08-27-2014 08:14 AM - edited 03-16-2019 11:55 PM
Newly setup CUCM and UC 10.5, I have a translation rule on a CUBE that sends all inbound calls to a certain number to a system call handler on Unity Connection. Calls come from a SIP trunk provider. UC is integrated to CUCM using SCCP.
The inbound call is sent to the call handler, I am prompted to pick a single number option or enter an extension. Picking either of these results in a transfer, the transfer rings the proper phone but when I pick up the called phone the calling party can't hear me, rather they just continue to hear the music on hold. I can however hear the calling party audio on the called phone.
I can't figure out why the music on hold doesn't stop after the called phone is picked up.
Additional Details:
I'm very confused at this point, any advice is appreciated.
08-27-2014 09:22 AM
What codec is your call from the SIP provider? Can you post your configuration?
08-27-2014 10:29 AM
What about routing information? I have seen where the signaling is working but the RTP path is not established due to not having a route.
08-27-2014 10:37 AM
Should have mentioned this before, but thank you for the help, it is appreciated!
Routing between CUBE and CUCM + UC seems okay, I can ping the CUBE from CUCM and UC, and vise versa.
Additionally there are also no ACL's into the voice VLAN, and the only ACL's on the router are configured to allow all SIP traffic from the provider, enabling logging of all dropped packets indicates there is no packets being dropped at CUBE due to an ACL.
08-28-2014 07:38 AM
Did a capture by enabling SPAN on the PC port of the phone the call is transferred to through UC, I see the SIP call control messages and then I start seeing RTP audio packets between the phone's IP address and the IP address of CUBE.
I take it this points to the issue being MOH not being stopped on the calling side than really being a one way audio issue...?
08-28-2014 07:43 AM
In addition to this the MOH isn't coming from CUCM, when I disable the MOH server on CUCM the MOH is still there. So the MOH is coming from UC somewhere, almost like the call is stuck in some queue waiting to be transferred.
08-28-2014 08:06 AM
Hi.
Can you please activate a debug ccsip message on cube and post the output of a non working call?
Please let us know
Carlo
08-28-2014 08:23 AM
Note the following: I have replaced the calling parties number with 11111111111, and I have replaced the called parties number with 2222222222.
Let me know if you need anything else.
As requested:
039403: Aug 28 09:08:57.477 MST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Received: INVITE sip:2222222222@184.71.242.2:5060 SIP/2.0 Via: SIP/2.0/UDP 208.43.85.75:5060;branch=z9hG4bK0f298422;rport From: "1111111111" <sip:1111111111@208.43.85.75>;tag=as40beef80 To: <sip:2222222222@184.71.242.2:5060> Contact: <sip:1111111111@208.43.85.75> Call-ID: 150b67c355dd6cc774ad4bca7944ca5b@208.43.85.75 CSeq: 102 INVITE User-Agent: Asterisk PBX Max-Forwards: 70 Remote-Party-ID: "1111111111" <sip:1111111111@208.43.85.75>;privacy=off;screen=no Date: Thu, 28 Aug 2014 15:08:57 GMT Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY Supported: replaces Content-Type: application/sdp Content-Length: 361 v=0 o=root 1022 1022 IN IP4 208.43.85.75 s=session c=IN IP4 208.43.85.75 b=CT:384 t=0 0 m=audio 18910 RTP/AVP 0 8 101 a=rtpmap:0 PCMU/8000 a=rtpmap:8 PCMA/8000 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-16 a=silenceSupp:off - - - - a=ptime:20 a=sendrecv m=video 18520 RTP/AVP 34 99 a=rtpmap:34 H263/90000 a=rtpmap:99 H264/90000 a=sendrecv 039404: Aug 28 09:08:57.485 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg: Sent: SIP/2.0 100 Trying Via: SIP/2.0/UDP 208.43.85.75:5060;branch=z9hG4bK0f298422;rport From: "1111111111" <sip:1111111111@208.43.85.75>;tag=as40beef80 To: <sip:2222222222@184.71.242.2:5060> Date: Thu, 28 Aug 2014 15:08:57 GMT Call-ID: 150b67c355dd6cc774ad4bca7944ca5b@208.43.85.75 CSeq: 102 INVITE Allow-Events: telephone-event Server: Cisco-SIPGateway/IOS-15.2.4.M6a Content-Length: 0 039405: Aug 28 09:08:57.489 MST: //6872/1164A17192EE/SIP/Msg/ccsipDisplayMsg: Sent: INVITE sip:3000@10.135.191.12:5060 SIP/2.0 Via: SIP/2.0/UDP 172.18.0.1:5060;branch=z9hG4bK1B6512A3 Remote-Party-ID: "1111111111" <sip:1111111111@172.18.0.1>;party=calling;screen=no;privacy=off From: "1111111111" <sip:1111111111@sip1.ixica.com>;tag=A7CF398-21B1 To: <sip:3000@10.135.191.12> Date: Thu, 28 Aug 2014 15:08:57 GMT Call-ID: 11667682-2DFC11E4-92F4CC10-65967311@172.18.0.1 Supported: 100rel,timer,resource-priority,replaces,sdp-anat Min-SE: 1800 Cisco-Guid: 0291807601-0771494372-2465123344-1704358673 User-Agent: Cisco-SIPGateway/IOS-15.2.4.M6a Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER CSeq: 101 INVITE Timestamp: 1409238537 Contact: <sip:1111111111@172.18.0.1:5060> Expires: 180 Allow-Events: telephone-event Max-Forwards: 69 Content-Type: application/sdp Content-Disposition: session;handling=required Content-Length: 393 v=0 o=CiscoSystemsSIP-GW-UserAgent 8203 267 IN IP4 172.18.0.1 s=SIP Call c=IN IP4 172.18.0.1 t=0 0 m=audio 18666 RTP/AVP 0 101 c=IN IP4 172.18.0.1 a=rtpmap:0 PCMU/8000 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-16 a=ptime:20 m=video 18668 RTP/AVP 34 119 c=IN IP4 172.18.0.1 a=rtpmap:34 H263/90000 a=fmtp:34 CIF=1 a=rtpmap:119 H264/90000 a=fmtp:119 profile-level-id=000000 039406: Aug 28 09:08:57.497 MST: //6872/1164A17192EE/SIP/Msg/ccsipDisplayMsg: Received: SIP/2.0 100 Trying Via: SIP/2.0/UDP 172.18.0.1:5060;branch=z9hG4bK1B6512A3 From: "1111111111" <sip:1111111111@sip1.ixica.com>;tag=A7CF398-21B1 To: <sip:3000@10.135.191.12> Date: Thu, 28 Aug 2014 15:08:57 GMT Call-ID: 11667682-2DFC11E4-92F4CC10-65967311@172.18.0.1 CSeq: 101 INVITE Allow-Events: presence Content-Length: 0 039407: Aug 28 09:08:57.505 MST: //6872/1164A17192EE/SIP/Msg/ccsipDisplayMsg: Received: SIP/2.0 180 Ringing Via: SIP/2.0/UDP 172.18.0.1:5060;branch=z9hG4bK1B6512A3 From: "1111111111" <sip:1111111111@sip1.ixica.com>;tag=A7CF398-21B1 To: <sip:3000@10.135.191.12>;tag=100429~dc062259-9b0a-4df2-b05d-e4de329c1980-28525423 Date: Thu, 28 Aug 2014 15:08:57 GMT Call-ID: 11667682-2DFC11E4-92F4CC10-65967311@172.18.0.1 CSeq: 101 INVITE Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY Allow-Events: presence Server: Cisco-CUCM10.5 Supported: X-cisco-srtp-fallback Supported: Geolocation P-Asserted-Identity: "Cisco Unity" <sip:2000@10.135.191.12> Remote-Party-ID: "Cisco Unity" <sip:2000@10.135.191.12>;party=called;screen=yes;privacy=off Contact: <sip:3000@10.135.191.12:5060> Content-Length: 0 039408: Aug 28 09:08:57.509 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg: Sent: SIP/2.0 180 Ringing Via: SIP/2.0/UDP 208.43.85.75:5060;branch=z9hG4bK0f298422;rport From: "1111111111" <sip:1111111111@208.43.85.75>;tag=as40beef80 To: <sip:2222222222@184.71.242.2:5060>;tag=A7CF3A8-B36 Date: Thu, 28 Aug 2014 15:08:57 GMT Call-ID: 150b67c355dd6cc774ad4bca7944ca5b@208.43.85.75 CSeq: 102 INVITE Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER Allow-Events: telephone-event Remote-Party-ID: "Cisco Unity" <sip:2000@184.71.242.2>;party=called;screen=yes;privacy=off Contact: <sip:3000@184.71.242.2:5060> Server: Cisco-SIPGateway/IOS-15.2.4.M6a Content-Length: 0 039409: Aug 28 09:08:57.617 MST: //6872/1164A17192EE/SIP/Msg/ccsipDisplayMsg: Received: SIP/2.0 200 OK Via: SIP/2.0/UDP 172.18.0.1:5060;branch=z9hG4bK1B6512A3 From: "1111111111" <sip:1111111111@sip1.ixica.com>;tag=A7CF398-21B1 To: <sip:3000@10.135.191.12>;tag=100429~dc062259-9b0a-4df2-b05d-e4de329c1980-28525423 Date: Thu, 28 Aug 2014 15:08:57 GMT Call-ID: 11667682-2DFC11E4-92F4CC10-65967311@172.18.0.1 CSeq: 101 INVITE Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY Allow-Events: presence, kpml Supported: replaces Server: Cisco-CUCM10.5 Supported: X-cisco-srtp-fallback Supported: Geolocation Session-Expires: 1800;refresher=uas Require: timer P-Asserted-Identity: "Cisco Unity" <sip:2000@10.135.191.12> Remote-Party-ID: "Cisco Unity" <sip:2000@10.135.191.12>;party=called;screen=yes;privacy=off Contact: <sip:3000@10.135.191.12:5060>;isFocus Content-Type: application/sdp Content-Length: 408 v=0 o=CiscoSystemsCCM-SIP 100429 1 IN IP4 10.135.191.12 s=SIP Call c=IN IP4 10.135.191.13 b=TIAS:64000 b=CT:64 b=AS:64 t=0 0 m=audio 16838 RTP/AVP 0 101 a=ptime:20 a=rtpmap:0 PCMU/8000 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-15 m=video 0 RTP/AVP 31 34 96 97 a=rtpmap:31 H261/90000 a=rtpmap:34 H263/90000 a=rtpmap:96 H263-1998/90000 a=rtpmap:97 H264/90000 a=content:main a=inactive 039410: Aug 28 09:08:57.621 MST: //6872/1164A17192EE/SIP/Msg/ccsipDisplayMsg: Sent: ACK sip:3000@10.135.191.12:5060 SIP/2.0 Via: SIP/2.0/UDP 172.18.0.1:5060;branch=z9hG4bK1B66BC6 From: "1111111111" <sip:1111111111@sip1.ixica.com>;tag=A7CF398-21B1 To: <sip:3000@10.135.191.12>;tag=100429~dc062259-9b0a-4df2-b05d-e4de329c1980-28525423 Date: Thu, 28 Aug 2014 15:08:57 GMT Call-ID: 11667682-2DFC11E4-92F4CC10-65967311@172.18.0.1 Max-Forwards: 70 CSeq: 101 ACK Allow-Events: telephone-event Content-Length: 0 039411: Aug 28 09:08:57.625 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg: Sent: SIP/2.0 200 OK Via: SIP/2.0/UDP 208.43.85.75:5060;branch=z9hG4bK0f298422;rport From: "1111111111" <sip:1111111111@208.43.85.75>;tag=as40beef80 To: <sip:2222222222@184.71.242.2:5060>;tag=A7CF3A8-B36 Date: Thu, 28 Aug 2014 15:08:57 GMT Call-ID: 150b67c355dd6cc774ad4bca7944ca5b@208.43.85.75 CSeq: 102 INVITE Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER Allow-Events: telephone-event Remote-Party-ID: "Cisco Unity" <sip:2000@184.71.242.2>;party=called;screen=yes;privacy=off Contact: <sip:2222222222@184.71.242.2:5060> Supported: replaces Supported: sdp-anat Server: Cisco-SIPGateway/IOS-15.2.4.M6a Supported: timer Content-Type: application/sdp Content-Disposition: session;handling=required Content-Length: 292 v=0 o=CiscoSystemsSIP-GW-UserAgent 7259 1403 IN IP4 184.71.242.2 s=SIP Call c=IN IP4 184.71.242.2 t=0 0 m=audio 18662 RTP/AVP 0 101 c=IN IP4 184.71.242.2 a=rtpmap:0 PCMU/8000 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-16 a=ptime:20 m=video 0 RTP/AVP 34 c=IN IP4 184.71.242.2 039412: Aug 28 09:08:57.709 MST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Received: ACK sip:2222222222@184.71.242.2:5060 SIP/2.0 Via: SIP/2.0/UDP 208.43.85.75:5060;branch=z9hG4bK1f4d545e;rport From: "1111111111" <sip:1111111111@208.43.85.75>;tag=as40beef80 To: <sip:2222222222@184.71.242.2:5060>;tag=A7CF3A8-B36 Contact: <sip:1111111111@208.43.85.75> Call-ID: 150b67c355dd6cc774ad4bca7944ca5b@208.43.85.75 CSeq: 102 ACK User-Agent: Asterisk PBX Max-Forwards: 70 Remote-Party-ID: "1111111111" <sip:1111111111@208.43.85.75>;privacy=off;screen=no Content-Length: 0 039413: Aug 28 09:09:03.221 MST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Received: INVITE sip:1111111111@172.18.0.1:5060 SIP/2.0 Via: SIP/2.0/UDP 10.135.191.12:5060;branch=z9hG4bKc1b5396f4b2 From: <sip:3000@10.135.191.12>;tag=100429~dc062259-9b0a-4df2-b05d-e4de329c1980-28525423 To: "1111111111" <sip:1111111111@sip1.ixica.com>;tag=A7CF398-21B1 Date: Thu, 28 Aug 2014 15:09:03 GMT Call-ID: 11667682-2DFC11E4-92F4CC10-65967311@172.18.0.1 Supported: timer,resource-priority,replaces Cisco-Guid: 0291807601-0771494372-2465123344-1704358673 User-Agent: Cisco-CUCM10.5 Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY CSeq: 101 INVITE Max-Forwards: 70 Expires: 180 Allow-Events: presence Supported: X-cisco-srtp-fallback Supported: Geolocation Session-Expires: 1800;refresher=uac Min-SE: 1800 P-Asserted-Identity: "Cisco Unity" <sip:2000@10.135.191.12> Remote-Party-ID: "Cisco Unity" <sip:2000@10.135.191.12>;party=calling;screen=yes;privacy=off Contact: <sip:3000@10.135.191.12:5060>;isFocus Content-Type: application/sdp Content-Length: 414 v=0 o=CiscoSystemsCCM-SIP 100429 2 IN IP4 10.135.191.12 s=SIP Call c=IN IP4 0.0.0.0 b=TIAS:64000 b=CT:64 b=AS:64 t=0 0 m=audio 16838 RTP/AVP 0 101 a=ptime:20 a=rtpmap:0 PCMU/8000 a=inactive a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-15 m=video 0 RTP/AVP 31 34 96 97 a=rtpmap:31 H261/90000 a=rtpmap:34 H263/90000 a=rtpmap:96 H263-1998/90000 a=rtpmap:97 H264/90000 a=content:main a=inactive 039414: Aug 28 09:09:03.229 MST: //6872/1164A17192EE/SIP/Msg/ccsipDisplayMsg: Sent: SIP/2.0 100 Trying Via: SIP/2.0/UDP 10.135.191.12:5060;branch=z9hG4bKc1b5396f4b2 From: <sip:3000@10.135.191.12>;tag=100429~dc062259-9b0a-4df2-b05d-e4de329c1980-28525423 To: "1111111111" <sip:1111111111@sip1.ixica.com>;tag=A7CF398-21B1 Date: Thu, 28 Aug 2014 15:09:03 GMT Call-ID: 11667682-2DFC11E4-92F4CC10-65967311@172.18.0.1 CSeq: 101 INVITE Allow-Events: telephone-event Server: Cisco-SIPGateway/IOS-15.2.4.M6a Content-Length: 0 039415: Aug 28 09:09:03.229 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg: Sent: INVITE sip:1111111111@208.43.85.75 SIP/2.0 Via: SIP/2.0/UDP 184.71.242.2:5060;branch=z9hG4bK1B678C7 From: <sip:2222222222@184.71.242.2:5060>;tag=A7CF3A8-B36 To: "1111111111" <sip:1111111111@208.43.85.75>;tag=as40beef80 Date: Thu, 28 Aug 2014 15:09:03 GMT Call-ID: 150b67c355dd6cc774ad4bca7944ca5b@208.43.85.75 Supported: 100rel,timer,resource-priority,replaces,sdp-anat Min-SE: 1800 Cisco-Guid: 0291807601-0771494372-2465123344-1704358673 User-Agent: Cisco-SIPGateway/IOS-15.2.4.M6a Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER CSeq: 101 INVITE Max-Forwards: 70 Timestamp: 1409238543 Contact: <sip:2222222222@184.71.242.2:5060> Expires: 180 Allow-Events: telephone-event Content-Type: application/sdp Content-Length: 294 v=0 o=CiscoSystemsSIP-GW-UserAgent 7259 1404 IN IP4 184.71.242.2 s=SIP Call c=IN IP4 0.0.0.0 t=0 0 m=audio 18662 RTP/AVP 0 101 c=IN IP4 0.0.0.0 a=inactive a=rtpmap:0 PCMU/8000 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-16 a=ptime:20 m=video 0 RTP/AVP 34 c=IN IP4 184.71.242.2 039416: Aug 28 09:09:03.313 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg: Received: SIP/2.0 100 Trying Via: SIP/2.0/UDP 184.71.242.2:5060;branch=z9hG4bK1B678C7;received=184.71.242.2 From: <sip:2222222222@184.71.242.2:5060>;tag=A7CF3A8-B36 To: "1111111111" <sip:1111111111@208.43.85.75>;tag=as40beef80 Call-ID: 150b67c355dd6cc774ad4bca7944ca5b@208.43.85.75 CSeq: 101 INVITE User-Agent: Asterisk PBX Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY Supported: replaces Contact: <sip:1111111111@208.43.85.75> Content-Length: 0 039417: Aug 28 09:09:03.313 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg: Received: SIP/2.0 200 OK Via: SIP/2.0/UDP 184.71.242.2:5060;branch=z9hG4bK1B678C7;received=184.71.242.2 From: <sip:2222222222@184.71.242.2:5060>;tag=A7CF3A8-B36 To: "1111111111" <sip:1111111111@208.43.85.75>;tag=as40beef80 Call-ID: 150b67c355dd6cc774ad4bca7944ca5b@208.43.85.75 CSeq: 101 INVITE User-Agent: Asterisk PBX Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY Supported: replaces Contact: <sip:1111111111@208.43.85.75> Content-Type: application/sdp Content-Length: 310 v=0 o=root 1022 1023 IN IP4 208.43.85.75 s=session c=IN IP4 208.43.85.75 b=CT:384 t=0 0 m=audio 18910 RTP/AVP 0 101 a=rtpmap:0 PCMU/8000 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-16 a=silenceSupp:off - - - - a=ptime:20 a=inactive m=video 18520 RTP/AVP 34 a=rtpmap:34 H263/90000 a=inactive 039418: Aug 28 09:09:03.321 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg: Sent: ACK sip:1111111111@208.43.85.75 SIP/2.0 Via: SIP/2.0/UDP 184.71.242.2:5060;branch=z9hG4bK1B6822DC From: <sip:2222222222@184.71.242.2:5060>;tag=A7CF3A8-B36 To: "1111111111" <sip:1111111111@208.43.85.75>;tag=as40beef80 Date: Thu, 28 Aug 2014 15:09:03 GMT Call-ID: 150b67c355dd6cc774ad4bca7944ca5b@208.43.85.75 Max-Forwards: 70 CSeq: 101 ACK Allow-Events: telephone-event Content-Length: 0 039419: Aug 28 09:09:03.321 MST: //6872/1164A17192EE/SIP/Msg/ccsipDisplayMsg: Sent: SIP/2.0 200 OK Via: SIP/2.0/UDP 10.135.191.12:5060;branch=z9hG4bKc1b5396f4b2 From: <sip:3000@10.135.191.12>;tag=100429~dc062259-9b0a-4df2-b05d-e4de329c1980-28525423 To: "1111111111" <sip:1111111111@sip1.ixica.com>;tag=A7CF398-21B1 Date: Thu, 28 Aug 2014 15:09:03 GMT Call-ID: 11667682-2DFC11E4-92F4CC10-65967311@172.18.0.1 CSeq: 101 INVITE Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER Allow-Events: telephone-event Remote-Party-ID: "1111111111" <sip:1111111111@172.18.0.1>;party=called;screen=no;privacy=off Contact: <sip:2000@172.18.0.1:5060> Supported: replaces Supported: sdp-anat Server: Cisco-SIPGateway/IOS-15.2.4.M6a Require: timer Session-Expires: 1800;refresher=uac Supported: timer Content-Type: application/sdp Content-Length: 295 v=0 o=CiscoSystemsSIP-GW-UserAgent 8203 267 IN IP4 172.18.0.1 s=SIP Call c=IN IP4 172.18.0.1 t=0 0 m=audio 18666 RTP/AVP 0 101 c=IN IP4 172.18.0.1 a=inactive a=rtpmap:0 PCMU/8000 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-16 a=ptime:20 m=video 0 RTP/AVP 31 c=IN IP4 172.18.0.1 039420: Aug 28 09:09:03.325 MST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Received: ACK sip:2000@172.18.0.1:5060 SIP/2.0 Via: SIP/2.0/UDP 10.135.191.12:5060;branch=z9hG4bKc1c60c9dcc9 From: <sip:3000@10.135.191.12>;tag=100429~dc062259-9b0a-4df2-b05d-e4de329c1980-28525423 To: "1111111111" <sip:1111111111@sip1.ixica.com>;tag=A7CF398-21B1 Date: Thu, 28 Aug 2014 15:09:03 GMT Call-ID: 11667682-2DFC11E4-92F4CC10-65967311@172.18.0.1 User-Agent: Cisco-CUCM10.5 Max-Forwards: 70 CSeq: 101 ACK Allow-Events: presence Content-Length: 0 039421: Aug 28 09:09:03.337 MST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Received: INVITE sip:2000@172.18.0.1:5060 SIP/2.0 Via: SIP/2.0/UDP 10.135.191.12:5060;branch=z9hG4bKc1d54678d26 From: <sip:3000@10.135.191.12>;tag=100429~dc062259-9b0a-4df2-b05d-e4de329c1980-28525423 To: "1111111111" <sip:1111111111@sip1.ixica.com>;tag=A7CF398-21B1 Date: Thu, 28 Aug 2014 15:09:03 GMT Call-ID: 11667682-2DFC11E4-92F4CC10-65967311@172.18.0.1 Supported: timer,resource-priority,replaces Cisco-Guid: 0291807601-0771494372-2465123344-1704358673 User-Agent: Cisco-CUCM10.5 Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY CSeq: 102 INVITE Max-Forwards: 70 Expires: 180 Allow-Events: presence Supported: X-cisco-srtp-fallback Supported: Geolocation Session-Expires: 1800;refresher=uac Min-SE: 1800 P-Asserted-Identity: "Cisco Unity" <sip:2000@10.135.191.12> Remote-Party-ID: "Cisco Unity" <sip:2000@10.135.191.12>;party=calling;screen=yes;privacy=off Contact: <sip:3000@10.135.191.12:5060>;isFocus Content-Length: 0 039422: Aug 28 09:09:03.341 MST: //6872/1164A17192EE/SIP/Msg/ccsipDisplayMsg: Sent: SIP/2.0 100 Trying Via: SIP/2.0/UDP 10.135.191.12:5060;branch=z9hG4bKc1d54678d26 From: <sip:3000@10.135.191.12>;tag=100429~dc062259-9b0a-4df2-b05d-e4de329c1980-28525423 To: "1111111111" <sip:1111111111@sip1.ixica.com>;tag=A7CF398-21B1 Date: Thu, 28 Aug 2014 15:09:03 GMT Call-ID: 11667682-2DFC11E4-92F4CC10-65967311@172.18.0.1 CSeq: 102 INVITE Allow-Events: telephone-event Server: Cisco-SIPGateway/IOS-15.2.4.M6a Content-Length: 0 039423: Aug 28 09:09:03.341 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg: Sent: INVITE sip:1111111111@208.43.85.75 SIP/2.0 Via: SIP/2.0/UDP 184.71.242.2:5060;branch=z9hG4bK1B691481 From: <sip:2222222222@184.71.242.2:5060>;tag=A7CF3A8-B36 To: "1111111111" <sip:1111111111@208.43.85.75>;tag=as40beef80 Date: Thu, 28 Aug 2014 15:09:03 GMT Call-ID: 150b67c355dd6cc774ad4bca7944ca5b@208.43.85.75 Supported: 100rel,timer,resource-priority,replaces,sdp-anat Min-SE: 1800 Cisco-Guid: 0291807601-0771494372-2465123344-1704358673 User-Agent: Cisco-SIPGateway/IOS-15.2.4.M6a Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER CSeq: 102 INVITE Max-Forwards: 70 Timestamp: 1409238543 Contact: <sip:2222222222@184.71.242.2:5060> Expires: 180 Allow-Events: telephone-event Content-Length: 0 039424: Aug 28 09:09:03.421 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg: Received: SIP/2.0 100 Trying Via: SIP/2.0/UDP 184.71.242.2:5060;branch=z9hG4bK1B691481;received=184.71.242.2 From: <sip:2222222222@184.71.242.2:5060>;tag=A7CF3A8-B36 To: "1111111111" <sip:1111111111@208.43.85.75>;tag=as40beef80 Call-ID: 150b67c355dd6cc774ad4bca7944ca5b@208.43.85.75 CSeq: 102 INVITE User-Agent: Asterisk PBX Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY Supported: replaces Contact: <sip:1111111111@208.43.85.75> Content-Length: 0 039425: Aug 28 09:09:03.421 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg: Received: SIP/2.0 200 OK Via: SIP/2.0/UDP 184.71.242.2:5060;branch=z9hG4bK1B691481;received=184.71.242.2 From: <sip:2222222222@184.71.242.2:5060>;tag=A7CF3A8-B36 To: "1111111111" <sip:1111111111@208.43.85.75>;tag=as40beef80 Call-ID: 150b67c355dd6cc774ad4bca7944ca5b@208.43.85.75 CSeq: 102 INVITE User-Agent: Asterisk PBX Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY Supported: replaces Contact: <sip:1111111111@208.43.85.75> Content-Type: application/sdp Content-Length: 361 v=0 o=root 1022 1024 IN IP4 208.43.85.75 s=session c=IN IP4 208.43.85.75 b=CT:384 t=0 0 m=audio 18910 RTP/AVP 0 8 101 a=rtpmap:0 PCMU/8000 a=rtpmap:8 PCMA/8000 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-16 a=silenceSupp:off - - - - a=ptime:20 a=sendrecv m=video 18520 RTP/AVP 34 99 a=rtpmap:34 H263/90000 a=rtpmap:99 H264/90000 a=sendrecv 039426: Aug 28 09:09:03.429 MST: //6872/1164A17192EE/SIP/Msg/ccsipDisplayMsg: Sent: SIP/2.0 200 OK Via: SIP/2.0/UDP 10.135.191.12:5060;branch=z9hG4bKc1d54678d26 From: <sip:3000@10.135.191.12>;tag=100429~dc062259-9b0a-4df2-b05d-e4de329c1980-28525423 To: "1111111111" <sip:1111111111@sip1.ixica.com>;tag=A7CF398-21B1 Date: Thu, 28 Aug 2014 15:09:03 GMT Call-ID: 11667682-2DFC11E4-92F4CC10-65967311@172.18.0.1 CSeq: 102 INVITE Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER Allow-Events: telephone-event Remote-Party-ID: "1111111111" <sip:1111111111@172.18.0.1>;party=called;screen=no;privacy=off Contact: <sip:2000@172.18.0.1:5060> Supported: replaces Supported: sdp-anat Server: Cisco-SIPGateway/IOS-15.2.4.M6a Require: timer Session-Expires: 1800;refresher=uac Supported: timer Content-Type: application/sdp Content-Length: 393 v=0 o=CiscoSystemsSIP-GW-UserAgent 8203 268 IN IP4 172.18.0.1 s=SIP Call c=IN IP4 172.18.0.1 t=0 0 m=audio 18666 RTP/AVP 0 101 c=IN IP4 172.18.0.1 a=rtpmap:0 PCMU/8000 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-16 a=ptime:20 m=video 18670 RTP/AVP 34 119 c=IN IP4 172.18.0.1 a=rtpmap:34 H263/90000 a=fmtp:34 CIF=1 a=rtpmap:119 H264/90000 a=fmtp:119 profile-level-id=000000 039427: Aug 28 09:09:03.441 MST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Received: ACK sip:2000@172.18.0.1:5060 SIP/2.0 Via: SIP/2.0/UDP 10.135.191.12:5060;branch=z9hG4bKc1e4ad4139 From: <sip:3000@10.135.191.12>;tag=100429~dc062259-9b0a-4df2-b05d-e4de329c1980-28525423 To: "1111111111" <sip:1111111111@sip1.ixica.com>;tag=A7CF398-21B1 Date: Thu, 28 Aug 2014 15:09:03 GMT Call-ID: 11667682-2DFC11E4-92F4CC10-65967311@172.18.0.1 User-Agent: Cisco-CUCM10.5 Max-Forwards: 70 CSeq: 102 ACK Allow-Events: presence Content-Type: application/sdp Content-Length: 380 v=0 o=CiscoSystemsCCM-SIP 100429 3 IN IP4 10.135.191.12 s=SIP Call c=IN IP4 0.0.0.0 b=TIAS:64000 b=CT:64 b=AS:64 t=0 0 m=audio 16838 RTP/AVP 0 a=X-cisco-media:mmoh a=ptime:20 a=rtpmap:0 PCMU/8000 a=inactive m=video 0 RTP/AVP 31 34 96 97 a=rtpmap:31 H261/90000 a=rtpmap:34 H263/90000 a=rtpmap:96 H263-1998/90000 a=rtpmap:97 H264/90000 a=content:main a=inactive 039428: Aug 28 09:09:03.441 MST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Received: INVITE sip:2000@172.18.0.1:5060 SIP/2.0 Via: SIP/2.0/UDP 10.135.191.12:5060;branch=z9hG4bKc1f64c64759 From: <sip:3000@10.135.191.12>;tag=100429~dc062259-9b0a-4df2-b05d-e4de329c1980-28525423 To: "1111111111" <sip:1111111111@sip1.ixica.com>;tag=A7CF398-21B1 Date: Thu, 28 Aug 2014 15:09:03 GMT Call-ID: 11667682-2DFC11E4-92F4CC10-65967311@172.18.0.1 Supported: timer,resource-priority,replaces Cisco-Guid: 0291807601-0771494372-2465123344-1704358673 User-Agent: Cisco-CUCM10.5 Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY CSeq: 103 INVITE Max-Forwards: 70 Expires: 180 Allow-Events: presence Supported: X-cisco-srtp-fallback Supported: Geolocation Session-Expires: 1800;refresher=uac Min-SE: 1800 P-Asserted-Identity: "Cisco Unity" <sip:2000@10.135.191.12> Remote-Party-ID: "Cisco Unity" <sip:2000@10.135.191.12>;party=calling;screen=yes;privacy=off Contact: <sip:3000@10.135.191.12:5060>;isFocus Content-Type: application/sdp Content-Length: 381 v=0 o=CiscoSystemsCCM-SIP 100429 4 IN IP4 10.135.191.12 s=SIP Call t=0 0 m=audio 16384 RTP/AVP 0 c=IN IP4 239.1.1.1 a=X-cisco-media:mmoh+ConnSendOnly a=ptime:20 a=rtpmap:0 PCMU/8000 a=recvonly m=video 0 RTP/AVP 31 34 96 97 c=IN IP4 0.0.0.0 a=rtpmap:31 H261/90000 a=rtpmap:34 H263/90000 a=rtpmap:96 H263-1998/90000 a=rtpmap:97 H264/90000 a=content:main a=inactive 039429: Aug 28 09:09:03.453 MST: //6872/1164A17192EE/SIP/Msg/ccsipDisplayMsg: Sent: SIP/2.0 100 Trying Via: SIP/2.0/UDP 10.135.191.12:5060;branch=z9hG4bKc1f64c64759 From: <sip:3000@10.135.191.12>;tag=100429~dc062259-9b0a-4df2-b05d-e4de329c1980-28525423 To: "1111111111" <sip:1111111111@sip1.ixica.com>;tag=A7CF398-21B1 Date: Thu, 28 Aug 2014 15:09:03 GMT Call-ID: 11667682-2DFC11E4-92F4CC10-65967311@172.18.0.1 CSeq: 103 INVITE Allow-Events: telephone-event Server: Cisco-SIPGateway/IOS-15.2.4.M6a Content-Length: 0 039430: Aug 28 09:09:03.453 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg: Sent: ACK sip:1111111111@208.43.85.75 SIP/2.0 Via: SIP/2.0/UDP 184.71.242.2:5060;branch=z9hG4bK1B6A5B5 From: <sip:2222222222@184.71.242.2:5060>;tag=A7CF3A8-B36 To: "1111111111" <sip:1111111111@208.43.85.75>;tag=as40beef80 Date: Thu, 28 Aug 2014 15:09:03 GMT Call-ID: 150b67c355dd6cc774ad4bca7944ca5b@208.43.85.75 Max-Forwards: 70 CSeq: 102 ACK Allow-Events: telephone-event Content-Type: application/sdp Content-Length: 294 v=0 o=CiscoSystemsSIP-GW-UserAgent 7259 1405 IN IP4 184.71.242.2 s=SIP Call c=IN IP4 0.0.0.0 t=0 0 m=audio 18662 RTP/AVP 0 101 c=IN IP4 0.0.0.0 a=inactive a=rtpmap:0 PCMU/8000 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-16 a=ptime:20 m=video 0 RTP/AVP 34 c=IN IP4 184.71.242.2 039431: Aug 28 09:09:03.453 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg: Sent: INVITE sip:1111111111@208.43.85.75 SIP/2.0 Via: SIP/2.0/UDP 184.71.242.2:5060;branch=z9hG4bK1B6B1D6B From: <sip:2222222222@184.71.242.2:5060>;tag=A7CF3A8-B36 To: "1111111111" <sip:1111111111@208.43.85.75>;tag=as40beef80 Date: Thu, 28 Aug 2014 15:09:03 GMT Call-ID: 150b67c355dd6cc774ad4bca7944ca5b@208.43.85.75 Supported: 100rel,timer,resource-priority,replaces,sdp-anat Min-SE: 1800 Cisco-Guid: 0291807601-0771494372-2465123344-1704358673 User-Agent: Cisco-SIPGateway/IOS-15.2.4.M6a Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER CSeq: 103 INVITE Max-Forwards: 70 Timestamp: 1409238543 Contact: <sip:2222222222@184.71.242.2:5060> Expires: 180 Allow-Events: telephone-event Content-Type: application/sdp Content-Length: 294 v=0 o=CiscoSystemsSIP-GW-UserAgent 7259 1406 IN IP4 184.71.242.2 s=SIP Call c=IN IP4 0.0.0.0 t=0 0 m=audio 18662 RTP/AVP 0 101 c=IN IP4 0.0.0.0 a=sendonly a=rtpmap:0 PCMU/8000 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-16 a=ptime:20 m=video 0 RTP/AVP 34 c=IN IP4 184.71.242.2 039432: Aug 28 09:09:03.537 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg: Received: SIP/2.0 100 Trying Via: SIP/2.0/UDP 184.71.242.2:5060;branch=z9hG4bK1B6B1D6B;received=184.71.242.2 From: <sip:2222222222@184.71.242.2:5060>;tag=A7CF3A8-B36 To: "1111111111" <sip:1111111111@208.43.85.75>;tag=as40beef80 Call-ID: 150b67c355dd6cc774ad4bca7944ca5b@208.43.85.75 CSeq: 103 INVITE User-Agent: Asterisk PBX Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY Supported: replaces Contact: <sip:1111111111@208.43.85.75> Content-Length: 0 039433: Aug 28 09:09:03.537 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg: Received: SIP/2.0 200 OK Via: SIP/2.0/UDP 184.71.242.2:5060;branch=z9hG4bK1B6B1D6B;received=184.71.242.2 From: <sip:2222222222@184.71.242.2:5060>;tag=A7CF3A8-B36 To: "1111111111" <sip:1111111111@208.43.85.75>;tag=as40beef80 Call-ID: 150b67c355dd6cc774ad4bca7944ca5b@208.43.85.75 CSeq: 103 INVITE User-Agent: Asterisk PBX Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY Supported: replaces Contact: <sip:1111111111@208.43.85.75> Content-Type: application/sdp Content-Length: 310 v=0 o=root 1022 1025 IN IP4 208.43.85.75 s=session c=IN IP4 208.43.85.75 b=CT:384 t=0 0 m=audio 18910 RTP/AVP 0 101 a=rtpmap:0 PCMU/8000 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-16 a=silenceSupp:off - - - - a=ptime:20 a=inactive m=video 18520 RTP/AVP 34 a=rtpmap:34 H263/90000 a=inactive 039434: Aug 28 09:09:03.545 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg: Sent: ACK sip:1111111111@208.43.85.75 SIP/2.0 Via: SIP/2.0/UDP 184.71.242.2:5060;branch=z9hG4bK1B6C26BF From: <sip:2222222222@184.71.242.2:5060>;tag=A7CF3A8-B36 To: "1111111111" <sip:1111111111@208.43.85.75>;tag=as40beef80 Date: Thu, 28 Aug 2014 15:09:03 GMT Call-ID: 150b67c355dd6cc774ad4bca7944ca5b@208.43.85.75 Max-Forwards: 70 CSeq: 103 ACK Allow-Events: telephone-event Content-Length: 0 039435: Aug 28 09:09:03.545 MST: //6872/1164A17192EE/SIP/Msg/ccsipDisplayMsg: Sent: SIP/2.0 200 OK Via: SIP/2.0/UDP 10.135.191.12:5060;branch=z9hG4bKc1f64c64759 From: <sip:3000@10.135.191.12>;tag=100429~dc062259-9b0a-4df2-b05d-e4de329c1980-28525423 To: "1111111111" <sip:1111111111@sip1.ixica.com>;tag=A7CF398-21B1 Date: Thu, 28 Aug 2014 15:09:03 GMT Call-ID: 11667682-2DFC11E4-92F4CC10-65967311@172.18.0.1 CSeq: 103 INVITE Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER Allow-Events: telephone-event Remote-Party-ID: "1111111111" <sip:1111111111@172.18.0.1>;party=called;screen=no;privacy=off Contact: <sip:2000@172.18.0.1:5060> Supported: replaces Supported: sdp-anat Server: Cisco-SIPGateway/IOS-15.2.4.M6a Require: timer Session-Expires: 1800;refresher=uac Supported: timer Content-Type: application/sdp Content-Length: 279 v=0 o=CiscoSystemsSIP-GW-UserAgent 8203 269 IN IP4 172.18.0.1 s=SIP Call c=IN IP4 172.18.0.1 t=0 0 m=audio 16384 RTP/AVP 0 c=IN IP4 239.1.1.1 a=inactive a=rtpmap:0 PCMU/8000 a=ptime:20 m=video 0 RTP/AVP 34 c=IN IP4 172.18.0.1 a=rtpmap:34 H263/90000 a=fmtp:34 CIF=1 039436: Aug 28 09:09:03.549 MST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Received: ACK sip:2000@172.18.0.1:5060 SIP/2.0 Via: SIP/2.0/UDP 10.135.191.12:5060;branch=z9hG4bKc20466fa4c5 From: <sip:3000@10.135.191.12>;tag=100429~dc062259-9b0a-4df2-b05d-e4de329c1980-28525423 To: "1111111111" <sip:1111111111@sip1.ixica.com>;tag=A7CF398-21B1 Date: Thu, 28 Aug 2014 15:09:03 GMT Call-ID: 11667682-2DFC11E4-92F4CC10-65967311@172.18.0.1 User-Agent: Cisco-CUCM10.5 Max-Forwards: 70 CSeq: 103 ACK Allow-Events: presence Content-Length: 0 039437: Aug 28 09:09:03.997 MST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Received: INVITE sip:2000@172.18.0.1:5060 SIP/2.0 Via: SIP/2.0/UDP 10.135.191.12:5060;branch=z9hG4bKc22648a2b14 From: <sip:3000@10.135.191.12>;tag=100429~dc062259-9b0a-4df2-b05d-e4de329c1980-28525423 To: "1111111111" <sip:1111111111@sip1.ixica.com>;tag=A7CF398-21B1 Date: Thu, 28 Aug 2014 15:09:03 GMT Call-ID: 11667682-2DFC11E4-92F4CC10-65967311@172.18.0.1 Supported: timer,resource-priority,replaces Cisco-Guid: 0291807601-0771494372-2465123344-1704358673 User-Agent: Cisco-CUCM10.5 Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY CSeq: 104 INVITE Max-Forwards: 70 Expires: 180 Allow-Events: presence Call-Info: <urn:x-cisco-remotecc:callinfo>;x-cisco-video-traffic-class=VIDEO_UNSPECIFIED Supported: X-cisco-srtp-fallback Supported: Geolocation Session-Expires: 1800;refresher=uac Min-SE: 1800 P-Asserted-Identity: "Cisco Unity" <sip:2000@10.135.191.12> Remote-Party-ID: "Cisco Unity" <sip:2000@10.135.191.12>;party=calling;screen=yes;privacy=off Contact: <sip:3000@10.135.191.12:5060>;isFocus Content-Type: application/sdp Content-Length: 361 v=0 o=CiscoSystemsCCM-SIP 100429 5 IN IP4 10.135.191.12 s=SIP Call c=IN IP4 0.0.0.0 t=0 0 m=audio 16384 RTP/AVP 0 a=X-cisco-media:mmoh+ConnSendOnly a=ptime:20 a=rtpmap:0 PCMU/8000 a=inactive m=video 0 RTP/AVP 31 34 96 97 a=rtpmap:31 H261/90000 a=rtpmap:34 H263/90000 a=rtpmap:96 H263-1998/90000 a=rtpmap:97 H264/90000 a=content:main a=inactive 039438: Aug 28 09:09:04.005 MST: //6872/1164A17192EE/SIP/Msg/ccsipDisplayMsg: Sent: SIP/2.0 100 Trying Via: SIP/2.0/UDP 10.135.191.12:5060;branch=z9hG4bKc22648a2b14 From: <sip:3000@10.135.191.12>;tag=100429~dc062259-9b0a-4df2-b05d-e4de329c1980-28525423 To: "1111111111" <sip:1111111111@sip1.ixica.com>;tag=A7CF398-21B1 Date: Thu, 28 Aug 2014 15:09:03 GMT Call-ID: 11667682-2DFC11E4-92F4CC10-65967311@172.18.0.1 CSeq: 104 INVITE Allow-Events: telephone-event Server: Cisco-SIPGateway/IOS-15.2.4.M6a Content-Length: 0 039439: Aug 28 09:09:04.005 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg: Sent: INVITE sip:1111111111@208.43.85.75 SIP/2.0 Via: SIP/2.0/UDP 184.71.242.2:5060;branch=z9hG4bK1B6D1B47 From: <sip:2222222222@184.71.242.2:5060>;tag=A7CF3A8-B36 To: "1111111111" <sip:1111111111@208.43.85.75>;tag=as40beef80 Date: Thu, 28 Aug 2014 15:09:04 GMT Call-ID: 150b67c355dd6cc774ad4bca7944ca5b@208.43.85.75 Supported: 100rel,timer,resource-priority,replaces,sdp-anat Min-SE: 1800 Cisco-Guid: 0291807601-0771494372-2465123344-1704358673 User-Agent: Cisco-SIPGateway/IOS-15.2.4.M6a Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER CSeq: 104 INVITE Max-Forwards: 70 Timestamp: 1409238544 Contact: <sip:2222222222@184.71.242.2:5060> Expires: 180 Allow-Events: telephone-event Content-Type: application/sdp Content-Length: 294 v=0 o=CiscoSystemsSIP-GW-UserAgent 7259 1407 IN IP4 184.71.242.2 s=SIP Call c=IN IP4 0.0.0.0 t=0 0 m=audio 18662 RTP/AVP 0 101 c=IN IP4 0.0.0.0 a=inactive a=rtpmap:0 PCMU/8000 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-16 a=ptime:20 m=video 0 RTP/AVP 34 c=IN IP4 184.71.242.2 039440: Aug 28 09:09:04.089 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg: Received: SIP/2.0 100 Trying Via: SIP/2.0/UDP 184.71.242.2:5060;branch=z9hG4bK1B6D1B47;received=184.71.242.2 From: <sip:2222222222@184.71.242.2:5060>;tag=A7CF3A8-B36 To: "1111111111" <sip:1111111111@208.43.85.75>;tag=as40beef80 Call-ID: 150b67c355dd6cc774ad4bca7944ca5b@208.43.85.75 CSeq: 104 INVITE User-Agent: Asterisk PBX Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY Supported: replaces Contact: <sip:1111111111@208.43.85.75> Content-Length: 0 039441: Aug 28 09:09:04.089 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg: Received: SIP/2.0 200 OK Via: SIP/2.0/UDP 184.71.242.2:5060;branch=z9hG4bK1B6D1B47;received=184.71.242.2 From: <sip:2222222222@184.71.242.2:5060>;tag=A7CF3A8-B36 To: "1111111111" <sip:1111111111@208.43.85.75>;tag=as40beef80 Call-ID: 150b67c355dd6cc774ad4bca7944ca5b@208.43.85.75 CSeq: 104 INVITE User-Agent: Asterisk PBX Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY Supported: replaces Contact: <sip:1111111111@208.43.85.75> Content-Type: application/sdp Content-Length: 310 v=0 o=root 1022 1026 IN IP4 208.43.85.75 s=session c=IN IP4 208.43.85.75 b=CT:384 t=0 0 m=audio 18910 RTP/AVP 0 101 a=rtpmap:0 PCMU/8000 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-16 a=silenceSupp:off - - - - a=ptime:20 a=inactive m=video 18520 RTP/AVP 34 a=rtpmap:34 H263/90000 a=inactive 039442: Aug 28 09:09:04.097 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg: Sent: ACK sip:1111111111@208.43.85.75 SIP/2.0 Via: SIP/2.0/UDP 184.71.242.2:5060;branch=z9hG4bK1B6EC08 From: <sip:2222222222@184.71.242.2:5060>;tag=A7CF3A8-B36 To: "1111111111" <sip:1111111111@208.43.85.75>;tag=as40beef80 Date: Thu, 28 Aug 2014 15:09:04 GMT Call-ID: 150b67c355dd6cc774ad4bca7944ca5b@208.43.85.75 Max-Forwards: 70 CSeq: 104 ACK Allow-Events: telephone-event Content-Length: 0 039443: Aug 28 09:09:04.097 MST: //6872/1164A17192EE/SIP/Msg/ccsipDisplayMsg: Sent: SIP/2.0 200 OK Via: SIP/2.0/UDP 10.135.191.12:5060;branch=z9hG4bKc22648a2b14 From: <sip:3000@10.135.191.12>;tag=100429~dc062259-9b0a-4df2-b05d-e4de329c1980-28525423 To: "1111111111" <sip:1111111111@sip1.ixica.com>;tag=A7CF398-21B1 Date: Thu, 28 Aug 2014 15:09:03 GMT Call-ID: 11667682-2DFC11E4-92F4CC10-65967311@172.18.0.1 CSeq: 104 INVITE Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER Allow-Events: telephone-event Remote-Party-ID: "1111111111" <sip:1111111111@172.18.0.1>;party=called;screen=no;privacy=off Contact: <sip:2000@172.18.0.1:5060> Supported: replaces Supported: sdp-anat Server: Cisco-SIPGateway/IOS-15.2.4.M6a Require: timer Session-Expires: 1800;refresher=uac Supported: timer Content-Type: application/sdp Content-Length: 280 v=0 o=CiscoSystemsSIP-GW-UserAgent 8203 269 IN IP4 172.18.0.1 s=SIP Call c=IN IP4 172.18.0.1 t=0 0 m=audio 18666 RTP/AVP 0 c=IN IP4 172.18.0.1 a=inactive a=rtpmap:0 PCMU/8000 a=ptime:20 m=video 0 RTP/AVP 34 c=IN IP4 172.18.0.1 a=rtpmap:34 H263/90000 a=fmtp:34 CIF=1 039444: Aug 28 09:09:04.101 MST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Received: ACK sip:2000@172.18.0.1:5060 SIP/2.0 Via: SIP/2.0/UDP 10.135.191.12:5060;branch=z9hG4bKc234759966 From: <sip:3000@10.135.191.12>;tag=100429~dc062259-9b0a-4df2-b05d-e4de329c1980-28525423 To: "1111111111" <sip:1111111111@sip1.ixica.com>;tag=A7CF398-21B1 Date: Thu, 28 Aug 2014 15:09:03 GMT Call-ID: 11667682-2DFC11E4-92F4CC10-65967311@172.18.0.1 User-Agent: Cisco-CUCM10.5 Max-Forwards: 70 CSeq: 104 ACK Allow-Events: presence Content-Length: 0 039445: Aug 28 09:09:04.113 MST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Received: UPDATE sip:2000@172.18.0.1:5060 SIP/2.0 Via: SIP/2.0/UDP 10.135.191.12:5060;branch=z9hG4bKc24648aba28 From: <sip:3000@10.135.191.12>;tag=100429~dc062259-9b0a-4df2-b05d-e4de329c1980-28525423 To: "1111111111" <sip:1111111111@sip1.ixica.com>;tag=A7CF398-21B1 Date: Thu, 28 Aug 2014 15:09:03 GMT Call-ID: 11667682-2DFC11E4-92F4CC10-65967311@172.18.0.1 User-Agent: Cisco-CUCM10.5 Max-Forwards: 70 Supported: timer,resource-priority,replaces Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY CSeq: 105 UPDATE Call-Info: <urn:x-cisco-remotecc:callinfo>;x-cisco-video-traffic-class=VIDEO_UNSPECIFIED Supported: X-cisco-srtp-fallback Supported: Geolocation Session-Expires: 1800;refresher=uac Min-SE: 1800 P-Asserted-Identity: "Anthony" <sip:270@10.135.191.12> Remote-Party-ID: "Anthony" <sip:270@10.135.191.12>;party=calling;screen=yes;privacy=off Contact: <sip:3000@10.135.191.12:5060> Content-Length: 0 039446: Aug 28 09:09:04.117 MST: //6872/1164A17192EE/SIP/Msg/ccsipDisplayMsg: Sent: SIP/2.0 200 OK Via: SIP/2.0/UDP 10.135.191.12:5060;branch=z9hG4bKc24648aba28 From: <sip:3000@10.135.191.12>;tag=100429~dc062259-9b0a-4df2-b05d-e4de329c1980-28525423 To: "1111111111" <sip:1111111111@sip1.ixica.com>;tag=A7CF398-21B1 Date: Thu, 28 Aug 2014 15:09:04 GMT Call-ID: 11667682-2DFC11E4-92F4CC10-65967311@172.18.0.1 Server: Cisco-SIPGateway/IOS-15.2.4.M6a CSeq: 105 UPDATE Allow-Events: telephone-event Contact: <sip:270@172.18.0.1:5060> Require: timer Session-Expires: 1800;refresher=uac Supported: timer Content-Length: 0 039447: Aug 28 09:09:04.125 MST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Received: INVITE sip:2000@172.18.0.1:5060 SIP/2.0 Via: SIP/2.0/UDP 10.135.191.12:5060;branch=z9hG4bKc2665258271 From: <sip:3000@10.135.191.12>;tag=100429~dc062259-9b0a-4df2-b05d-e4de329c1980-28525423 To: "1111111111" <sip:1111111111@sip1.ixica.com>;tag=A7CF398-21B1 Date: Thu, 28 Aug 2014 15:09:04 GMT Call-ID: 11667682-2DFC11E4-92F4CC10-65967311@172.18.0.1 Supported: timer,resource-priority,replaces Cisco-Guid: 0291807601-0771494372-2465123344-1704358673 User-Agent: Cisco-CUCM10.5 Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY CSeq: 106 INVITE Max-Forwards: 70 Expires: 180 Allow-Events: presence Call-Info: <urn:x-cisco-remotecc:callinfo>;x-cisco-video-traffic-class=VIDEO_UNSPECIFIED Supported: X-cisco-srtp-fallback Supported: Geolocation Session-Expires: 1800;refresher=uac Min-SE: 1800 P-Asserted-Identity: "Anthony" <sip:270@10.135.191.12> Remote-Party-ID: "Anthony" <sip:270@10.135.191.12>;party=calling;screen=yes;privacy=off Contact: <sip:3000@10.135.191.12:5060> Content-Length: 0 039448: Aug 28 09:09:04.129 MST: //6872/1164A17192EE/SIP/Msg/ccsipDisplayMsg: Sent: SIP/2.0 100 Trying Via: SIP/2.0/UDP 10.135.191.12:5060;branch=z9hG4bKc2665258271 From: <sip:3000@10.135.191.12>;tag=100429~dc062259-9b0a-4df2-b05d-e4de329c1980-28525423 To: "1111111111" <sip:1111111111@sip1.ixica.com>;tag=A7CF398-21B1 Date: Thu, 28 Aug 2014 15:09:04 GMT Call-ID: 11667682-2DFC11E4-92F4CC10-65967311@172.18.0.1 CSeq: 106 INVITE Allow-Events: telephone-event Server: Cisco-SIPGateway/IOS-15.2.4.M6a Content-Length: 0 039449: Aug 28 09:09:04.129 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg: Sent: INVITE sip:1111111111@208.43.85.75 SIP/2.0 Via: SIP/2.0/UDP 184.71.242.2:5060;branch=z9hG4bK1B6F19D2 From: <sip:2222222222@184.71.242.2:5060>;tag=A7CF3A8-B36 To: "1111111111" <sip:1111111111@208.43.85.75>;tag=as40beef80 Date: Thu, 28 Aug 2014 15:09:04 GMT Call-ID: 150b67c355dd6cc774ad4bca7944ca5b@208.43.85.75 Supported: 100rel,timer,resource-priority,replaces,sdp-anat Min-SE: 1800 Cisco-Guid: 0291807601-0771494372-2465123344-1704358673 User-Agent: Cisco-SIPGateway/IOS-15.2.4.M6a Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER CSeq: 105 INVITE Max-Forwards: 70 Timestamp: 1409238544 Contact: <sip:2222222222@184.71.242.2:5060> Expires: 180 Allow-Events: telephone-event Content-Length: 0 039450: Aug 28 09:09:04.213 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg: Received: SIP/2.0 100 Trying Via: SIP/2.0/UDP 184.71.242.2:5060;branch=z9hG4bK1B6F19D2;received=184.71.242.2 From: <sip:2222222222@184.71.242.2:5060>;tag=A7CF3A8-B36 To: "1111111111" <sip:1111111111@208.43.85.75>;tag=as40beef80 Call-ID: 150b67c355dd6cc774ad4bca7944ca5b@208.43.85.75 CSeq: 105 INVITE User-Agent: Asterisk PBX Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY Supported: replaces Contact: <sip:1111111111@208.43.85.75> Content-Length: 0 039451: Aug 28 09:09:04.213 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg: Received: SIP/2.0 200 OK Via: SIP/2.0/UDP 184.71.242.2:5060;branch=z9hG4bK1B6F19D2;received=184.71.242.2 From: <sip:2222222222@184.71.242.2:5060>;tag=A7CF3A8-B36 To: "1111111111" <sip:1111111111@208.43.85.75>;tag=as40beef80 Call-ID: 150b67c355dd6cc774ad4bca7944ca5b@208.43.85.75 CSeq: 105 INVITE User-Agent: Asterisk PBX Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY Supported: replaces Contact: <sip:1111111111@208.43.85.75> Content-Type: application/sdp Content-Length: 361 v=0 o=root 1022 1027 IN IP4 208.43.85.75 s=session c=IN IP4 208.43.85.75 b=CT:384 t=0 0 m=audio 18910 RTP/AVP 0 8 101 a=rtpmap:0 PCMU/8000 a=rtpmap:8 PCMA/8000 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-16 a=silenceSupp:off - - - - a=ptime:20 a=sendrecv m=video 18520 RTP/AVP 34 99 a=rtpmap:34 H263/90000 a=rtpmap:99 H264/90000 a=sendrecv 039452: Aug 28 09:09:04.217 MST: //6872/1164A17192EE/SIP/Msg/ccsipDisplayMsg: Sent: SIP/2.0 200 OK Via: SIP/2.0/UDP 10.135.191.12:5060;branch=z9hG4bKc2665258271 From: <sip:3000@10.135.191.12>;tag=100429~dc062259-9b0a-4df2-b05d-e4de329c1980-28525423 To: "1111111111" <sip:1111111111@sip1.ixica.com>;tag=A7CF398-21B1 Date: Thu, 28 Aug 2014 15:09:04 GMT Call-ID: 11667682-2DFC11E4-92F4CC10-65967311@172.18.0.1 CSeq: 106 INVITE Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER Allow-Events: telephone-event Remote-Party-ID: "1111111111" <sip:1111111111@172.18.0.1>;party=called;screen=no;privacy=off Contact: <sip:270@172.18.0.1:5060> Supported: replaces Supported: sdp-anat Server: Cisco-SIPGateway/IOS-15.2.4.M6a Require: timer Session-Expires: 1800;refresher=uac Supported: timer Content-Type: application/sdp Content-Length: 393 v=0 o=CiscoSystemsSIP-GW-UserAgent 8203 270 IN IP4 172.18.0.1 s=SIP Call c=IN IP4 172.18.0.1 t=0 0 m=audio 18666 RTP/AVP 0 101 c=IN IP4 172.18.0.1 a=rtpmap:0 PCMU/8000 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-16 a=ptime:20 m=video 18672 RTP/AVP 34 119 c=IN IP4 172.18.0.1 a=rtpmap:34 H263/90000 a=fmtp:34 CIF=1 a=rtpmap:119 H264/90000 a=fmtp:119 profile-level-id=000000 039453: Aug 28 09:09:04.237 MST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Received: ACK sip:270@172.18.0.1:5060 SIP/2.0 Via: SIP/2.0/UDP 10.135.191.12:5060;branch=z9hG4bKc2730d82576 From: <sip:3000@10.135.191.12>;tag=100429~dc062259-9b0a-4df2-b05d-e4de329c1980-28525423 To: "1111111111" <sip:1111111111@sip1.ixica.com>;tag=A7CF398-21B1 Date: Thu, 28 Aug 2014 15:09:04 GMT Call-ID: 11667682-2DFC11E4-92F4CC10-65967311@172.18.0.1 User-Agent: Cisco-CUCM10.5 Max-Forwards: 70 CSeq: 106 ACK Allow-Events: presence Content-Type: application/sdp Content-Length: 371 v=0 o=CiscoSystemsCCM-SIP 100429 6 IN IP4 10.135.191.12 s=SIP Call t=0 0 m=audio 4000 RTP/AVP 0 c=IN IP4 10.135.191.12 a=X-cisco-media:umoh a=ptime:20 a=rtpmap:0 PCMU/8000 a=sendonly m=video 0 RTP/AVP 31 34 96 97 c=IN IP4 0.0.0.0 a=rtpmap:31 H261/90000 a=rtpmap:34 H263/90000 a=rtpmap:96 H263-1998/90000 a=rtpmap:97 H264/90000 a=content:main a=inactive 039454: Aug 28 09:09:04.241 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg: Sent: ACK sip:1111111111@208.43.85.75 SIP/2.0 Via: SIP/2.0/UDP 184.71.242.2:5060;branch=z9hG4bK1B7068F From: <sip:2222222222@184.71.242.2:5060>;tag=A7CF3A8-B36 To: "1111111111" <sip:1111111111@208.43.85.75>;tag=as40beef80 Date: Thu, 28 Aug 2014 15:09:04 GMT Call-ID: 150b67c355dd6cc774ad4bca7944ca5b@208.43.85.75 Max-Forwards: 70 CSeq: 105 ACK Allow-Events: telephone-event Content-Type: application/sdp Content-Length: 304 v=0 o=CiscoSystemsSIP-GW-UserAgent 7259 1408 IN IP4 184.71.242.2 s=SIP Call c=IN IP4 184.71.242.2 t=0 0 m=audio 18662 RTP/AVP 0 101 c=IN IP4 184.71.242.2 a=sendonly a=rtpmap:0 PCMU/8000 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-16 a=ptime:20 m=video 0 RTP/AVP 34 c=IN IP4 184.71.242.2 039455: Aug 28 09:09:07.509 MST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Received: INVITE sip:270@172.18.0.1:5060 SIP/2.0 Via: SIP/2.0/UDP 10.135.191.12:5060;branch=z9hG4bKc28659cd830 From: <sip:3000@10.135.191.12>;tag=100429~dc062259-9b0a-4df2-b05d-e4de329c1980-28525423 To: "1111111111" <sip:1111111111@sip1.ixica.com>;tag=A7CF398-21B1 Date: Thu, 28 Aug 2014 15:09:07 GMT Call-ID: 11667682-2DFC11E4-92F4CC10-65967311@172.18.0.1 Supported: timer,resource-priority,replaces Cisco-Guid: 0291807601-0771494372-2465123344-1704358673 User-Agent: Cisco-CUCM10.5 Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY CSeq: 107 INVITE Max-Forwards: 70 Expires: 180 Allow-Events: presence Call-Info: <urn:x-cisco-remotecc:callinfo>;x-cisco-video-traffic-class=VIDEO_UNSPECIFIED Supported: X-cisco-srtp-fallback Supported: Geolocation Session-Expires: 1800;refresher=uac Min-SE: 1800 P-Asserted-Identity: "Anthony" <sip:270@10.135.191.12> Remote-Party-ID: "Anthony" <sip:270@10.135.191.12>;party=calling;screen=yes;privacy=off Contact: <sip:3000@10.135.191.12:5060> Content-Type: application/sdp Content-Length: 347 v=0 o=CiscoSystemsCCM-SIP 100429 7 IN IP4 10.135.191.12 s=SIP Call c=IN IP4 0.0.0.0 t=0 0 m=audio 4000 RTP/AVP 0 a=X-cisco-media:umoh a=ptime:20 a=rtpmap:0 PCMU/8000 a=inactive m=video 0 RTP/AVP 31 34 96 97 a=rtpmap:31 H261/90000 a=rtpmap:34 H263/90000 a=rtpmap:96 H263-1998/90000 a=rtpmap:97 H264/90000 a=content:main a=inactive 039456: Aug 28 09:09:07.517 MST: //6872/1164A17192EE/SIP/Msg/ccsipDisplayMsg: Sent: SIP/2.0 100 Trying Via: SIP/2.0/UDP 10.135.191.12:5060;branch=z9hG4bKc28659cd830 From: <sip:3000@10.135.191.12>;tag=100429~dc062259-9b0a-4df2-b05d-e4de329c1980-28525423 To: "1111111111" <sip:1111111111@sip1.ixica.com>;tag=A7CF398-21B1 Date: Thu, 28 Aug 2014 15:09:07 GMT Call-ID: 11667682-2DFC11E4-92F4CC10-65967311@172.18.0.1 CSeq: 107 INVITE Allow-Events: telephone-event Server: Cisco-SIPGateway/IOS-15.2.4.M6a Content-Length: 0 039457: Aug 28 09:09:07.517 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg: Sent: INVITE sip:1111111111@208.43.85.75 SIP/2.0 Via: SIP/2.0/UDP 184.71.242.2:5060;branch=z9hG4bK1B71E5E From: <sip:2222222222@184.71.242.2:5060>;tag=A7CF3A8-B36 To: "1111111111" <sip:1111111111@208.43.85.75>;tag=as40beef80 Date: Thu, 28 Aug 2014 15:09:07 GMT Call-ID: 150b67c355dd6cc774ad4bca7944ca5b@208.43.85.75 Supported: 100rel,timer,resource-priority,replaces,sdp-anat Min-SE: 1800 Cisco-Guid: 0291807601-0771494372-2465123344-1704358673 User-Agent: Cisco-SIPGateway/IOS-15.2.4.M6a Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER CSeq: 106 INVITE Max-Forwards: 70 Timestamp: 1409238547 Contact: <sip:2222222222@184.71.242.2:5060> Expires: 180 Allow-Events: telephone-event Content-Type: application/sdp Content-Length: 294 v=0 o=CiscoSystemsSIP-GW-UserAgent 7259 1409 IN IP4 184.71.242.2 s=SIP Call c=IN IP4 0.0.0.0 t=0 0 m=audio 18662 RTP/AVP 0 101 c=IN IP4 0.0.0.0 a=inactive a=rtpmap:0 PCMU/8000 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-16 a=ptime:20 m=video 0 RTP/AVP 34 c=IN IP4 184.71.242.2 039458: Aug 28 09:09:07.601 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg: Received: SIP/2.0 100 Trying Via: SIP/2.0/UDP 184.71.242.2:5060;branch=z9hG4bK1B71E5E;received=184.71.242.2 From: <sip:2222222222@184.71.242.2:5060>;tag=A7CF3A8-B36 To: "1111111111" <sip:1111111111@208.43.85.75>;tag=as40beef80 Call-ID: 150b67c355dd6cc774ad4bca7944ca5b@208.43.85.75 CSeq: 106 INVITE User-Agent: Asterisk PBX Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY Supported: replaces Contact: <sip:1111111111@208.43.85.75> Content-Length: 0 039459: Aug 28 09:09:07.601 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg: Received: SIP/2.0 200 OK Via: SIP/2.0/UDP 184.71.242.2:5060;branch=z9hG4bK1B71E5E;received=184.71.242.2 From: <sip:2222222222@184.71.242.2:5060>;tag=A7CF3A8-B36 To: "1111111111" <sip:1111111111@208.43.85.75>;tag=as40beef80 Call-ID: 150b67c355dd6cc774ad4bca7944ca5b@208.43.85.75 CSeq: 106 INVITE User-Agent: Asterisk PBX Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY Supported: replaces Contact: <sip:1111111111@208.43.85.75> Content-Type: application/sdp Content-Length: 310 v=0 o=root 1022 1028 IN IP4 208.43.85.75 s=session c=IN IP4 208.43.85.75 b=CT:384 t=0 0 m=audio 18910 RTP/AVP 0 101 a=rtpmap:0 PCMU/8000 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-16 a=silenceSupp:off - - - - a=ptime:20 a=inactive m=video 18520 RTP/AVP 34 a=rtpmap:34 H263/90000 a=inactive 039460: Aug 28 09:09:07.605 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg: Sent: ACK sip:1111111111@208.43.85.75 SIP/2.0 Via: SIP/2.0/UDP 184.71.242.2:5060;branch=z9hG4bK1B721B73 From: <sip:2222222222@184.71.242.2:5060>;tag=A7CF3A8-B36 To: "1111111111" <sip:1111111111@208.43.85.75>;tag=as40beef80 Date: Thu, 28 Aug 2014 15:09:07 GMT Call-ID: 150b67c355dd6cc774ad4bca7944ca5b@208.43.85.75 Max-Forwards: 70 CSeq: 106 ACK Allow-Events: telephone-event Content-Length: 0 039461: Aug 28 09:09:07.605 MST: //6872/1164A17192EE/SIP/Msg/ccsipDisplayMsg: Sent: SIP/2.0 200 OK Via: SIP/2.0/UDP 10.135.191.12:5060;branch=z9hG4bKc28659cd830 From: <sip:3000@10.135.191.12>;tag=100429~dc062259-9b0a-4df2-b05d-e4de329c1980-28525423 To: "1111111111" <sip:1111111111@sip1.ixica.com>;tag=A7CF398-21B1 Date: Thu, 28 Aug 2014 15:09:07 GMT Call-ID: 11667682-2DFC11E4-92F4CC10-65967311@172.18.0.1 CSeq: 107 INVITE Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER Allow-Events: telephone-event Remote-Party-ID: "1111111111" <sip:1111111111@172.18.0.1>;party=called;screen=no;privacy=off Contact: <sip:270@172.18.0.1:5060> Supported: replaces Supported: sdp-anat Server: Cisco-SIPGateway/IOS-15.2.4.M6a Require: timer Session-Expires: 1800;refresher=uac Supported: timer Content-Type: application/sdp Content-Length: 280 v=0 o=CiscoSystemsSIP-GW-UserAgent 8203 270 IN IP4 172.18.0.1 s=SIP Call c=IN IP4 172.18.0.1 t=0 0 m=audio 18666 RTP/AVP 0 c=IN IP4 172.18.0.1 a=inactive a=rtpmap:0 PCMU/8000 a=ptime:20 m=video 0 RTP/AVP 34 c=IN IP4 172.18.0.1 a=rtpmap:34 H263/90000 a=fmtp:34 CIF=1 039462: Aug 28 09:09:07.609 MST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Received: ACK sip:270@172.18.0.1:5060 SIP/2.0 Via: SIP/2.0/UDP 10.135.191.12:5060;branch=z9hG4bKc292f69fb64 From: <sip:3000@10.135.191.12>;tag=100429~dc062259-9b0a-4df2-b05d-e4de329c1980-28525423 To: "1111111111" <sip:1111111111@sip1.ixica.com>;tag=A7CF398-21B1 Date: Thu, 28 Aug 2014 15:09:07 GMT Call-ID: 11667682-2DFC11E4-92F4CC10-65967311@172.18.0.1 User-Agent: Cisco-CUCM10.5 Max-Forwards: 70 CSeq: 107 ACK Allow-Events: presence Content-Length: 0 039463: Aug 28 09:09:07.617 MST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Received: INVITE sip:270@172.18.0.1:5060 SIP/2.0 Via: SIP/2.0/UDP 10.135.191.12:5060;branch=z9hG4bKc2a86fb648 From: <sip:3000@10.135.191.12>;tag=100429~dc062259-9b0a-4df2-b05d-e4de329c1980-28525423 To: "1111111111" <sip:1111111111@sip1.ixica.com>;tag=A7CF398-21B1 Date: Thu, 28 Aug 2014 15:09:07 GMT Call-ID: 11667682-2DFC11E4-92F4CC10-65967311@172.18.0.1 Supported: timer,resource-priority,replaces Cisco-Guid: 0291807601-0771494372-2465123344-1704358673 User-Agent: Cisco-CUCM10.5 Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY CSeq: 108 INVITE Max-Forwards: 70 Expires: 180 Allow-Events: presence Call-Info: <urn:x-cisco-remotecc:callinfo>;x-cisco-video-traffic-class=VIDEO_UNSPECIFIED Supported: X-cisco-srtp-fallback Supported: Geolocation Session-Expires: 1800;refresher=uac Min-SE: 1800 P-Asserted-Identity: "Anthony" <sip:270@10.135.191.12> Remote-Party-ID: "Anthony" <sip:270@10.135.191.12>;party=calling;screen=yes;privacy=off Contact: <sip:3000@10.135.191.12:5060>;video;audio Content-Length: 0 039464: Aug 28 09:09:07.621 MST: //6872/1164A17192EE/SIP/Msg/ccsipDisplayMsg: Sent: SIP/2.0 100 Trying Via: SIP/2.0/UDP 10.135.191.12:5060;branch=z9hG4bKc2a86fb648 From: <sip:3000@10.135.191.12>;tag=100429~dc062259-9b0a-4df2-b05d-e4de329c1980-28525423 To: "1111111111" <sip:1111111111@sip1.ixica.com>;tag=A7CF398-21B1 Date: Thu, 28 Aug 2014 15:09:07 GMT Call-ID: 11667682-2DFC11E4-92F4CC10-65967311@172.18.0.1 CSeq: 108 INVITE Allow-Events: telephone-event Server: Cisco-SIPGateway/IOS-15.2.4.M6a Content-Length: 0 039465: Aug 28 09:09:07.621 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg: Sent: INVITE sip:1111111111@208.43.85.75 SIP/2.0 Via: SIP/2.0/UDP 184.71.242.2:5060;branch=z9hG4bK1B73526 From: <sip:2222222222@184.71.242.2:5060>;tag=A7CF3A8-B36 To: "1111111111" <sip:1111111111@208.43.85.75>;tag=as40beef80 Date: Thu, 28 Aug 2014 15:09:07 GMT Call-ID: 150b67c355dd6cc774ad4bca7944ca5b@208.43.85.75 Supported: 100rel,timer,resource-priority,replaces,sdp-anat Min-SE: 1800 Cisco-Guid: 0291807601-0771494372-2465123344-1704358673 User-Agent: Cisco-SIPGateway/IOS-15.2.4.M6a Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER CSeq: 107 INVITE Max-Forwards: 70 Timestamp: 1409238547 Contact: <sip:2222222222@184.71.242.2:5060> Expires: 180 Allow-Events: telephone-event Content-Length: 0 039466: Aug 28 09:09:07.701 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg: Received: SIP/2.0 100 Trying Via: SIP/2.0/UDP 184.71.242.2:5060;branch=z9hG4bK1B73526;received=184.71.242.2 From: <sip:2222222222@184.71.242.2:5060>;tag=A7CF3A8-B36 To: "1111111111" <sip:1111111111@208.43.85.75>;tag=as40beef80 Call-ID: 150b67c355dd6cc774ad4bca7944ca5b@208.43.85.75 CSeq: 107 INVITE User-Agent: Asterisk PBX Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY Supported: replaces Contact: <sip:1111111111@208.43.85.75> Content-Length: 0 039467: Aug 28 09:09:07.705 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg: Received: SIP/2.0 200 OK Via: SIP/2.0/UDP 184.71.242.2:5060;branch=z9hG4bK1B73526;received=184.71.242.2 From: <sip:2222222222@184.71.242.2:5060>;tag=A7CF3A8-B36 To: "1111111111" <sip:1111111111@208.43.85.75>;tag=as40beef80 Call-ID: 150b67c355dd6cc774ad4bca7944ca5b@208.43.85.75 CSeq: 107 INVITE User-Agent: Asterisk PBX Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY Supported: replaces Contact: <sip:1111111111@208.43.85.75> Content-Type: application/sdp Content-Length: 361 v=0 o=root 1022 1029 IN IP4 208.43.85.75 s=session c=IN IP4 208.43.85.75 b=CT:384 t=0 0 m=audio 18910 RTP/AVP 0 8 101 a=rtpmap:0 PCMU/8000 a=rtpmap:8 PCMA/8000 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-16 a=silenceSupp:off - - - - a=ptime:20 a=sendrecv m=video 18520 RTP/AVP 34 99 a=rtpmap:34 H263/90000 a=rtpmap:99 H264/90000 a=sendrecv 039468: Aug 28 09:09:07.709 MST: //6872/1164A17192EE/SIP/Msg/ccsipDisplayMsg: Sent: SIP/2.0 200 OK Via: SIP/2.0/UDP 10.135.191.12:5060;branch=z9hG4bKc2a86fb648 From: <sip:3000@10.135.191.12>;tag=100429~dc062259-9b0a-4df2-b05d-e4de329c1980-28525423 To: "1111111111" <sip:1111111111@sip1.ixica.com>;tag=A7CF398-21B1 Date: Thu, 28 Aug 2014 15:09:07 GMT Call-ID: 11667682-2DFC11E4-92F4CC10-65967311@172.18.0.1 CSeq: 108 INVITE Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER Allow-Events: telephone-event Remote-Party-ID: "1111111111" <sip:1111111111@172.18.0.1>;party=called;screen=no;privacy=off Contact: <sip:270@172.18.0.1:5060> Supported: replaces Supported: sdp-anat Server: Cisco-SIPGateway/IOS-15.2.4.M6a Require: timer Session-Expires: 1800;refresher=uac Supported: timer Content-Type: application/sdp Content-Length: 393 v=0 o=CiscoSystemsSIP-GW-UserAgent 8203 271 IN IP4 172.18.0.1 s=SIP Call c=IN IP4 172.18.0.1 t=0 0 m=audio 18666 RTP/AVP 0 101 c=IN IP4 172.18.0.1 a=rtpmap:0 PCMU/8000 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-16 a=ptime:20 m=video 18674 RTP/AVP 34 119 c=IN IP4 172.18.0.1 a=rtpmap:34 H263/90000 a=fmtp:34 CIF=1 a=rtpmap:119 H264/90000 a=fmtp:119 profile-level-id=000000 039469: Aug 28 09:09:07.721 MST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Received: ACK sip:270@172.18.0.1:5060 SIP/2.0 Via: SIP/2.0/UDP 10.135.191.12:5060;branch=z9hG4bKc2b4dadf04c From: <sip:3000@10.135.191.12>;tag=100429~dc062259-9b0a-4df2-b05d-e4de329c1980-28525423 To: "1111111111" <sip:1111111111@sip1.ixica.com>;tag=A7CF398-21B1 Date: Thu, 28 Aug 2014 15:09:07 GMT Call-ID: 11667682-2DFC11E4-92F4CC10-65967311@172.18.0.1 User-Agent: Cisco-CUCM10.5 Max-Forwards: 70 CSeq: 108 ACK Allow-Events: presence, kpml Content-Type: application/sdp Content-Length: 405 v=0 o=CiscoSystemsCCM-SIP 100429 8 IN IP4 10.135.191.12 s=SIP Call b=TIAS:64000 b=AS:64 t=0 0 m=audio 29928 RTP/AVP 0 101 c=IN IP4 10.135.191.54 a=rtpmap:0 PCMU/8000 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-15 m=video 0 RTP/AVP 31 34 96 97 c=IN IP4 0.0.0.0 a=rtpmap:31 H261/90000 a=rtpmap:34 H263/90000 a=rtpmap:96 H263-1998/90000 a=rtpmap:97 H264/90000 a=content:main a=inactive 039470: Aug 28 09:09:07.729 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg: Sent: ACK sip:1111111111@208.43.85.75 SIP/2.0 Via: SIP/2.0/UDP 184.71.242.2:5060;branch=z9hG4bK1B7420AC From: <sip:2222222222@184.71.242.2:5060>;tag=A7CF3A8-B36 To: "1111111111" <sip:1111111111@208.43.85.75>;tag=as40beef80 Date: Thu, 28 Aug 2014 15:09:07 GMT Call-ID: 150b67c355dd6cc774ad4bca7944ca5b@208.43.85.75 Max-Forwards: 70 CSeq: 107 ACK Allow-Events: telephone-event Content-Type: application/sdp Content-Length: 292 v=0 o=CiscoSystemsSIP-GW-UserAgent 7259 1410 IN IP4 184.71.242.2 s=SIP Call c=IN IP4 184.71.242.2 t=0 0 m=audio 18662 RTP/AVP 0 101 c=IN IP4 184.71.242.2 a=rtpmap:0 PCMU/8000 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-16 a=ptime:20 m=video 0 RTP/AVP 34 c=IN IP4 184.71.242.2 039471: Aug 28 09:09:07.729 MST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Received: UPDATE sip:270@172.18.0.1:5060 SIP/2.0 Via: SIP/2.0/UDP 10.135.191.12:5060;branch=z9hG4bKc2c12c97bd7 From: <sip:3000@10.135.191.12>;tag=100429~dc062259-9b0a-4df2-b05d-e4de329c1980-28525423 To: "1111111111" <sip:1111111111@sip1.ixica.com>;tag=A7CF398-21B1 Date: Thu, 28 Aug 2014 15:09:07 GMT Call-ID: 11667682-2DFC11E4-92F4CC10-65967311@172.18.0.1 User-Agent: Cisco-CUCM10.5 Max-Forwards: 70 Supported: timer,resource-priority,replaces Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY CSeq: 109 UPDATE Call-Info: <urn:x-cisco-remotecc:callinfo>;x-cisco-video-traffic-class=DESKTOP Supported: X-cisco-srtp-fallback Supported: Geolocation Session-Expires: 1800;refresher=uac Min-SE: 1800 P-Asserted-Identity: "Anthony" <sip:270@10.135.191.12> Remote-Party-ID: "Anthony" <sip:270@10.135.191.12>;party=calling;screen=yes;privacy=off Contact: <sip:0b11a44f-86ee-41f9-ee7e-e8a942be2210@10.135.191.12:5060> Content-Length: 0 039472: Aug 28 09:09:07.733 MST: //6872/1164A17192EE/SIP/Msg/ccsipDisplayMsg: Sent: SIP/2.0 200 OK Via: SIP/2.0/UDP 10.135.191.12:5060;branch=z9hG4bKc2c12c97bd7 From: <sip:3000@10.135.191.12>;tag=100429~dc062259-9b0a-4df2-b05d-e4de329c1980-28525423 To: "1111111111" <sip:1111111111@sip1.ixica.com>;tag=A7CF398-21B1 Date: Thu, 28 Aug 2014 15:09:07 GMT Call-ID: 11667682-2DFC11E4-92F4CC10-65967311@172.18.0.1 Server: Cisco-SIPGateway/IOS-15.2.4.M6a CSeq: 109 UPDATE Allow-Events: telephone-event Contact: <sip:270@172.18.0.1:5060> Require: timer Session-Expires: 1800;refresher=uac Supported: timer Content-Length: 0 039473: Aug 28 09:09:16.049 MST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Received: INVITE sip:270@172.18.0.1:5060 SIP/2.0 Via: SIP/2.0/UDP 10.135.191.12:5060;branch=z9hG4bKc2f4b354494 From: <sip:3000@10.135.191.12>;tag=100429~dc062259-9b0a-4df2-b05d-e4de329c1980-28525423 To: "1111111111" <sip:1111111111@sip1.ixica.com>;tag=A7CF398-21B1 Date: Thu, 28 Aug 2014 15:09:15 GMT Call-ID: 11667682-2DFC11E4-92F4CC10-65967311@172.18.0.1 Supported: timer,resource-priority,replaces Cisco-Guid: 0291807601-0771494372-2465123344-1704358673 User-Agent: Cisco-CUCM10.5 Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY CSeq: 110 INVITE Max-Forwards: 70 Expires: 180 Allow-Events: presence Call-Info: <urn:x-cisco-remotecc:callinfo>;x-cisco-video-traffic-class=DESKTOP Supported: X-cisco-srtp-fallback Supported: Geolocation Session-Expires: 1800;refresher=uac Min-SE: 1800 P-Asserted-Identity: "Anthony" <sip:270@10.135.191.12> Remote-Party-ID: "Anthony" <sip:270@10.135.191.12>;party=calling;screen=yes;privacy=off Contact: <sip:0b11a44f-86ee-41f9-ee7e-e8a942be2210@10.135.191.12:5060> Content-Type: application/sdp Content-Length: 393 v=0 o=CiscoSystemsCCM-SIP 100429 9 IN IP4 10.135.191.12 s=SIP Call c=IN IP4 0.0.0.0 b=TIAS:64000 b=AS:64 t=0 0 m=audio 29928 RTP/AVP 0 101 a=rtpmap:0 PCMU/8000 a=inactive a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-15 m=video 0 RTP/AVP 31 34 96 97 a=rtpmap:31 H261/90000 a=rtpmap:34 H263/90000 a=rtpmap:96 H263-1998/90000 a=rtpmap:97 H264/90000 a=content:main a=inactive 039474: Aug 28 09:09:16.057 MST: //6872/1164A17192EE/SIP/Msg/ccsipDisplayMsg: Sent: SIP/2.0 100 Trying Via: SIP/2.0/UDP 10.135.191.12:5060;branch=z9hG4bKc2f4b354494 From: <sip:3000@10.135.191.12>;tag=100429~dc062259-9b0a-4df2-b05d-e4de329c1980-28525423 To: "1111111111" <sip:1111111111@sip1.ixica.com>;tag=A7CF398-21B1 Date: Thu, 28 Aug 2014 15:09:16 GMT Call-ID: 11667682-2DFC11E4-92F4CC10-65967311@172.18.0.1 CSeq: 110 INVITE Allow-Events: telephone-event Server: Cisco-SIPGateway/IOS-15.2.4.M6a Content-Length: 0 039475: Aug 28 09:09:16.057 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg: Sent: INVITE sip:1111111111@208.43.85.75 SIP/2.0 Via: SIP/2.0/UDP 184.71.242.2:5060;branch=z9hG4bK1B751A02 From: <sip:2222222222@184.71.242.2:5060>;tag=A7CF3A8-B36 To: "1111111111" <sip:1111111111@208.43.85.75>;tag=as40beef80 Date: Thu, 28 Aug 2014 15:09:16 GMT Call-ID: 150b67c355dd6cc774ad4bca7944ca5b@208.43.85.75 Supported: 100rel,timer,resource-priority,replaces,sdp-anat Min-SE: 1800 Cisco-Guid: 0291807601-0771494372-2465123344-1704358673 User-Agent: Cisco-SIPGateway/IOS-15.2.4.M6a Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER CSeq: 108 INVITE Max-Forwards: 70 Timestamp: 1409238556 Contact: <sip:2222222222@184.71.242.2:5060> Expires: 180 Allow-Events: telephone-event Content-Type: application/sdp Content-Length: 294 v=0 o=CiscoSystemsSIP-GW-UserAgent 7259 1411 IN IP4 184.71.242.2 s=SIP Call c=IN IP4 0.0.0.0 t=0 0 m=audio 18662 RTP/AVP 0 101 c=IN IP4 0.0.0.0 a=inactive a=rtpmap:0 PCMU/8000 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-16 a=ptime:20 m=video 0 RTP/AVP 34 c=IN IP4 184.71.242.2 039476: Aug 28 09:09:16.141 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg: Received: SIP/2.0 100 Trying Via: SIP/2.0/UDP 184.71.242.2:5060;branch=z9hG4bK1B751A02;received=184.71.242.2 From: <sip:2222222222@184.71.242.2:5060>;tag=A7CF3A8-B36 To: "1111111111" <sip:1111111111@208.43.85.75>;tag=as40beef80 Call-ID: 150b67c355dd6cc774ad4bca7944ca5b@208.43.85.75 CSeq: 108 INVITE User-Agent: Asterisk PBX Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY Supported: replaces Contact: <sip:1111111111@208.43.85.75> Content-Length: 0 039477: Aug 28 09:09:16.141 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg: Received: SIP/2.0 200 OK Via: SIP/2.0/UDP 184.71.242.2:5060;branch=z9hG4bK1B751A02;received=184.71.242.2 From: <sip:2222222222@184.71.242.2:5060>;tag=A7CF3A8-B36 To: "1111111111" <sip:1111111111@208.43.85.75>;tag=as40beef80 Call-ID: 150b67c355dd6cc774ad4bca7944ca5b@208.43.85.75 CSeq: 108 INVITE User-Agent: Asterisk PBX Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY Supported: replaces Contact: <sip:1111111111@208.43.85.75> Content-Type: application/sdp Content-Length: 310 v=0 o=root 1022 1030 IN IP4 208.43.85.75 s=session c=IN IP4 208.43.85.75 b=CT:384 t=0 0 m=audio 18910 RTP/AVP 0 101 a=rtpmap:0 PCMU/8000 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-16 a=silenceSupp:off - - - - a=ptime:20 a=inactive m=video 18520 RTP/AVP 34 a=rtpmap:34 H263/90000 a=inactive 039478: Aug 28 09:09:16.149 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg: Sent: ACK sip:1111111111@208.43.85.75 SIP/2.0 Via: SIP/2.0/UDP 184.71.242.2:5060;branch=z9hG4bK1B7624B6 From: <sip:2222222222@184.71.242.2:5060>;tag=A7CF3A8-B36 To: "1111111111" <sip:1111111111@208.43.85.75>;tag=as40beef80 Date: Thu, 28 Aug 2014 15:09:16 GMT Call-ID: 150b67c355dd6cc774ad4bca7944ca5b@208.43.85.75 Max-Forwards: 70 CSeq: 108 ACK Allow-Events: telephone-event Content-Length: 0 039479: Aug 28 09:09:16.149 MST: //6872/1164A17192EE/SIP/Msg/ccsipDisplayMsg: Sent: SIP/2.0 200 OK Via: SIP/2.0/UDP 10.135.191.12:5060;branch=z9hG4bKc2f4b354494 From: <sip:3000@10.135.191.12>;tag=100429~dc062259-9b0a-4df2-b05d-e4de329c1980-28525423 To: "1111111111" <sip:1111111111@sip1.ixica.com>;tag=A7CF398-21B1 Date: Thu, 28 Aug 2014 15:09:16 GMT Call-ID: 11667682-2DFC11E4-92F4CC10-65967311@172.18.0.1 CSeq: 110 INVITE Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER Allow-Events: telephone-event Remote-Party-ID: "1111111111" <sip:1111111111@172.18.0.1>;party=called;screen=no;privacy=off Contact: <sip:270@172.18.0.1:5060> Supported: replaces Supported: sdp-anat Server: Cisco-SIPGateway/IOS-15.2.4.M6a Require: timer Session-Expires: 1800;refresher=uac Supported: timer Content-Type: application/sdp Content-Length: 336 v=0 o=CiscoSystemsSIP-GW-UserAgent 8203 272 IN IP4 172.18.0.1 s=SIP Call c=IN IP4 172.18.0.1 t=0 0 m=audio 18666 RTP/AVP 0 101 c=IN IP4 172.18.0.1 a=inactive a=rtpmap:0 PCMU/8000 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-16 a=ptime:20 m=video 0 RTP/AVP 34 c=IN IP4 172.18.0.1 a=rtpmap:34 H263/90000 a=fmtp:34 CIF=1 039480: Aug 28 09:09:16.153 MST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Received: ACK sip:270@172.18.0.1:5060 SIP/2.0 Via: SIP/2.0/UDP 10.135.191.12:5060;branch=z9hG4bKc30696ffa8d From: <sip:3000@10.135.191.12>;tag=100429~dc062259-9b0a-4df2-b05d-e4de329c1980-28525423 To: "1111111111" <sip:1111111111@sip1.ixica.com>;tag=A7CF398-21B1 Date: Thu, 28 Aug 2014 15:09:15 GMT Call-ID: 11667682-2DFC11E4-92F4CC10-65967311@172.18.0.1 User-Agent: Cisco-CUCM10.5 Max-Forwards: 70 CSeq: 110 ACK Allow-Events: presence Content-Length: 0 039481: Aug 28 09:09:16.157 MST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Received: BYE sip:270@172.18.0.1:5060 SIP/2.0 Via: SIP/2.0/UDP 10.135.191.12:5060;branch=z9hG4bKc31527a26a6 From: <sip:3000@10.135.191.12>;tag=100429~dc062259-9b0a-4df2-b05d-e4de329c1980-28525423 To: "1111111111" <sip:1111111111@sip1.ixica.com>;tag=A7CF398-21B1 Date: Thu, 28 Aug 2014 15:09:15 GMT Call-ID: 11667682-2DFC11E4-92F4CC10-65967311@172.18.0.1 User-Agent: Cisco-CUCM10.5 Max-Forwards: 70 CSeq: 111 BYE Reason: Q.850;cause=16 Content-Length: 0 039482: Aug 28 09:09:16.165 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg: Sent: BYE sip:1111111111@208.43.85.75 SIP/2.0 Via: SIP/2.0/UDP 184.71.242.2:5060;branch=z9hG4bK1B772138 From: <sip:2222222222@184.71.242.2:5060>;tag=A7CF3A8-B36 To: "1111111111" <sip:1111111111@208.43.85.75>;tag=as40beef80 Date: Thu, 28 Aug 2014 15:09:16 GMT Call-ID: 150b67c355dd6cc774ad4bca7944ca5b@208.43.85.75 User-Agent: Cisco-SIPGateway/IOS-15.2.4.M6a Max-Forwards: 70 Timestamp: 1409238556 CSeq: 109 BYE Reason: Q.850;cause=16 P-RTP-Stat: PS=857,OS=137120,PR=620,OR=90776,PL=0,JI=0,LA=0,DU=18 Content-Length: 0 039483: Aug 28 09:09:16.165 MST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Sent: SIP/2.0 200 OK Via: SIP/2.0/UDP 10.135.191.12:5060;branch=z9hG4bKc31527a26a6 From: <sip:3000@10.135.191.12>;tag=100429~dc062259-9b0a-4df2-b05d-e4de329c1980-28525423 To: "1111111111" <sip:1111111111@sip1.ixica.com>;tag=A7CF398-21B1 Date: Thu, 28 Aug 2014 15:09:16 GMT Call-ID: 11667682-2DFC11E4-92F4CC10-65967311@172.18.0.1 Server: Cisco-SIPGateway/IOS-15.2.4.M6a CSeq: 111 BYE Reason: Q.850;cause=16 P-RTP-Stat: PS=620,OS=90776,PR=857,OR=137120,PL=0,JI=0,LA=0,DU=18 Content-Length: 0 039484: Aug 28 09:09:16.249 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg: Received: SIP/2.0 200 OK Via: SIP/2.0/UDP 184.71.242.2:5060;branch=z9hG4bK1B772138;received=184.71.242.2 From: <sip:2222222222@184.71.242.2:5060>;tag=A7CF3A8-B36 To: "1111111111" <sip:1111111111@208.43.85.75>;tag=as40beef80 Call-ID: 150b67c355dd6cc774ad4bca7944ca5b@208.43.85.75 CSeq: 109 BYE User-Agent: Asterisk PBX Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY Supported: replaces Contact: <sip:1111111111@208.43.85.75> Content-Length: 0
09-15-2014 09:31 AM
Looks like this was all caused by a DTMF mismatch between the provider and the CUCM SIP trunk...
Requiring MTP on the trunk fixed the issue.
08-27-2014 09:41 AM
The codec is G711ulaw
Relevant CUBE config:
voice service voip ip address trusted list ipv4 208.43.85.75 255.255.255.255 ipv4 10.135.191.12 255.255.255.255 mode border-element allow-connections sip to sip fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none sip registrar server expires max 1200 min 300 early-offer forced midcall-signaling passthru voice translation-rule 1 rule 1 /^9/ // ! voice translation-rule 2 rule 1 /REDACTEDTENDIGITNUMBER/ /3000/ ! ! voice translation-profile INCOMING1 translate called 2 ! voice translation-profile Strip9 translate called 1 dial-peer voice 333 pots description Overhead PAging destination-pattern 3333 port 0/0/0 no sip-register ! dial-peer voice 1000 voip description *** Outbound CUCM *** destination-pattern ....? session protocol sipv2 session target ipv4:10.135.191.12 dtmf-relay rtp-nte codec g711ulaw no vad ! dial-peer voice 2000 voip description *** Inbound CUCM *** session protocol sipv2 incoming called-number ....? dtmf-relay rtp-nte codec g711ulaw no vad ! dial-peer voice 101 voip description *** Incoming Dial-Peer *** translation-profile incoming INCOMING1 session protocol sipv2 session target sip-server incoming called-number redactedtendigitnumber dtmf-relay rtp-nte codec g711ulaw no vad ! dial-peer voice 1 voip description *** Outbound Dial-Peer *** translation-profile outgoing Strip9 destination-pattern 9.+ session protocol sipv2 session target sip-server dtmf-relay rtp-nte codec g711ulaw no vad ! ! sip-ua credentials username redacted password 7 redacted realm redacted authentication username redacted password 7 redacted registrar dns:sip1.ixica.com expires 60 sip-server dns:sip1.ixica.com
