08-02-2011 11:00 AM - edited 03-16-2019 06:16 AM
I'm getting replication status error message # 3 between our Unity pub and Sub servers
I have run the following form the pub
Utils dbreplication status
Copy current replication file and receive the error
Pub status is 2 active local
Sub status is 3 active connected
I need assistance to resolve the replication issue
Current environment
Unity 8.5.1.10000-206
Thx
08-02-2011 11:07 AM
A database status of 3 translates to the following state:
3 (Broken) — Replication failed during setup and is not working
For this state, the first thing to do is to reboot the Subscriber server and see if the replication issue is resolved. Have you done this yet?
Hailey
Please rate helpful posts!
08-02-2011 11:27 AM
Yes i did , however no luck
08-02-2011 11:33 AM
Check out the following guide...it refers to CUCM but the procedures for troubleshooting the DB are the same:
08-02-2011 12:04 PM
I tried everything with no luck . Still the same error message 3
08-02-2011 01:37 PM
If you have performed a repair as well as a reset and verified host name and other settings as per the document and replication is still broken, then it would be in your best interest to open a TAC case so that you can receive some hands-on assistance in troubleshooting and resolving the issue.
Hailey
08-02-2011 01:59 PM
I'm guessing when you say you tried everything, you have already verified DNS? [if your installation is using DNS.]
