yes, ring subscriber" or "yes, ring subscriber at this phone:"
java
if this helps, please rate
java
yes, this helped out alot. thanks
