Unity Connection 11.5 MTP and DTMF
Vinh Nguyen
Hi All
I recently upgraded from CUC 10.5 to 11.5.  After upgrade there is no DTMF being sent from IP Phones registered with CUCM (also upgraded from 10.5 to 11.5).  The integration is SIP.  The Unity Connections work fine with CUCM on 10.5.  I have tried all sorts of configurations but no luck.  The only way it will work is if I tick the MTP required on the SIP Trunk to Unity Connections.  However I don't want to use MTP.  Is there anything change in CUC 11.5 for this to occur?
R0g22
What is the SIP trunk DTMF preference ? Can you take a SDL trace for a test call and share here ?
I have tried various DTMF options however it is not standard Unity Connections configuration.  All the configurations should be retained from the upgrade.  Why does it all of a sudden need MTP going from 10.5 to 11.5
There can be a variety of reasons from a unintended config change to hitting an unexpected bug. Are these Cisco IP Phones or third party phones (please mention the phone model)? Also please attach Callmanager traces for a failed call.
Please rate if you find this helpful.
Aeby
Aeby
This is the trace.  VM Pilot is 5555.  Tested extension from 4030 and 5174
