Highlighted
Beginner
Unity Auto Attendant - Dial by number
Unity Version 11.5
We have an Auto Attendant set up for the main phone number of our business. Callers are able to dial the extension of a party from this menu if they know it, but those calls go directly to voicemail rather than ringing the line. How do I transfer to the line rather than directly to the mailbox.
1 ACCEPTED SOLUTION
Highlighted
Hall of Fame Cisco Employee
Re: Unity Auto Attendant - Dial by number
Look at what Chris mentioned for call routing, and since the alternate transfer rule is enabled, then that's the number to which it will transfer the call (assuming proper call routing allows you to place the call)
java
if this helps, please rate
10 REPLIES 10
Highlighted
Change the transfer rules of every user to do that
java
Beginner
It looks like I already have it set to transfer to extension
Highlighted
Is that the specific user you're testing with?
That setting is PER user.
Are there other transfer rules enabled?
java
Highlighted
Beginner
Yes this is a specific user I am testing with. The screenshot is the "Standard" transfer rule. The "Alternate" rule is also enabled with the same settings but a different number.
Highlighted
Hall of Fame Master
Does the CSS applied to your Unity SIP trunk (if using SIP integration) or SCCP voicemail ports has access to proper partition assigned to the extension of the device?
Are your restriction tables in Unity allowing these calls?
Highlighted
java
Highlighted
Beginner
The css looks correct. I disabled the alternate transfer rule and it transfers properly as a live call. Can the user enable transfer rules or is that only done by admin? I'm not sure where the alternate rule came from.
Highlighted
Enthusiast
There's a setting in the Greeting, "Allow Transfers to Numbers Not Associated with Users or Call Handlers", is that enabled?
Edit - see it's fixed anyway,
Highlighted
Beginner
I did not have that setting enabled for this specific user, I turned it on and turned the alternate transfer back on to test it. Calls still go directly to voicemail when the alternate transfer rule is enabled.
Highlighted
That setting is not applicable for what you were facing.
That setting simply allows you to dial DNs that do not exist in CUC. If you leave it unchecked, the transfers are limited to DNs that do exist in CUC.
java
