383
Marcin Brzeski
Beginner
Unity 8.5, how to record voice messages to CD media
Hi All,
One of our departments for security purposes would like to store recorded voice messages on CD. How can extract messages from particular mail box in Unity and record in to CD in .wav format?
Thank you,
Marcin
2 REPLIES 2
Marcin Brzeski
Beginner
Apparently there is a easy way to access the voice messages via the Cisco Unity Connection Web Inbox, which is enabled by default in Unity 8.5. What credentials do I need to use to log in to this service. I've tried my Display Name from Unity and PIN but it doesn't work.
Marcin
If you are LDAP integrate you use the LDAP credentials, if you are not LDAP integrated then you use the web credentials which can be changed per user, and which are drivern by the web authentication rule.
HTH,
Chris
Create
Recognize Your Peers
Content for Community-Ad
