07-27-2011 12:00 PM - edited 03-16-2019 06:10 AM
I have UC 8.0 & i would like to integrate the same with Microsoft Exchange 2010 & AD..Can you someone guide me what are the features that will i get from sich integration? Can i have every features that of Unity Server integration with Microsoft Exchange??
Rgds,
Partha
07-27-2011 12:23 PM
Not on 8.0.
Most likely you're looking for single inbox, but that's on CUC 8.5
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
07-28-2011 04:30 AM
Thanks Java. What kind of features that we will get from 8.0 UC integration with Exchange??
Rgds,
Partha
07-28-2011 07:15 AM
They really don't integrate, what you can do is use the relay feature to forward a copy of the VMs to Exchange.
But since this is not single inbox when they hear the VM they won't get the MWI off.
java
08-17-2011 05:26 AM
Hi java,
Whether such integration possible between Unity connection 8.5 & Exchange??
Rgds,
