I just completed my PUT order for the upgrade license from 7.x to 8.x and the only options I was able to see were for the UNRESTRICTED version of the software. I waited for my order to be fulfilled and eDelivery to happen and sure enough, I got a PAK.
I registered the PAK and downloaded my migration license and in the license it says its for the UNRESTRICTED version of CUCXN.
Will this work for a restricted install? I want to stay on the restricted setup... should I open a case with licensing?
Solved! Go to Solution.
Hi William,
I see your dilemma here
If you were to use the Software Download linked to this order
you would most likely be offered the "Unrestricted" version of
CUC 8.6 which you don't want.
The licensing portion will be fine, but you'll either want to re-do
the order via PUT or just download the restricted version via CCO;
It should look like this;
UCSInstall_UCOS_8.6.2.22900-9.sgn.iso
And NOT this;
UCSInstall_UCOS_UNRST_8.6.2.22900-9.sgn.iso
Cheers!
Rob
"Talk about a dream
Try to make it real"
- Springsteen
I don't think the license matters, but you certainly want to install RESTRICTED version, so make sure the install media is such.
HTH,
Chris
Is there any documentation to back that up? Has anyone ever run into this issue?
Hi William,
Just to add what Mr. Chris has said:
Please refer to URL for Call Manager . It would be same for Unity connection as well.It says
In addition to the delay inherent in obtaining export licenses, products classified
as restricted by the Department of Commerce (DoC) carry a requirement to allow
US government representatives to demand on-site inspections at any time to
confirm that the product is being used in accordance with its licensed purpose.
https://supportforums.cisco.com/docs/DOC-24523
regds,
aman
Hi William,
+5 to Chris & Aman for their good notes/tips here!
I've never seen an actual reference to the build version
"Restricted vs Unrestricted" in a license file so I was wondering
if you might be able to attach a santized copy here.
You may be seeing;
LicRegionIsUnrestricted
Which is common to all CUC license files we've ever used and we
are running the Restricted version
Cheers!
Rob
"Talk about a dream
- Springsteen
I was looking in the License file and saw the part you are referring to, and maybe I mis-spoke in my original post about seeing it only being for the unrestricted version. However, when I ordered through PUT, I was only able to select the export unrestricted and got the eDelivery message attached.
Hi William,
And NOT this;
Cheers!
Rob
"Talk about a dream
- Springsteen
Yes, I have 8.6.2a (SU2) (UCSInstall_UCOS_8.6.2.22900-9.sgn) from another install I did for another customer, so I have the CUCM/CUC software I need without downloading anything. I just wanted to confirm that the "unrestricted" license could and would work for the restricted version of software. I was really looking for any kind of documentation I could get that points this out.
I was offered the unrestricted download through that link in the eDelivery email and wanted to make sure the license was compatible with both.
Thanks very much for your help!
