04-03-2013 01:51 AM - edited 03-16-2019 04:34 PM
I did migration for unity from 1.x to 9.x , and the backup it is done by cobra tool and successfully but still the ELM license steps are not done at enterprise manager
my question is :
- when i go to system call handlers > greeting (english or arabic ...) > standard> i cant play or record the wav file , it is hidden (please see the attached files)
Do you think this problem from ELM license is not done ?
i tried in chrome browers and firefox and internet expolere but the same problem it is hidden button so i cant make play or record or upload wav files
how to solve this issue ?
Solved! Go to Solution.
04-03-2013 09:07 AM
Hi there,
Here are the listed bug conditions;
Conditions:
PC running Mozilla or Internet Explorer browser with JRE 7 (1.7.x)
So, you'll need to downgrade as nicely suggested by Yosh & Chris
Just search for;
"download java jre 6"
in your favourite search engine.
Cheers!
Rob
"Hours are like diamonds, don't let them waste
Time waits for no one, no favors has he"
- Stones
04-03-2013 06:09 AM
Any updates plz ?
04-03-2013 06:13 AM
It does not look like the greeting is enabled to play personal recorded greeting, can you check that to see if that helps?
Check "greeting enabled with not end date" and "my personal recording" radio buttons.
Check Usually this type of issue is a java issue, but I don't know if license would prevent it.
Chris
04-03-2013 06:23 AM
I agree with Chris this is usually a Java issue. You can try updating your Java and or using a different explorer.
Yosh
04-03-2013 07:42 AM
regardin the java version :
version 7 update 17 (build 1.7.0) , i updated before two days
04-03-2013 06:28 AM
Hi there,
I agree with Chris and Yosh here (+5 folks )
There is also this bug related to Java;
CSCuf51788 - Media Master Popups do not work with JRE 7 and Mozilla / IE
Description
Details
9.1(0.1),8.6(2)
Status:
Open
Last Modified:
Mar 21,2013
Product:
Cisco Unity Connection
Platform:
Dependent
Severity:
3 - moderate
Cheers!
Rob
- Stones
04-03-2013 07:38 AM
Hi rob
thanks for your reply
i tried in Inter explorer and chromo and Firefox , but all the same problem
regarding Workaround , it is not cleared for me , what i will do exactly to solve this issue plz ?
thanks
04-03-2013 07:42 AM
04-03-2013 07:43 AM
Dear Rob
regardin the java version in my laptop is :
04-03-2013 07:45 AM
Have you tried from a different pc or laptop to rule out any java security policies.
Yosh
04-03-2013 07:57 AM
Unity Connection does not work with Java 7, you will need to downgrade to Java 6 for it to work, no way around it as far as I know.
HTH,
Chris
04-03-2013 09:07 AM
Hi there,
Conditions:
Just search for;
Cheers!
Rob
- Stones
04-04-2013 01:43 AM
Dear Rob
i attached some files
i did downgrade to ver 6 but still the same problem
and i when i go to the greeting > enaglish/arabic> i can play or record or upload file
but i go greeting> englishor arabic > standard > the button it is hidden
what you think the problem ?
04-04-2013 10:34 PM
Hi Rob
Any updates plz ?
thanks
