I am trying to use Bulk Edit to change a few settings in a bunch of subscribers at the same time. Some of the setting I want to change are:
Greeting options
- Send caller to
- Repromt the user after this...
- Number of times to repromt
Caller Input options
- Unchecked "allow users to ...."
I don't get any errors but the settings are not applied. Any idea what's happening?
Thanks in advanced. RG
What version of Unity?
We are using Unity 7.1
Are you able to make these changes manually on the subscribers? I would verify that there are no DB issues.
